A few questions from a complete newbie!
SierraWhisky
PostPosted: 19:08 - 26 Nov 2012    Post subject: A few questions from a complete newbie! Reply with quote
Hi guys,
I'm new to the forum and riding, having just completed my CBT and bought a Suzuki GS 125 ESM. I'm wanting to give maintaining my own bike as far as reasonably possible ago, I fancy the challenge! I've ordered the Haynes manual for the bike, but in the mean time I was hoping somebody might be able to answer a question for me:
https://www.dropbox.com/s/idcyhbwxj1wccnj/2012-11-26%2015.55.54.jpg
The link goes to a picture of what I assume is the clutch in the open position (extra fuel going in?!?). When I leave it to idle in this position the bike sits at about 3000rpm. When I close the choke the revs drop down blow 1000rpm and the engine cuts out.
I've tried leaving the engine running with the clutch open for 10 minutes so its warm and then closing the choke, but I still get the same problem.
Any suggestions?
Thanks
SW
Suzuki GS 125 ESM (1996)
Complete and utter novice.... but I will get the hang of this!
snikks
PostPosted: 19:12 - 26 Nov 2012    Post subject: Reply with quote
In the spirit of checking simple things first, is the idle set properly? There's usually a screw of some sort you can twist to make it idle slower or faster, your haynes manual should have details.
If that doesn't seem to help, it may be worth posting it in workshop, as that's where the real mechanics gurus hang out.
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
andy_uk
PostPosted: 19:18 - 26 Nov 2012    Post subject: Reply with quote
Could be a few things...Someone more knowledgeable than me will probably be along shortly, but here are my suggestions :
1) Could be the mixture settings that need looking at
2) Air filter blocked or 'leaking' too much air through
3) Compression could be too low
Can you keep it running by blipping the throttle?
If so, does it ride ok or does it feel underpowered?
//edited to add :
The tickover adjuster is the screw just to the left of where it says "made in Japan" in the photo. Clockwise will increase the tickover.
SierraWhisky
PostPosted: 19:27 - 26 Nov 2012    Post subject: Reply with quote
Thank you for the replies so far!
I'll have a tinker with the screw in the light tomorrow. Like I said, complete novice, is it just a case of making minute adjustments until it'll tickover without stalling?
With the choke closed, I can blip the throttle to keep the engine running, and the bike feels like it's pulling away fine!
Appreciate the help.
SW
andy_uk
PostPosted: 19:42 - 26 Nov 2012    Post subject: Reply with quote
The idle speed (tickover) should be 1,500rpm Smile
SierraWhisky
PostPosted: 19:52 - 26 Nov 2012    Post subject: Reply with quote
Thank you! Is that the idle speed with choke closed? And if so what should it be idling at with choke open?
Sorry for all the questions!
andy_uk
PostPosted: 20:53 - 26 Nov 2012    Post subject: Reply with quote
That's for a fully warmed up engine, with the choke closed.
There's no set figure for while the choke is open.
Best way is to start it up (with choke if needed), have a ride around (close the choke after about a minute, or less if you can) until it's fully warmed up, then adjust the tickover screw until it's at 1,500rpm
Teflon-Mike
tl;dr
PostPosted: 22:13 - 26 Nov 2012    Post subject: Reply with quote
OK, that is a CV carb by the look of it, and that lever thingy on the side you show in pic, looks like the the throttle butterfly, not the choke, or even the clutch - your use of terminology suggests that you didn't quite grasp everything you should have covered in CBT....
CLUTCH: lever on the left hand handle-bar, operates a 'switch' in the transmission, that engages and dissengages drive. More like a 'dimmer-switch' than an on/off switch, you can gain partial drive, teh clutch 'slipping' between fully dissengaged & fully engaged... remember the biting point.
CHOKE: Mechanism for 'enritching' the mixture during cold-start. Name coming from old fasioned method of 'choking' the flow of air into the engine, originally with a hand over the intake, more conventionally via some sort of flap that closes the air-way.
Confusingly, a 'choke' in engineering terms can also be a restriction in a duct, and on some carburettors, such a restriction is fitted inside the carburettor to create a pressure drop and an increase in air-speed to help suck fuel into the air-stream. Most common on slide-less carburettors, such as a webber or delorto, which are often rated by 'choke size'.... but this sort of 'choke' ought not be confused with the enritchement mechanism.
THROTTLE: mechanism for controlling air-flow into the engine, and hence power.
On a conventional slide carb, a slide acts like a port-cullis in the air-way, exposing more or less area for flow, worked directly via a cable that pulls it 'up' to allow more air-flow, and a spring that pulls it back down again.
On your carb, a CV carb, you still have a slide, but instead of being worked directly by cable and spring, its lifted and lowered by a pressure differential above and below a diagphram.
The 'Throttle' as connected to the twist grip on the right hand throttle, works a butterfly valve upstream, by the looks of it, on your carb, which allows a more or less air-flow, and changes the pressure difference upstream and down stream of it, which lifts of lowers the main throttle slide, that self adjusts to maintain a 'constant velocity' of air-flow through the carb and hence a more constant vacuum above the main jet, and hence consistent mixture strength.
NOW, backing up to your 'problem'.....
We need to be clear in terminology here. THAT is the throttle. At idle engine should tick-over about 1500rpm. twist the twist-grip, revs should rise, and rise nice and cleanly, not drop.
If we are not talking about any amomolouse influence of the enritchement system.... then if its ticking over at 3000rpm and revs dropping when the throttle opened.... something is wrong.
And on a CV carb, my first suspicion is that the carburettor diagphram is fucked.
High tick-over is becouse the throttle slide is being lifted by a striong manifold vacuum while the butterfly is closed, but when you open the butterfly, vacuum is lost, and the slide falls.
If this effect is happening without touching the throttle, and is on teh choke, then my suspicion would be that the carb is clogged up, or your fuel contaminated, and the main or idle jet is not letting enough fuel through. Put the chole 'on' it gives enritchement, which comensates for the reduced flow through running jets, as well as any 'cold-start'... turn it off, then the mixture goes weak and idle falls or engine conks out.
My advice?
LEAVE the FUCK ALONE until your Haynes turns up..... or you will be pissing in the wind as like to fuck it up worse than it is now.
THEN, whan manual arrives, follow the instructions to remove the carburettor. Strip the float bowl and clean the jets.
Pay particular heed to any advice around teh CV diagphram. These can sometimes be 'bonded' to the throttle slide, and need to be replaced as a unit, or a seperate and often quite cheap, but effoff delicate part, that can require very stringent diligence to cleaning and assembly, to ensure critical sealing & operation.
On which basis I would leave the diagnphram alone, until I had tested cleaning jets & setting float height, and eliminated the easy stuff to sort!
Then, depending on advice, may need a new diaphragm, or diaphragm/slide assembly, or, depending on cost, a carburetor replacement.
SierraWhisky
PostPosted: 22:22 - 26 Nov 2012    Post subject: Reply with quote
Teflon,
Thanks for the reply!
I think the mix-up in terminology and perhaps in what I'm trying to say is due to a lack of sleep rather a lack of understanding (just come off nights), I hope!
When I've written clutch, I meant choke.
What I'm asking broken down is:
- Is the lever in the picture the choke?
- In the position that the lever is in on the picture, the engine will idle at 3000 rpm.
- If I move the lever 90 degrees downwards (only way it will go) the revs drop and the engine cuts out after approx 5 seconds.
- assuming if this is the choke, do I need to alter the idling speed?
You may have answered this and I've completely missed it, but I'm 30 hours without sleep and still got to stay up for a while longer, so I apologise if I have!
SW
Werny
PostPosted: 23:20 - 26 Nov 2012    Post subject: Reply with quote
- Yes, that is the choke lever
- That is normal for the engine with the choke engaged
- The revs should drop when the choke is disengaged, but not cut out
- Because it does cut out, the first and easiest thing to alter is the idle speed using that adjuster screw just below the choke lever.
What Tef wrote is all valid and useful stuff, but much too much to try as a first case remedy.
SierraWhisky
PostPosted: 23:34 - 26 Nov 2012    Post subject: Reply with quote
Ta muchly!
SierraWhisky
PostPosted: 18:37 - 27 Nov 2012    Post subject: Reply with quote
Ok, so had a play with the screw as suggested, nothing really happened. Decided to ride it to my local bike shop and see what they said, just down the road the bike conks out and won't restart - battery completely flat!
Wheeled the bike to the shop, new battery bought and replaced, and idling speed sorted!
Thanks to everyone for their suggestions!
SW
The last post was made 13 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 79.31 Kb
