| WannaBeDude |
 WannaBeDude World Chat Champion
 Posted: 14:10 - 21 Nov 2012 Post subject: Zorst Ring Thing |
2T 125 have 2 rubber rings that fit inside the pipe just before engine, one small and one big one, im missing one, what effect would or could this have ?  ____________________ Jogging on, destination living. |
| mentalboy |
 mentalboy World Chat Champion
| WannaBeDude |
 Posted: 17:41 - 21 Nov 2012 Post subject: |
2009 125 Raptor ( Mito ) - they were new rubber rings for pipe engine end, for within pipe, the larger one has been fitted on the outside of the pipe, so where its supposed to be there is not one there, or maybe there is, but I never saw one, even with grease the larger one would not seat, supposed to be awkward fit.
May be PJME gave me wrong size, doubtful.
Just wondering effects, whether to refit one, or leave until I buy a new pipe maybe next year.
Jetting and plug chops are A ok.  ____________________ Jogging on, destination living. |
| mentalboy |
| WannaBeDude |
 Posted: 19:23 - 21 Nov 2012 Post subject: |
The rings are for INSIDE the pipe, looking for a definitive answer as to what they do, and what not having the larger one does.  ____________________ Jogging on, destination living. |
| mentalboy |
| WannaBeDude |
 Posted: 20:47 - 21 Nov 2012 Post subject: |
Tbf - ive said what their made of and where their supposed to go -  ____________________ Jogging on, destination living. |
| mentalboy |
 Posted: 20:54 - 21 Nov 2012 Post subject: |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 21:04 - 21 Nov 2012 Post subject: |
I'd imagine they're vitron rubber, which is (IIRC) treated to survive high temperatures. As for what effect it'd have; as with all two-strokes, they're very sensitive to changes in the incoming and outgoing flow of gases, so I'd imagine you'd potentially lose a bit of power, and if it flowed extra gas beyond a certain threshold, it might start to get a bit lean.
However, this post should be taken with a pinch of salt, since I've never actually owned or ridden a two-stroke; a fact that I lament, but can't really be bothered to remedy. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| mentalboy |
| WannaBeDude |
 Posted: 21:36 - 21 Nov 2012 Post subject: |
Well if I put the larger one back in I will have to downjet then, running 132 main - with str through end can, standard is 120.  ____________________ Jogging on, destination living. |
| WannaBeDude |
 Posted: 21:52 - 21 Nov 2012 Post subject: |
Basically if its fine without, then 132 main is ok with me ... pulls ok - no issues there - so -  ____________________ Jogging on, destination living. |
| WannaBeDude |
| WannaBeDude |
| mentalboy |
| WannaBeDude |
 Posted: 12:54 - 22 Nov 2012 Post subject: |
Think the rings are to help seal pipe to manifold
Am chilled. have asked - before, now and elsewhere, no definitive answer ...  ____________________ Jogging on, destination living. |
| mentalboy |
| WannaBeDude |
| mentalboy |
| WannaBeDude |
 Posted: 15:23 - 22 Nov 2012 Post subject: |
Below pic is a diagram, fits into groove  ____________________ Jogging on, destination living. |
| mentalboy |
 Posted: 19:08 - 22 Nov 2012 Post subject: |
I think you'll just have to keep fighting that ring into place, it looks like it is only a gasket to prevent blowing. It'll make it noisy without and may affect smooth running, I doubt very much if it's the wrong size, sounds like you're not the only one to have grief fighting it into place.
You could try heating pipe to make it expand, best way if you are careful would be to put pipe in place and run up engine. Best way to hold pipe after heat would be to get a solder mat and wrap it round pipe.  ____________________ Make mine a Corona. |
| WannaBeDude |
 Posted: 19:18 - 22 Nov 2012 Post subject: |
A competent person will be doing it in future, so you think come new pipe time, buy some new rings and use them.?
The bike is loud, as the end can is str through, but still has baffles.
Not sure if more noise is present as a result of the missing ring.
Bike was checked as not blowing.
On decoking pipe / all new gaskets were put on using paste, same time was the new can.
As a result of the above, jetting was changed a few times until plug chops were good.
Whilst arrow stated 120 jet for their can, I think they mean their can plus pipe.
So I now believe, new arrow pipe and gaskets, decoke and rejet is the way forward ?
And thanks for your help and time dude !  ____________________ Jogging on, destination living. |
| mentalboy |
 Posted: 19:25 - 22 Nov 2012 Post subject: |
No problems
What is wrong with the current pipe, is it not an Arrow? It may help final max output values but at the end of the day you could end up spending silly money in order to achieve a barely noticeable improvement in performance. ____________________ Make mine a Corona. |
| WannaBeDude |
The last post was made 13 years, 337 days ago. Instead of replying here, would creating a new thread be more useful? |
