device to keep wheel alignment when adjusting chain
Ribenapigeon
PostPosted: 13:09 - 23 Nov 2012    Post subject: device to keep wheel alignment when adjusting chain Reply with quote
Take one wood baton and attach cheap laser pointer to it lengthways with cable ties. Before adjusting chain attach baton to side of rear wheel with the laser pointing rear or forwards again use cable ties. Put bike on paddock stand. Straighten front wheel then switch laser on. Mark point on wall, fence, post etc where the laser hits. Then adjust rear wheel but making sure to keep laser on marked target point.
You can get fancy commercial versions of this but why bother when you can get a laser pointer for under a tenner. I was so chuffed with this idea last night I quickly made up one and tried it on the bike quickly before going to work. Works like a treat. I just lined up with a gatepost opposite my shed but anything would do and the further away the target the more accuratly it will work.
At last an idea that works Smile
Next idea...... Laser filtering gap designator Smile
nowhere.elysium
The Pork Lord
PostPosted: 13:10 - 23 Nov 2012    Post subject: Reply with quote
Alternately, you could use the 'bit of string' method, and save yourself the tenner.
mrdelmonti
PostPosted: 13:50 - 23 Nov 2012    Post subject: Reply with quote
Keep It Simple Stupid
Zen Dog
PostPosted: 14:58 - 23 Nov 2012    Post subject: Reply with quote
Single-sided swingarm or shaft drive also work very well. Very Happy
Zen Dog
Ribenapigeon
PostPosted: 15:53 - 23 Nov 2012    Post subject: Reply with quote
String method is a bit iffy plus you need a good amount of space. A laser is also very accurate.
nowhere.elysium
The Pork Lord
PostPosted: 16:03 - 23 Nov 2012    Post subject: Reply with quote
No it's not, and no you don't. Use a common reference point.
A laser is indeed accurate, although it is something of a sledgehammer to crack a walnut.
Teflon-Mike
tl;dr
PostPosted: 16:10 - 23 Nov 2012    Post subject: Reply with quote
30 years & I have never owned a shaftie or belt drive, yet I have never found anything beyond cleaning the adjuster marks and counting to be necessary Thinking
sidewinder
PostPosted: 16:20 - 23 Nov 2012    Post subject: Reply with quote
Good idea in principal but the adjuster marks on the divvy are smack on .found this out when it went in for a mot Very Happy
illuminateTHE...
PostPosted: 16:28 - 23 Nov 2012    Post subject: Reply with quote
i actually agree with teflon on this one... strange Sick
Theory: PASSED Module 1: PASSED Module 2: PASSED 12/2012!!!
yzf r125 [SOLD] sv650 [CURRENT]
Ribenapigeon
PostPosted: 16:57 - 23 Nov 2012    Post subject: Reply with quote
Welcome to 2012 Tef Smile surely half the pleasure of bikes is tinkering and fettling?
Teflon-Mike
tl;dr
PostPosted: 23:39 - 23 Nov 2012    Post subject: Reply with quote
Oh-Kay... I'll let you go tinker on this one.....
IF you haven't cable tied the lazer on your wood exactly parallel, and or your bit of wood isn;'t perfectly straight edged to the wheel..... when you mark your lazer point, then pull the wheel back, re-aligning to your original mark, could actually 'skew' the rear-wheel alignment by a multiple of any error in the original parallelity....
Think triangles....
Now.. while you very accuratley try and solve that accuracy error.... I'll get a rag, a bit of thiners, and have the job done, by eye, before you have even worked out what I'm talking about!
Remember, I used to be a rocket-scientist..... and something I learned very early on, was you can get in a big mess trying to be TOO clever!
Ribenapigeon
PostPosted: 00:57 - 24 Nov 2012    Post subject: Reply with quote
Its still more accurate than string. Given the tyre is going to be fairkly true in terms of shape and as long as the wooden baton is good and straight then the aim point will be true, mybe not to the 1000th of a mill but good enough and surely better than the markings on the swing arm which going by posts here seem to be notoriously off.
PostPosted: 01:17 - 24 Nov 2012    Post subject: Reply with quote
Alternatively you could draw a little line on your adjuster nuts, say vertically, and keep measure that way, if your lines are both pointing down and you have made the same amount of turns on each nut then your wheel is straight.
Pfft to laser pointers and the likes.
Teflon-Mike
tl;dr
PostPosted: 03:52 - 24 Nov 2012    Post subject: Reply with quote
Think about it Booze, lay your lazer off by say 15 Degrees from parallel to the wheel centre line, mark point, what, 5m ahead of bike on wall, then pull the wheel back 5mm to tighten the chain.
Becouse of the angle of the Lazer, your dot is going to move sideways, WITHOUT turning the rear wheel in the swing-arm.
So, you re-align to your original lazer dot-mark..... and to do so have to twist the wheel in the swing arm AWAY from center!
Lazer is just a convenient means of making a light lever, which is a mechanism for multiplying angles over great distances to magnify differences.
BUT in this case, you are multiplying an error, not an accuracy; hence you will DECREASE the acuracy of alignment, not increase it.
Meanwhile, notoriety of poor alignmement marks is rather spuriouse. They are normally more than accurate enough. Problems tends to be:-
1/ People dont use them
2/ People dont bother cleaning them, SO they can use them
3/ People CANT COUNT!
Or the 'problem' is not with the alignment marks, but elsewhere on the bike.
- Buggered swing-arm bushes, and you alight to the arm, but the arms not straight to teh engine
- Buggered wheel bearings; you alighn axle to swing arm, but sprocket isn;t true to axle.
- Bikes 'Bent', swing arm has been twisted in a spill, or frame is out of alignment.
etc.
For the error possible, they are usually more than 'good-enough'.
Your suggestion, imaginative as it may be, is flawed, and not a solution to the real problem, at the root cause.
If the bikes bent or worn out, doesn't matter how accurateloy you try and align the sprockets, wont help fix the real problem.
If people cant work a simple scale.... then giving them a high-tech light lever system to use more wrongly, wont help that either.
If a high-tech light lever system is too expensive, then increasing tolerence of experimental error, from blue-peter style improvisation, neither helps them alighn sprockets more accuratley, nor more easily, and increases riosk of them getting it even more to cock..... and WORSE convincing themselves it MUST be 'spot on' because they used a 'Lazer'.....
Just been reading about the Long-Bow in the 100 years war.... stone-age technogy that, surviving and out-performing weaponry right up to the advent of cordite... IF used 'properly', and that's the trick to it.
Engineering, 'Technology' is the application of scientific knowledge to solve practical problems; and the GOLDEN rule is, before proposing a solution, be damn sure you know what the problem REALLY is..........
Is the problem that alignment marks are not accurate enough, OR is it that people are too dum or too lazy to use them properly?
Ribenapigeon
PostPosted: 10:47 - 24 Nov 2012    Post subject: Reply with quote
Tef, sure if the laser is at an extreme angle then I would get a leveraged reading that would be at an extreme as well, but for that to happen the wheel would have to be so massivly bent out of shape you need a new wheel not adjustment.
Matt B
PostPosted: 11:24 - 24 Nov 2012    Post subject: Reply with quote
You people obviously have too much time on your hands...
Turn the adjusters one flat at a time each, check alignment marks, tighten it all up, get on bike, go out and ride it!
Bomberman
PostPosted: 18:24 - 25 Nov 2012    Post subject: Reply with quote
Yeah this Thumbs Up Also the amount of bolt sticking out of the nut as a final check for me Thumbs Up
The last post was made 13 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 102.4 Kb
