| Ruar3b |
 Ruar3b L Plate Warrior
| 69chris |
 69chris Trackday Trickster
 Posted: 16:27 - 18 Nov 2012 Post subject: |
whip off the tank and check the connections where the engine loom joins the main loom (l/h/s of the frame)
these can corroded and often need some 'patient' cleaning out
mine was doing a similar thing and the above, and cleaning the earth connections seemed to sort it ouf  |
| Ruar3b |
| 69chris |
 Posted: 17:23 - 18 Nov 2012 Post subject: |
yes mine had no spark untill i wiggled the wiring at the point of the connectors, then it started straight up,
i still had no headlight untill i stripped and cleaned the connectors tho,
they looked clean enough but infact had a clear'ish coating of...... something yucky on them, some tarnish type crap that i had to gently scrape off with a blade, then clean with fine sandpaper,
good luck mate  |
| Vincent |
 Vincent Banned
| Ruar3b |
| at106 |
 at106 Brolly Dolly
The last post was made 13 years, 310 days ago. Instead of replying here, would creating a new thread be more useful? |
