bandit 600 clutch slipping!
joe.
PostPosted: 14:31 - 25 Nov 2012    Post subject: bandit 600 clutch slipping! Reply with quote
Hi I have recently bought a bandit 600, apparantly it had been tuned although the previous owner had no proof. Open examination I could see a different exhaust system and markings, stamping on the top of the barrel, apparantly some tuners mark the engine after they've rebuilt/tuned it? Anyway the clutch slips upon heavy load throught the gears, I've fitted a new set of standard b6 clutch friction plates and heavy duty springs but still slipping :?help!!
Joe
current: firestorm
previous:gsxr 750, rsv, fz6, xj6, firestorm, bandit 600/825, zx7r, gpz500, gs500, zzr600, xj600, zzr600, cbr 600, xj600, cb500, Kawasaki Gpz500, Aprilia rs125, Suzuki gs 125, Kawasaki gpz 500, Suzuki gt 185, Yamaha dtr 125, Yamaha ybr 125, cagiva mito, Yamaha dtr 125, Honda ns 125, Honda cb 125t, derbi senda, gilera dna, peugoet speedfight, gilera runner, mbk mach G, gilera gsm, derbi gpr, peugeot speedfight, italjet formula, derbi predator. since january 2009.
Bezzer
PostPosted: 15:19 - 25 Nov 2012    Post subject: Reply with quote
Have you altered the cable to give the right free play as well??, too tight and you can get slip. Bandit 600 should have 10-15mm at the lever. If it's too tight on the lever adjuster slacken it off a bit on the clutch end adjuster to give you a bit more to play with at the lever end.
joe.
PostPosted: 15:22 - 25 Nov 2012    Post subject: Reply with quote
Tried that bud, enough free play at both ends of the cable
Joe
current: firestorm
MaybeGuy
PostPosted: 15:25 - 25 Nov 2012    Post subject: Reply with quote
check the steels for warpage
petrolhead69
PostPosted: 16:31 - 25 Nov 2012    Post subject: Reply with quote
you could check the baskets in case the plates have worn grooves into them
joe.
PostPosted: 16:43 - 25 Nov 2012    Post subject: Reply with quote
I'll get a pic and have a look tomorrow, if anyone lives near brum an fancies coming and having a look and a rip round the block there more than welcome
Joe
current: firestorm
joe.
PostPosted: 18:37 - 25 Nov 2012    Post subject: Reply with quote
Vincent wrote:
Joe
Whereabouts in Brum are you?
West heath mate
current: firestorm
joe.
PostPosted: 14:54 - 27 Nov 2012    Post subject: Reply with quote
ok so its got new standard plates, friction and steel, heavy duty springs and it still slips! I am really stumped now, any ideas?
current: firestorm
sickpup
Old Timer
PostPosted: 16:00 - 27 Nov 2012    Post subject: Reply with quote
Yes. You didn't measure the stack height did you.
PostPosted: 16:08 - 27 Nov 2012    Post subject: Reply with quote
Joe
Have you checked the pushrod clearance?
joe.
PostPosted: 18:02 - 27 Nov 2012    Post subject: Reply with quote
Haven't tried either of those Confused
current: firestorm
joe.
PostPosted: 19:42 - 27 Nov 2012    Post subject: Reply with quote
CHR15 wrote:
on the sprocket cover theres a black rubber circle, prize it out gently.
behind it theres a screw and a locknut, hold the screw (with a screwdriver Razz) and undo the nut with a spanner.
wind the nut off a bit. now back the screw out and slowly wind it in again, when you feel some resistance as your winding it in, stop and back it off half a turn. now hold the screw still and do the lock nut up.
see if its still slipping.
Tried that aswell Sad if it is a tuned engine an I've bought a standard clutch would it just not be up to the task?
current: firestorm
MaybeGuy
PostPosted: 19:47 - 27 Nov 2012    Post subject: Reply with quote
Lol, tuned engine... Bandit 6
joe.
PostPosted: 20:30 - 27 Nov 2012    Post subject: Reply with quote
CHR15 wrote:
a b6 clutch will handle more power than you can make even if it was a qualifying engine.
theres something mechanically wrong with it.
have you done what sickpup said?
Oh shit! I hoped it was nothing serious mechanically
Erm how do I do that Embarassed
current: firestorm
PostPosted: 21:05 - 27 Nov 2012    Post subject: Reply with quote
Could be a worn out pressure plate. I've seen that on a couple of bikes - in fact, Bonny's CBR pressure plate was worn out causing the clutch to slip.
sickpup
Old Timer
PostPosted: 22:32 - 27 Nov 2012    Post subject: Reply with quote
Its the stack height of the clutch. Can't remember the correct height of the combined fibres and metals, will be 40something mm iirc +-1.5mm or so. Bandits have 2 different clutch fibre plate thicknesses so you can achieve the correct stack height.
herulach
PostPosted: 22:42 - 27 Nov 2012    Post subject: Reply with quote
Bit of an obvious one - but you have tried changing the oil haven't you? 'Its been tuned' guy might well have shoved it full of magnatec or similar.
YBR 125>FZS600
The last post was made 13 years, 78 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 104.26 Kb
