| SierraWhisky |
 SierraWhisky Derestricted Danger
 Posted: 19:08 - 26 Nov 2012 Post subject: A few questions from a complete newbie! |
Hi guys,
I'm new to the forum and riding, having just completed my CBT and bought a Suzuki GS 125 ESM. I'm wanting to give maintaining my own bike as far as reasonably possible ago, I fancy the challenge! I've ordered the Haynes manual for the bike, but in the mean time I was hoping somebody might be able to answer a question for me:
https://www.dropbox.com/s/idcyhbwxj1wccnj/2012-11-26%2015.55.54.jpg
The link goes to a picture of what I assume is the clutch in the open position (extra fuel going in?!?). When I leave it to idle in this position the bike sits at about 3000rpm. When I close the choke the revs drop down blow 1000rpm and the engine cuts out.
I've tried leaving the engine running with the clutch open for 10 minutes so its warm and then closing the choke, but I still get the same problem.
Any suggestions?
Thanks
SW ____________________ Suzuki GS 125 ESM (1996)
Complete and utter novice.... but I will get the hang of this! |
| snikks |
 snikks Spanner Monkey
| andy_uk |
 andy_uk World Chat Champion
| SierraWhisky |
| andy_uk |
 Posted: 19:42 - 26 Nov 2012 Post subject: |
The idle speed (tickover) should be 1,500rpm  ____________________ Aprilia Classic 125, GS500E, ER5-A1, ER5-C4, ER6 & an XJ6 project frame... |
| SierraWhisky |
| andy_uk |
| Teflon-Mike |
 Posted: 22:13 - 26 Nov 2012 Post subject: |
OK, that is a CV carb by the look of it, and that lever thingy on the side you show in pic, looks like the the throttle butterfly, not the choke, or even the clutch - your use of terminology suggests that you didn't quite grasp everything you should have covered in CBT....
CLUTCH: lever on the left hand handle-bar, operates a 'switch' in the transmission, that engages and dissengages drive. More like a 'dimmer-switch' than an on/off switch, you can gain partial drive, teh clutch 'slipping' between fully dissengaged & fully engaged... remember the biting point.
CHOKE: Mechanism for 'enritching' the mixture during cold-start. Name coming from old fasioned method of 'choking' the flow of air into the engine, originally with a hand over the intake, more conventionally via some sort of flap that closes the air-way.
Confusingly, a 'choke' in engineering terms can also be a restriction in a duct, and on some carburettors, such a restriction is fitted inside the carburettor to create a pressure drop and an increase in air-speed to help suck fuel into the air-stream. Most common on slide-less carburettors, such as a webber or delorto, which are often rated by 'choke size'.... but this sort of 'choke' ought not be confused with the enritchement mechanism.
THROTTLE: mechanism for controlling air-flow into the engine, and hence power.
On a conventional slide carb, a slide acts like a port-cullis in the air-way, exposing more or less area for flow, worked directly via a cable that pulls it 'up' to allow more air-flow, and a spring that pulls it back down again.
On your carb, a CV carb, you still have a slide, but instead of being worked directly by cable and spring, its lifted and lowered by a pressure differential above and below a diagphram.
The 'Throttle' as connected to the twist grip on the right hand throttle, works a butterfly valve upstream, by the looks of it, on your carb, which allows a more or less air-flow, and changes the pressure difference upstream and down stream of it, which lifts of lowers the main throttle slide, that self adjusts to maintain a 'constant velocity' of air-flow through the carb and hence a more constant vacuum above the main jet, and hence consistent mixture strength.
NOW, backing up to your 'problem'.....
| Quote: | what I assume is the clutch in the open position (extra fuel going in?!?). When I leave it to idle in this position the bike sits at about 3000rpm. When I close the choke the revs drop down blow 1000rpm and the engine cuts out. |
We need to be clear in terminology here. THAT is the throttle. At idle engine should tick-over about 1500rpm. twist the twist-grip, revs should rise, and rise nice and cleanly, not drop.
If we are not talking about any amomolouse influence of the enritchement system.... then if its ticking over at 3000rpm and revs dropping when the throttle opened.... something is wrong.
And on a CV carb, my first suspicion is that the carburettor diagphram is fucked.
High tick-over is becouse the throttle slide is being lifted by a striong manifold vacuum while the butterfly is closed, but when you open the butterfly, vacuum is lost, and the slide falls.
If this effect is happening without touching the throttle, and is on teh choke, then my suspicion would be that the carb is clogged up, or your fuel contaminated, and the main or idle jet is not letting enough fuel through. Put the chole 'on' it gives enritchement, which comensates for the reduced flow through running jets, as well as any 'cold-start'... turn it off, then the mixture goes weak and idle falls or engine conks out.
My advice?
LEAVE the FUCK ALONE until your Haynes turns up..... or you will be pissing in the wind as like to fuck it up worse than it is now.
THEN, whan manual arrives, follow the instructions to remove the carburettor. Strip the float bowl and clean the jets.
Pay particular heed to any advice around teh CV diagphram. These can sometimes be 'bonded' to the throttle slide, and need to be replaced as a unit, or a seperate and often quite cheap, but effoff delicate part, that can require very stringent diligence to cleaning and assembly, to ensure critical sealing & operation.
On which basis I would leave the diagnphram alone, until I had tested cleaning jets & setting float height, and eliminated the easy stuff to sort!
Then, depending on advice, may need a new diaphragm, or diaphragm/slide assembly, or, depending on cost, a carburetor replacement. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| SierraWhisky |
| Werny |
 Werny Traffic Copper
| SierraWhisky |
| SierraWhisky |
The last post was made 13 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
