Is 5000 miles too many between oil changes ?
WULFSTAN
PostPosted: 23:50 - 22 Nov 2012    Post subject: Is 5000 miles too many between oil changes ? Reply with quote
Like the title says really is 5k miles too many between oil changes using cheap oil?
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
PostPosted: 23:56 - 22 Nov 2012    Post subject: Reply with quote
Depends on the bike, usually the point of using cheap oil is to change it more often. That said most bikes are recommended to be changed at 4k, so it rather depends on your machine.
How cheap is cheap?
RichieZX6R
PostPosted: 23:57 - 22 Nov 2012    Post subject: Reply with quote
depends, what do you mean by cheap oil? ON a honda CBR (in your sig i guess) that should be fine for road use.
Manual on my Zx6r says some thing like 6-7k intervals.
Current: Kawazaki ZX6R 51
Past: Kawazaki ZX6R 96 - Honda CBR 600F4 05 - Dragstar 125 02 - Honda CB 400 SF 94 - Honda NSR 125 51 - Gilera Runner XV125 04
Andy_Pagin
PostPosted: 23:58 - 22 Nov 2012    Post subject: Reply with quote
What does the owners handbook say?
WULFSTAN
PostPosted: 00:01 - 23 Nov 2012    Post subject: Reply with quote
https://www.wilkinsonplus.com/car-maintenance/wilko-semi-synthetic-formula-10w-40-motor-oil-5ltr/invt/0257972/?htxt=b95ISHYCs7A2PDQHEfjdpSIRZHoe8Ws%2Fva05Ge0nixg6V3mXXJHckrbYr94z7wswKni6tbYBcIfK%0AVxFigU%2FuCQ%3D%3D That cheap Wink
blurredman
PostPosted: 00:11 - 23 Nov 2012    Post subject: Reply with quote
Depends on the bike. It's safe to say that alot of medium performance bikes (commuters etc) recommend 5-6k, however there are some oddities, like the cx500 which recommend 8k..
Look in the manual
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 52k.
Noxious89123
PostPosted: 00:34 - 23 Nov 2012    Post subject: Reply with quote
Oil and filter is specified at every 8000 miles on my CBR, same as it was on my old CBR. (I don't do anywhere near that milage in a year these days, so I'll be doing it every 12 months instead).
What bikes specify 4k in the owners manual? Shocked Neutral
i.p.phrealy
PostPosted: 00:36 - 23 Nov 2012    Post subject: Reply with quote
cheap chinese 125 i have says 3000 miles, it gets done monthly.
BigDan1190
The older bikes will be fine, back when engines were built to withstand a lot of shit.
PostPosted: 00:45 - 23 Nov 2012    Post subject: Reply with quote
A lot of older bikes had far more frequent oil changes. Eg, CB400N was 1800 miles between oil changes.
.Chris.
PostPosted: 00:55 - 23 Nov 2012    Post subject: Reply with quote
What gave you that impression?
My bike needs an oil change every 2k (or 3k, depending on which manual you read Laughing). It's the same for old cars - 3000 miles used to be a pretty typical oil change interval for pre-80s vehicles. The trade-off is that old cars/bikes don't need (or at least, weren't designed to use) the sophisticated oils that modern engines require. Therefore the oil tends to be cheaper.
Chris
1985 Kawasaki Z550F
Noxious89123
Modern engines are hardly fragile. Think how many people thrash the hell out of their bikes and how few ever blow up. The engineering in a modern engine is a lot more advanced and precise. (With a few exceptions, like the YZF-R125. Quite a few reports of blown up engines a little too often!)
barrkel
PostPosted: 01:10 - 23 Nov 2012    Post subject: Reply with quote
My SH300's oil change light comes on every 4k. Many, if not most, scooters spec fairly low intervals for oil changes. At least the SH300 has an actual oil filter, rather than a screen etc.
PostPosted: 01:13 - 23 Nov 2012    Post subject: Reply with quote
The oil cooled Bandits were (from memory) ~3800 miles for oil changes (ie, 6000km).
Bendy
Mrs Sensible
PostPosted: 09:10 - 23 Nov 2012    Post subject: Reply with quote
My CBR600 did.
My GSXR is 3500 miles. Laughing
esullivan
PostPosted: 09:18 - 23 Nov 2012    Post subject: Reply with quote
I recently bought a Honda NC700S, which specifies a service interval of 8K miles, and I questioned this as well. The dealer said modern engines, especially ones that run at such low revs as this model's, can easily go 8K between oil changes. You're more likely to need a new tire or brake pads in that period, though, which is why they also recommend a quick checkup at 4K.
Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
c-m
PostPosted: 09:27 - 23 Nov 2012    Post subject: Re: Is 5000 miles too many between oil changes ? Reply with quote
Whatever the handbook/owners manual says is correct. The manufacturer knows much better than anyone on here.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
cimbian
PostPosted: 10:34 - 23 Nov 2012    Post subject: Reply with quote
When all else fails RTFM Rolling Eyes
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
DrDonnyBrago
PostPosted: 11:15 - 23 Nov 2012    Post subject: Reply with quote
Bendy wrote:
My CBR600 did.
Unless I am mistaken about the model CBR you had (I thought it was a carb'd, ally framed 600f) then I'm pretty sure that is incorrect.
My 2001 CBR says 8k, Nox's CBR was the same model as you had, and he says 8k.
EDIT: Looking at the F4 service manual also specifies 8k.
Alpha-9
PostPosted: 11:19 - 23 Nov 2012    Post subject: Reply with quote
I do my 125 every 1000 now and it's always black and nasty as fuck
Fzr-600 1999
UnspeedySam
PostPosted: 13:30 - 23 Nov 2012    Post subject: Reply with quote
What oil are you using? I would say 2000 or more is fine.
Bendy
Mrs Sensible
PostPosted: 13:48 - 23 Nov 2012    Post subject: Reply with quote
I never had an official manual for it, but I had a Haynes and I'm sure that said 4, as did the intervals in the service book. I did sell it over 4 years ago mind.
Generally changed the oil more often than that, since I did a lot of trackdays. It would start giving false neutrals when it wanted a change.
goto10
PostPosted: 14:12 - 23 Nov 2012    Post subject: Reply with quote
Totally depends on the age of the bike and the usage - how many heat cycles does the oil go through?
If it takes 3 years to cover 5000 miles (achieved by riding around town) then it's definitely no good.
My NC has done 5000 miles since its last service and the oil is still honey coloured - but I've done those miles within 2 and a half months.
Although doing the same mileage on my ER5 (in the same time frame) would've made the oil black by now and I would definitely be changing it sooner.
PostPosted: 15:32 - 23 Nov 2012    Post subject: Reply with quote
My Explorer has a 12000 mile service interval including oil changes. Fuck that. Sorry Triumph, my lady will be getting new drinkies at 5000 miles at the most.
Triumph Trophy Launch Edition
mysterious_rider
PostPosted: 15:44 - 23 Nov 2012    Post subject: Reply with quote
change mine (zzr600) every 10k miles. That works out about once every 6 months.
The last post was made 13 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 132.77 Kb
