 Val World Chat Champion
 janner_10 World Chat Champion
 Walloper Super Spammer
 Posted: 17:17 - 18 Nov 2012 Post subject: |
Don't start the bike for 5-10 minutes.
The engine will only get wet internally as it will not get warm enough to drive off moisture from combustion.
If you are going to run it run it until the fan comes on then switches off, give the throttle a blip or three to clear it's throat of unburned petrol (and shit) then shut it down.
Also, the energy taken from the battery for the start cycle will need to be replaced and an alternator needs a bit of RPMs to effectively charge a battery. Over 2000RPMs A figure I just plucked out of the air there..
Get an optimizer.
Good ones are not cheap but cheaper than a couple of new batteries.
C-Tek are the best that I've used. And I've burned out two Optimates. And two Hien Gericke optimizers. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
