bandit 600 fuel system...been butchered..
mysterious_rider
PostPosted: 17:54 - 21 Nov 2012    Post subject: bandit 600 fuel system...been butchered.. Reply with quote
bandit 600 (1996)
Hi guys, been looking over the fuel system on the bandit, and it runs pretty badly.
Looks like there is no vacuum pump thing, there is a thin vacuum tube, and it leads into a nib on the top of ONE of the carbs, the other carbs have the same nib, but are all covered up with rubber caps.
Noticed on ebay I'm missing a vacuum thingymabobby.
is there a diagram on how it's all supposed to go together?
At the moment it takes about a minute of holding the starter button even before the engine wants to start...
cheers
2 litre
PostPosted: 18:28 - 21 Nov 2012    Post subject: Re: bandit 600 fuel system...been butchered.. Reply with quote
mysterious_rider wrote:
bandit 600 (1996)
cheers
Not sure what part you mean, it's sounds right from what you are saying.
mysterious_rider
PostPosted: 18:30 - 21 Nov 2012    Post subject: Reply with quote
basically there are like vacuum feed pump things on ebay, but mines lacking this.
All mine has, is a tube going to ONE of the carbs. Isnt it supposed to split off into four and go to all four carbs? Cheers.
2 litre
PostPosted: 18:31 - 21 Nov 2012    Post subject: Reply with quote
Giz a link, there's only 1 pipe from the tap to one of the carbs.
stonesie
PostPosted: 18:41 - 21 Nov 2012    Post subject: Reply with quote
This, on the bandit I worked on there was 1 vac line from one of the end carbs to the fuel tap, all other vac connections on the carbs were blanked off.
PostPosted: 20:33 - 21 Nov 2012    Post subject: Reply with quote
There are four vacuum take-offs, one on each carb, for balancing the carbs. Three should be capped, the fourth should have a small hose connected to the fuel tap, which provides a vacuum signal and turns on the fuel when the engine is running.
mysterious_rider
PostPosted: 23:14 - 21 Nov 2012    Post subject: Reply with quote
Cheers guys all is perfect then! Does it have to be any carb in particular? At the moment it's on the far right hand side one.
Just looked bodged with the blank off tubes having screws in Rolling Eyes , bike has been running quite badly so ordered new plugs. Will see how it goes. Cool Thanks again.
hazza
PostPosted: 11:02 - 22 Nov 2012    Post subject: Reply with quote
Check the exhaust for leaks. My collector box was leaky and it ran like death.
Harry.
mysterious_rider
PostPosted: 15:29 - 22 Nov 2012    Post subject: Reply with quote
Yeah the exhaust headers are completely fooked. Gotta get a new system for sure!!
Cheers for the info guys, v helpful. Smile
The last post was made 13 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 64.85 Kb
