Chain cleaning equipment
Bike Chat Forums Index -> New Bikers via View All Topics
Biker80
PostPosted: 18:07 - 22 Nov 2012    Post subject: Chain cleaning equipment Reply with quote
Any recommended products for cleaning and oiling the chain
How often should you clean it? (chain that is)
J4mes
PostPosted: 18:14 - 22 Nov 2012    Post subject: Reply with quote
I do mine every two tanks of fuel (300-ish miles) and I use Paraffin with a 25mm paint brush which has had the bristles cut right back in order to make it quite stiff.
I use Sdoc100 chain lube Thumbs Up
janner_10
PostPosted: 19:17 - 22 Nov 2012    Post subject: Reply with quote
Don't usually clean the chain at all - just keep it nicely greased with old engine oil every week.
trikeschick
PostPosted: 20:10 - 22 Nov 2012    Post subject: Reply with quote
Castrol chain cleaner and chain lubricant gets my vote Thumbs Up I check mine every week - keep on top of it is the best bet rather than wait until it needs done
"Light travels faster than the speed of sound, which is why some people appear bright until they speak"
Flatbadger
PostPosted: 20:31 - 22 Nov 2012    Post subject: Reply with quote
I just did mine, toothbrush & paraffin, give a good rub with a rag.
Then deisel oil applied through an old toy oil can, perhaps a brush up at the end with a 1/2" paintbrush, nice and cheap!
But this method really needs doing fortnightly at least, if riding around in shitty weather.
You're in ISIS
Slacker24seve...
PostPosted: 20:44 - 22 Nov 2012    Post subject: Reply with quote
This +1.
Paraffin, rags and a toothbrush to clean it. Whatever good, dry chain lube I can get cheap to lube it. Muck-Off is decent and cheapish.
Clean once in a while, lube every 200 miles or so.
Banger rallies are ace
Vracktal
PostPosted: 22:38 - 22 Nov 2012    Post subject: Reply with quote
I use halfords chain lube spray, just keep applying it every two weeks or so, don't really clean the chain though.
fireyphoenix1...
PostPosted: 02:59 - 23 Nov 2012    Post subject: Reply with quote
clean what is this "clean" you people speak of (im into ratbikes Thumbs Up )
i just use an oil can and apply used engine oil too the sprocket while the bikes ticking over in first gear .
The wheel spinning moves oil through the chain from the inside out doing this has always worked well for me and my uncles fif it for 20 + years before me lol
2014 Aprillia dorsoduro 750 factory.
Islander
PostPosted: 09:41 - 23 Nov 2012    Post subject: Reply with quote
A washing up brush and an jar with some diesel or paraffin in it plus a supply of rags to wipe the excess off. Apply the diesel with the brush and work it into the links. Repeat until clean, wipe excess off with rag. Repeat section by section until the entire chain is done. Allow to dry. Apply lube.
I usually put a sheet of cardboard or ply between the chain and the rear wheel to avoid diesel splashing onto the tyre. If you do this inside a garage then you'll need to protect the floor or pressure wash it afterwards. Lay any diesel soaked rags out flat to dry when you're done - they've been known to spontaneously combust if left scrunched up.
DrDonnyBrago
PostPosted: 09:43 - 23 Nov 2012    Post subject: Reply with quote
Paraffin, paint brush and a bowl. Wipe with a rag when done.
The Tot
PostPosted: 00:02 - 28 Nov 2012    Post subject: Reply with quote
Paddock stand, paraffin onto a rag, rotate wheel and wipe.
Dry your chain and apply chainsaw oil onto another rag and then wipe on. 1 litre of chainsaw oil is a fiver.. Wurth Dry lube - god knows how much they cost now, but I've not touched chain lube since I had my tutoro auto chain lube - only recently broke, hence reverting to manually applying chainsaw oil. Old engine oil works just as well.
Never argue with autism
The last post was made 13 years, 105 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> New Bikers via View All Topics All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 67.79 Kb
