| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 13:28 - 03 Dec 2012 Post subject: Car issue - over revving when changing gear |
Mk1 Ford focus 1.8 petrol, year 2000, 55k miles.
Right, annoying thing the car does when accelerating is that when you press the clutch to change up, the engine continues to rev for a bit. It's like the accelerator is being depressed for a fraction of a second longer than it actually is. Letting off the accelerator earlier before depressing clutch and it doesn't happen, just dipping the clutch without accelerating and it doesn't happen.
It also occasionally stalls immediately after starting on some cold days, but starts up fine the second time around. Not sure if these are related.
It's more annoying than anything, also makes smooth and fast gear changes tricky as it blips the throttle on upshifts .
Checked for leaking inlet by spraying stuff around it, didn't pick up. Was thinking perhaps a sticking throttle body/accelerator mechanism but thought to ask first in case anyone has seen similar. |
| lukamon |
 lukamon World Chat Champion
| Aff |
 Aff World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 14:24 - 03 Dec 2012 Post subject: |
Butterfly valve and check the MAF sensor  |
| DrDonnyBrago |
 Posted: 15:30 - 03 Dec 2012 Post subject: |
Cheers chums . |
| MarkJ |
 MarkJ World Chat Champion
| stuarthouston |
 stuarthouston Trackday Trickster
| Acemastr |
 Acemastr World Chat Champion
| DrDonnyBrago |
| Aff |
| Chalky. |
 Chalky. World Chat Champion
 Posted: 17:55 - 03 Dec 2012 Post subject: |
Idle Control Valve is a common problem on these, it's located on the front of the engine.
Clean with carb cleaner.  |
| i.p.phrealy |
 i.p.phrealy World Chat Champion
| geordiecbrblo... |
 geordiecbrblo... Trackday Trickster
The last post was made 13 years, 333 days ago. Instead of replying here, would creating a new thread be more useful? |
