| Ribenapigeon |
 Ribenapigeon Super Spammer
 Posted: 13:09 - 23 Nov 2012 Post subject: device to keep wheel alignment when adjusting chain |
Take one wood baton and attach cheap laser pointer to it lengthways with cable ties. Before adjusting chain attach baton to side of rear wheel with the laser pointing rear or forwards again use cable ties. Put bike on paddock stand. Straighten front wheel then switch laser on. Mark point on wall, fence, post etc where the laser hits. Then adjust rear wheel but making sure to keep laser on marked target point.
You can get fancy commercial versions of this but why bother when you can get a laser pointer for under a tenner. I was so chuffed with this idea last night I quickly made up one and tried it on the bike quickly before going to work. Works like a treat. I just lined up with a gatepost opposite my shed but anything would do and the further away the target the more accuratly it will work.
At last an idea that works
Next idea...... Laser filtering gap designator  |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| mrdelmonti |
 mrdelmonti Renault 5 Driver
| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 14:58 - 23 Nov 2012 Post subject: |
Single-sided swingarm or shaft drive also work very well.
Zen Dog ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
| Ribenapigeon |
| nowhere.elysium |
| Teflon-Mike |
 Teflon-Mike tl;dr
| sidewinder |
 sidewinder World Chat Champion
 Posted: 16:20 - 23 Nov 2012 Post subject: |
Good idea in principal but the adjuster marks on the divvy are smack on .found this out when it went in for a mot  ____________________ "Nitrous is like a cheap hooker, you want to hit it but are scared of the consequences |
| illuminateTHE... |
 illuminateTHE... World Chat Champion
| Ribenapigeon |
 Posted: 16:57 - 23 Nov 2012 Post subject: |
Welcome to 2012 Tef surely half the pleasure of bikes is tinkering and fettling? |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 23:39 - 23 Nov 2012 Post subject: |
| Boozehawk wrote: | Welcome to 2012 Tef  surely half the pleasure of bikes is tinkering and fettling? |
| Boozehawk wrote: | String method is a bit iffy plus you need a good amount of space. A laser is also very accurate. |
Oh-Kay... I'll let you go tinker on this one.....
IF you haven't cable tied the lazer on your wood exactly parallel, and or your bit of wood isn;'t perfectly straight edged to the wheel..... when you mark your lazer point, then pull the wheel back, re-aligning to your original mark, could actually 'skew' the rear-wheel alignment by a multiple of any error in the original parallelity....
Think triangles....
Now.. while you very accuratley try and solve that accuracy error.... I'll get a rag, a bit of thiners, and have the job done, by eye, before you have even worked out what I'm talking about!
Remember, I used to be a rocket-scientist..... and something I learned very early on, was you can get in a big mess trying to be TOO clever! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Ribenapigeon |
| pinkyfloyd |
 pinkyfloyd Super Spammer
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 03:52 - 24 Nov 2012 Post subject: |
Think about it Booze, lay your lazer off by say 15 Degrees from parallel to the wheel centre line, mark point, what, 5m ahead of bike on wall, then pull the wheel back 5mm to tighten the chain.
Becouse of the angle of the Lazer, your dot is going to move sideways, WITHOUT turning the rear wheel in the swing-arm.
So, you re-align to your original lazer dot-mark..... and to do so have to twist the wheel in the swing arm AWAY from center!
Lazer is just a convenient means of making a light lever, which is a mechanism for multiplying angles over great distances to magnify differences.
BUT in this case, you are multiplying an error, not an accuracy; hence you will DECREASE the acuracy of alignment, not increase it.
Meanwhile, notoriety of poor alignmement marks is rather spuriouse. They are normally more than accurate enough. Problems tends to be:-
1/ People dont use them
2/ People dont bother cleaning them, SO they can use them
3/ People CANT COUNT!
Or the 'problem' is not with the alignment marks, but elsewhere on the bike.
- Buggered swing-arm bushes, and you alight to the arm, but the arms not straight to teh engine
- Buggered wheel bearings; you alighn axle to swing arm, but sprocket isn;t true to axle.
- Bikes 'Bent', swing arm has been twisted in a spill, or frame is out of alignment.
etc.
For the error possible, they are usually more than 'good-enough'.
Your suggestion, imaginative as it may be, is flawed, and not a solution to the real problem, at the root cause.
If the bikes bent or worn out, doesn't matter how accurateloy you try and align the sprockets, wont help fix the real problem.
If people cant work a simple scale.... then giving them a high-tech light lever system to use more wrongly, wont help that either.
If a high-tech light lever system is too expensive, then increasing tolerence of experimental error, from blue-peter style improvisation, neither helps them alighn sprockets more accuratley, nor more easily, and increases riosk of them getting it even more to cock..... and WORSE convincing themselves it MUST be 'spot on' because they used a 'Lazer'.....
Just been reading about the Long-Bow in the 100 years war.... stone-age technogy that, surviving and out-performing weaponry right up to the advent of cordite... IF used 'properly', and that's the trick to it.
Engineering, 'Technology' is the application of scientific knowledge to solve practical problems; and the GOLDEN rule is, before proposing a solution, be damn sure you know what the problem REALLY is..........
Is the problem that alignment marks are not accurate enough, OR is it that people are too dum or too lazy to use them properly? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Ribenapigeon |
| Matt B |
 Matt B World Chat Champion
| Bomberman |
 Bomberman World Chat Champion
 Posted: 18:24 - 25 Nov 2012 Post subject: |
The last post was made 13 years, 94 days ago. Instead of replying here, would creating a new thread be more useful? |
