dropping tyre pressure to aid winter riding
tsmith
PostPosted: 11:26 - 02 Dec 2012    Post subject: dropping tyre pressure to aid winter riding Reply with quote
Just dropped the tyre pressures on my GPZ500 from 32/36 to 28/32 to aid winter riding
Anyone else tried this? Did it help?
Walloper
PostPosted: 11:42 - 02 Dec 2012    Post subject: Re: dropping tyre pressure to aid winter riding Reply with quote
I don't know if it will help as the tyre will flex more.
I would not go more than 3-4 PSI under recomended though in any case.
Dropping tyre pressure to ultra-low will help if you are balloxed in soft sand, snow or a bowl of cold, thick custard.
It's strange that bikers spend silly money on tyres compared to cars mile for mile but tyre manufacturers have no answer for cold roads.
I think they are pressuring car owners with those 'winter' tyres (with SIPS) purely as marketing and sales gimmick more than for road safety.
In colder countries like Sweden Norway insurance may not pay out on claims for vehicles that had the wrong winter tyre spec fitted.. Shocked
Kind of makes you think it's not long till the fannies that are the EU declare war on us Brits and force us to comply in the interests of 'safety'.
I think better driving standards are all we need in most parts of UK not different tyres.
If you're concerned about it you may try a softer compound for winter to help the tyre conform in cold weather. I won't bother my arse as I have never noticed it as much of a muchness and feel wet salty roads are the problem more than cold frosty roads.
PostPosted: 11:52 - 02 Dec 2012    Post subject: Reply with quote
Let me guess...Lower pressure = bigger contact patch and heats up quicker?
Stick with the manufacturers figures. If they thought the bike would handle better with lower pressures in winter they'd mention it.
I lowered mine to get my roadbike out of a muddy wood.
Also consider that less psi = lower carrying weight...Oh, and the crappy handling.
PostPosted: 13:49 - 02 Dec 2012    Post subject: Reply with quote
They will get hotter, as I found out when I had a leaky valve on my 305 and only the hot rubber smell clued me in.
As to handling, I haven't noticed any difference, or at least not an improvement. But then I'm running a combination of Whatever Was On It on the front and Whatever Was Cheapest on the rear. I'd imagine picking the right rubber is going to do you a lot more good than fiddling with the pressure.
Torque Wrench
PostPosted: 03:32 - 21 Dec 2012    Post subject: Reply with quote
Reducing Tyre Pressure = More contact area between tyre and tarmac which in turn will increase friction, heat. The increase in friction and contact area will improve grip.The increase in friction will also result in a higher heat cycle through the tire which in turn will impact on the life of your tyres; fuel consumpsion will also suffer as you will after overcome the increase in friction produced between the two mating pairs (tyre and tarmac). It will impact on handling, making for a more sluggish response, you may notice an increase in effort is required to turn the bars.
Coeff for tyre(Rubber) and tarmac is around 0.9 - 1.0
Coeff for tyre and Ice is around 0.15 - 0.18
Islander
PostPosted: 09:41 - 21 Dec 2012    Post subject: Re: dropping tyre pressure to aid winter riding Reply with quote
Winter tyres on a car do make a massive amount of difference. They aren't a panacea for poor driving skills but if you know how to drive in snow and ice anyway they really do give you an edge. I have a set that I get fitted every year. Last year I spent hogmanay down in the central glens with deep snow and ice and didn't have a single problem whereas locals with normal tyres were getting stuck.
I'd completely agree with the need for better driving standards though.
PostPosted: 10:08 - 21 Dec 2012    Post subject: Re: dropping tyre pressure to aid winter riding Reply with quote
I have found tyre pressures drop all by themselves in winter (colder so denser air?)
I've had to pump mine up. I have never felt to need to lower them.
Slacker24seve...
PostPosted: 10:17 - 21 Dec 2012    Post subject: Re: dropping tyre pressure to aid winter riding Reply with quote
My instructor actually took me out in thick snow and got me to deliberately get the car to slide and showed me how to deal with it. Best driving lesson ever!!!
Banger rallies are ace
Matt B
PostPosted: 10:24 - 21 Dec 2012    Post subject: Reply with quote
Dunlop say:
"Under-inflated tyres can result in imprecise cornering, higher running temperatures and overheating cracks, irregular tread wear at the edge of the contact patch, fatigue cracking, overstressing and eventual failure of the tyre carcass. Over-inflating tyres does not increase load-carrying capacity, but will result in a hard ride and accelerated tyre wear in the centre of the contact patch."
I wouldn't change for winter riding, I adjust my riding style not the tyre pressure.
Slacker24seve...
PostPosted: 11:34 - 21 Dec 2012    Post subject: Reply with quote
Actually by default I run 34/36 rather that 36/42 as it does get more heat in them. Owners forums are full of that sort of information. I remember getting told in a novices trackday briefing that the recommended pressures are for litigation purposes, ie 2-up at max speed, rather than for outright grip.
Walloper
PostPosted: 13:46 - 21 Dec 2012    Post subject: Reply with quote
Wot's that smell?
Very Happy
They told you wrong.
The tyre manufacturer gives tyre pressure based on performance from testing.
For the road the pressures will be correct. It won't affect performance that much in everyday use to be +- 3PSI though.
I round up/down the Bike OEM's figures for arithmetic sake +-1PSI
Or just set to the average between the loaded and unloaded figures. 42 instead of 44 loaded or 40 un-loaded.
I never have any issue concerning grip on the road. Bikes are rarely pushed to the limit of the tyre on the road. Unless you are a nutter. Smile
-1PSI may noticeably affect MPG (over hundreds of miles) and I would imagine setting the tyre to the top limit would provide the least rolling resistance but hee-haw grip.
Turkish
PostPosted: 21:26 - 21 Dec 2012    Post subject: Reply with quote
No. To pretty much everything in your post.
F = uN.
Which part of that equation relates to surface area? Oh that's right; none of it.
Yes, the contact patch will increase, but it means nothing because the normal reaction force and coefficient of friction remain unchanged.
Moreover, the handling of the bike will suffer and would be far more danerous than any peceived benefit from this mod. Do yourself a favour and set it up the way the designers intended.
ZX-6R G2
CBR125R RW6
oldenuff
PostPosted: 21:33 - 21 Dec 2012    Post subject: Elementary mechanics Reply with quote
Friction is independent of surface area. The only thing that a larger surface area does is to provide a bigger pathway to conduct away any heat generated.
barrkel
PostPosted: 21:47 - 21 Dec 2012    Post subject: Reply with quote
Larger surface area also reduces wear rate (or rather, spreads the wear over a larger area, so you don't e.g. end up with a heavily worn bit right in the middle so soon).
Of course friction is itself just an approximation of stochastic processes at a lower level. If you are torquing the rubber so hard that it is physically coming apart, having more in contact with the road may help.
Torque Wrench
PostPosted: 21:48 - 21 Dec 2012    Post subject: Reply with quote
@Turkish
I don't need a lesson in Engineering from a kid on CBR125R.
PostPosted: 21:54 - 21 Dec 2012    Post subject: Reply with quote
No point in dropping your pressures in winter in conclusion. It'll just make it more dodgey IMO.
Stick with what the manufacturer recommends. IME that gives you more than enough grip.
johnsmith222
PostPosted: 22:06 - 21 Dec 2012    Post subject: Reply with quote
Can anyone confirm this?
I remember that some michelin tyres were succeptible to cupping and the advice was to ensure that tyre pressures were checked regularly to ensure that there was enough pressure in the tyre and prevent this from occurring as significantly.
@Turkish
What does his bike have anything to do with it?
covent.gardens
World Clap Champion
@Turkish
I'm not a physicist and can't tell which one of you is right, but seeing as you've resorted to insulting him as your only form of reply, my money is on him. Laughing
Torque Wrench
PostPosted: 22:16 - 21 Dec 2012    Post subject: Reply with quote
@Turkish
So reducing tyre pressure will not result in further drag which in turn increases load on the engine increasing fuel consumpion
Contact patch will increase as will drag which will mean areas of the tyre will see higher heat cycles, resulting in accelerated tyre wear.
This is dynamic remember not static.
Torque Wrench
PostPosted: 22:32 - 21 Dec 2012    Post subject: Reply with quote
The tyre will change shape when the wheel rotates, lower tyre pressure will cause the edges of the tyre to drag.
Walloper
PostPosted: 22:39 - 21 Dec 2012    Post subject: Re: dropping tyre pressure to aid winter riding Reply with quote
Sorry I have watched the evidence and they certainly do help traction. What I am getting at is: For the few days of 'winter' roads we get in the more tropical parts of the UK Winter Tyres are a bit of a luxury. The only 'tests' I have seen are on ice/snow I have not seen any tests on 'cold' roads. And as has been said drive to the conditions and you can easily get around safely.
Perhaps like body armour in bike gear and comfort in cars we would get the 'Gladiator Effect' and think we were driving Gods shod with winter tyres. Smile
Turkish
PostPosted: 11:23 - 22 Dec 2012    Post subject: Reply with quote
@Turkish
Rolling resistance will increase but this wont translate to any useable grip on the surface - as you say the force is deforming the tyre, that is the work it is doing.
The rolling resistance is a vector quantity in the direction of wheel rotation. It wont help lateral grip at all, which is arguably the only mechanism in which you can end up binning a bike.
ZX-6R G2
CBR125R RW6
lozzypop1
Certified MILF!
PostPosted: 12:00 - 22 Dec 2012    Post subject: Reply with quote
@Turkish
So there you have it kids.. It's all about the sideways-lateral-torsional-force! Thumbs UpTwisted Evil
wilz1234
PostPosted: 12:04 - 22 Dec 2012    Post subject: Reply with quote
Why do people think that increasing the size of contact patch will help. Certainly for mud/sand it will, but on ice....no.
Whats gripper on ice/snow, knobbly tires or slicks? The lower the contact patch, the more it presses into the ice
RS50 - ZXR400 - ZXR 400 - ZX7R - Bandit 600 - NTV 650
The last post was made 13 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 135.69 Kb
