Zorst Ring Thing
WannaBeDude
PostPosted: 14:10 - 21 Nov 2012    Post subject: Zorst Ring Thing Reply with quote
2T 125 have 2 rubber rings that fit inside the pipe just before engine, one small and one big one, im missing one, what effect would or could this have ? Karma Question Smile
mentalboy
PostPosted: 15:11 - 21 Nov 2012    Post subject: Reply with quote
C'mon you know the drill. Make, model, year.
It's not unusual to find different bikes with non - copper header gaskets, however when you say two different sizes do you mean diameters? Sounds like one is original and other a bodge if so.
Make mine a Corona.
WannaBeDude
PostPosted: 17:41 - 21 Nov 2012    Post subject: Reply with quote
2009 125 Raptor ( Mito ) - they were new rubber rings for pipe engine end, for within pipe, the larger one has been fitted on the outside of the pipe, so where its supposed to be there is not one there, or maybe there is, but I never saw one, even with grease the larger one would not seat, supposed to be awkward fit.
May be PJME gave me wrong size, doubtful.
Just wondering effects, whether to refit one, or leave until I buy a new pipe maybe next year.
Jetting and plug chops are A ok. Thumbs Up Karma
mentalboy
PostPosted: 17:58 - 21 Nov 2012    Post subject: Reply with quote
Sounds like it's only there to help stop blowing. I'd try it and see.Worst that can happen is it'll chuck fumes out.
Make mine a Corona.
WannaBeDude
PostPosted: 19:23 - 21 Nov 2012    Post subject: Reply with quote
The rings are for INSIDE the pipe, looking for a definitive answer as to what they do, and what not having the larger one does. Thumbs Up
mentalboy
PostPosted: 20:41 - 21 Nov 2012    Post subject: Reply with quote
Ok, we'll start again. You are saying that these are not exhaust gaskets right?
If not I would speculate that they are something to do with restricting it. In which case I would have thought that one of these would be conical.
Make mine a Corona.
WannaBeDude
PostPosted: 20:47 - 21 Nov 2012    Post subject: Reply with quote
Tbf - ive said what their made of and where their supposed to go - Thumbs Up Rolling Eyes
mentalboy
PostPosted: 20:54 - 21 Nov 2012    Post subject: Reply with quote
Shouldn't be too hard to work out then Rolling Eyes
Make mine a Corona.
nowhere.elysium
The Pork Lord
PostPosted: 21:04 - 21 Nov 2012    Post subject: Reply with quote
I'd imagine they're vitron rubber, which is (IIRC) treated to survive high temperatures. As for what effect it'd have; as with all two-strokes, they're very sensitive to changes in the incoming and outgoing flow of gases, so I'd imagine you'd potentially lose a bit of power, and if it flowed extra gas beyond a certain threshold, it might start to get a bit lean.
However, this post should be taken with a pinch of salt, since I've never actually owned or ridden a two-stroke; a fact that I lament, but can't really be bothered to remedy.
mentalboy
PostPosted: 21:13 - 21 Nov 2012    Post subject: Reply with quote
So it's outside the inside of the pipe Confused
As N.E. said it will alter pressures thus if inside pipe will make lean when removed, you'll have to upjet. It is quite common to fit these as restrictions in 50's and 125's
Make mine a Corona.
WannaBeDude
PostPosted: 21:36 - 21 Nov 2012    Post subject: Reply with quote
Well if I put the larger one back in I will have to downjet then, running 132 main - with str through end can, standard is 120. Rolling Eyes
WannaBeDude
PostPosted: 21:52 - 21 Nov 2012    Post subject: Reply with quote
Basically if its fine without, then 132 main is ok with me ... pulls ok - no issues there - so - Confused
WannaBeDude
PostPosted: 09:06 - 22 Nov 2012    Post subject: Reply with quote
Ta = now I don't know if I have more or less powah !! wtf are the 2 T experts. Evil or Very Mad
WannaBeDude
PostPosted: 10:19 - 22 Nov 2012    Post subject: Re: RuneScape Gold Reply with quote
d3center wrote:
The author's view is very special, It's beneficial to my study and life.So,I am consent with the author's word absolutely.I like to Diablo 3 and looking forward to play with you.
As far as I'm concerned,Diablo 3 is very intersting. Buying Diablo III Gold from vipdiablo3 is the most convenient and fastest way.I can always get a secure delivery within 15mins minutes ,they can always make sure my enjoying not being disrupted and having execute more exciting. Buying cost-effective diablo III gold from the most reputable online store:vipdiablo3 is the best assistance of getting Diablo 3 Gold. They deserve it.So I often buy Diablo 3 gold at the following webpage:vipdiablo3.
topgw2gold is an established Guild Wars 2 company that provides all kinds of Guild Wars 2 products, such as Guild Wars 2 Gold.Welcome to buy Diablo 3 Gold in our store through following:topgw2gold.
rsgold2buy as the most reputable RuneScape Gold supplier in world,is specialized in providing you cheapest RuneScape Gold with the best service.If you need to buy RuneScape Gold,just take a look here rsgold2buy,you will take fancy with this site all along.
Great post of amusing confusion and wtf !!
mentalboy
PostPosted: 12:32 - 22 Nov 2012    Post subject: Reply with quote
Cov - dude take a chill pill.
It's a two stroke not a clockwork hydrogen processing plant!
So we have established that you have two rubber rings inside the pipe, they're not exhaust header gaskets, and one of them doesn't fit.
What was the set up before you removed said exhaust pipe?
You'll be ok running up jetted carb at the moment because the stock exhaust has been replaced with a straight through which will make bike run leaner.
A plug chop will confirm that your mixture is ok, or not.
If I read you right then the larger one was never there, which would probably mean it was binned when someone was beefing up performance.
Because of the importance of exhaust diameter/ pipe length for a two stroke to run well, it would suggest to me that Cagiva designed set up for its optimal performance and added a ring in the pipe to make it conform to certain markets. Ones with bhp restrictions get rings, ones without don't.
Make mine a Corona.
WannaBeDude
PostPosted: 12:54 - 22 Nov 2012    Post subject: Reply with quote
Think the rings are to help seal pipe to manifold Question
Am chilled. have asked - before, now and elsewhere, no definitive answer ... Sad
mentalboy
PostPosted: 13:02 - 22 Nov 2012    Post subject: Reply with quote
After all that you think they're header gaskets? Methinks you should find a manual Rolling Eyes
Make mine a Corona.
WannaBeDude
PostPosted: 13:08 - 22 Nov 2012    Post subject: Reply with quote
Pic on here scroll down a bit ... Karma
https://www.125ccsportsbikes.com/forums/index.php?showtopic=99666
mentalboy
PostPosted: 13:19 - 22 Nov 2012    Post subject: Reply with quote
So does the larger one fit into a recess or a groove? If it would fit that is!
Edit: I hope that pics not yours, it's hanging!
Make mine a Corona.
WannaBeDude
PostPosted: 15:23 - 22 Nov 2012    Post subject: Reply with quote
Below pic is a diagram, fits into groove Cool
mentalboy
PostPosted: 19:08 - 22 Nov 2012    Post subject: Reply with quote
I think you'll just have to keep fighting that ring into place, it looks like it is only a gasket to prevent blowing. It'll make it noisy without and may affect smooth running, I doubt very much if it's the wrong size, sounds like you're not the only one to have grief fighting it into place.
You could try heating pipe to make it expand, best way if you are careful would be to put pipe in place and run up engine. Best way to hold pipe after heat would be to get a solder mat and wrap it round pipe. Very Happy
Make mine a Corona.
WannaBeDude
PostPosted: 19:18 - 22 Nov 2012    Post subject: Reply with quote
A competent person will be doing it in future, so you think come new pipe time, buy some new rings and use them.?
The bike is loud, as the end can is str through, but still has baffles.
Not sure if more noise is present as a result of the missing ring.
Bike was checked as not blowing.
On decoking pipe / all new gaskets were put on using paste, same time was the new can.
As a result of the above, jetting was changed a few times until plug chops were good.
Whilst arrow stated 120 jet for their can, I think they mean their can plus pipe.
So I now believe, new arrow pipe and gaskets, decoke and rejet is the way forward ?
And thanks for your help and time dude ! Karma
mentalboy
PostPosted: 19:25 - 22 Nov 2012    Post subject: Reply with quote
No problems Smile
What is wrong with the current pipe, is it not an Arrow? It may help final max output values but at the end of the day you could end up spending silly money in order to achieve a barely noticeable improvement in performance.
Make mine a Corona.
WannaBeDude
PostPosted: 19:30 - 22 Nov 2012    Post subject: Reply with quote
Its only the pipe which will be about 170 quid or so, the current pipe is very good, but weighs a ton, will get circa 40 quid plus for it to put towards new pipe.
Its merely come decoke time will make the upgrade, arrow pipe is a lot less weight, as was the can upgrade from standard. The small extra top end will help a tad, I don't mind suffering less midrange as a result.
Its easily done and jeted, would get Jolly etc, but will keep it nice and simple ish.
The last post was made 13 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.55 - MySQL Queries: 16 - Page Size: 132.74 Kb
