FFS MY BIKE WON'T START!!!
DottyDuck
PostPosted: 16:26 - 02 Dec 2012    Post subject: FFS MY BIKE WON'T START!!! Reply with quote
ok... so my bike wont start... ive had the choke on full. half and off tried it but its just not starting! my bike is blimming new i thought buying new would mean it would be reliable! maybe the cold weather had a part to play! i dont know im just frustrated!
doggone
PostPosted: 16:43 - 02 Dec 2012    Post subject: Reply with quote
Has someone nicked your petrol? Razz
Bung it on charge if you can.
DottyDuck
PostPosted: 16:46 - 02 Dec 2012    Post subject: Reply with quote
my petrol tank is full!! lol i think my bike is on strike!! erm.... how do i charge my bike? :O
stoke-gaz
PostPosted: 16:53 - 02 Dec 2012    Post subject: Reply with quote
Battery charger!
Is the fuel tap turned on?
Does the starter motor turn?
Does it have a spark?
Gaz.
Ex: GZ125HS, Current: Yamaha xv535 virago, Suzuki GSF600.
CBT: passed 30/09/2012 Theory: passed 02/02/2013 MOD 1: 27/03/2013 MOD 2: 18/04/2013.......CAT A LICENCE IS MINE!!!!
Paddy Blake
PostPosted: 16:55 - 02 Dec 2012    Post subject: Reply with quote
What bike is it.?
Islander
PostPosted: 17:05 - 02 Dec 2012    Post subject: Reply with quote
Don't forget to check your kill switch as well, Smile
TomGT
PostPosted: 17:09 - 02 Dec 2012    Post subject: Reply with quote
you don't know how to start it. Not a bad thing, I'm still learning how to start the CBR. If you are using the choke don't touch the throttle, starter and a bit of throttle to start it works for me, then throttle off and adjust the choke.
Jump starting will do you a favour, as you haven't got a flat battery to worry about Smile
1992 ZXR 400
sidewinder
PostPosted: 17:10 - 02 Dec 2012    Post subject: Reply with quote
+1 for kill switch
DottyDuck
PostPosted: 17:41 - 02 Dec 2012    Post subject: Reply with quote
my bike is a zontes panther Smile
yes fuel tap is on
does the starter motor turn? erm i think so.. it makes a noise like it wants to start but when i rev it .. like it doesn's start like normal... (if that makes sense)
i have sometimes started it with the kickstart but today it was having none of it!
and my bike doesn't have a kill switch either lol
J.M.
PostPosted: 17:44 - 02 Dec 2012    Post subject: Reply with quote
sidewinder wrote:
+1 for kill switch
Another +1 for this.
I tried bump starting my bike the other day. Ran half way down the street with it almost starting and cutting out before I noticed the kill switch -.-
2004 R1 & 2018 XSR900
DottyDuck
PostPosted: 17:59 - 02 Dec 2012    Post subject: Reply with quote
p.s how do i recharge the battery? Embarassed
Efes123
PostPosted: 18:03 - 02 Dec 2012    Post subject: Reply with quote
You are joking, right? Shocked
Take battery off bike, get a 13 amp plug with some wire on it, strip the ends off and attach them to the terminals on the battery Thumbs Up
Disclaimer: any explosions, fires, or other damage caused by this is not my fault.
NB: Don't really do this, take battery off bike and attach what's commonly known as a battery charger to it and leave overnight.
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
i.p.phrealy
PostPosted: 18:16 - 02 Dec 2012    Post subject: Reply with quote
also it sounds like you've flooded it. if it hasn't started after 10 seconds, leave it 30 seconds before starting again. also check your side stand, the bike shouldn't start with that down.
Islander
PostPosted: 18:23 - 02 Dec 2012    Post subject: Reply with quote
+1 apart from the side stand. It should start with that down as long as it's in neutral - unless you've got a fault in the sidestand/clutch switch circuit of course...
If you've flooded it then whip the plug out, close the choke and throttle and spin it over a few times - it'll clear the excess fuel out of the cylinder. Thumbs Up
recman
PostPosted: 18:25 - 02 Dec 2012    Post subject: Reply with quote
J.M. wrote:
sidewinder wrote:
+1 for kill switch
lol.
_Troy_
+1 for it being flooded. Using full choke a lot, and revving it, will quickly flood the ending with fuel.
Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650
DottyDuck
PostPosted: 23:53 - 02 Dec 2012    Post subject: Reply with quote
i will try again tomorrow and let you know what happens... if it doesnt start then i think i may scream ... so if you hear a scream tomorrow.. it will be me! grhh!!!!! lol
bikertomm
PostPosted: 09:54 - 03 Dec 2012    Post subject: Re: FFS MY BIKE WON'T START!!! Reply with quote
https://media.steampowered.com/steamcommunity/public/images/avatars/8e/8ea58107c90eea3b283b40f46d260d93da62093c_full.jpg
PostPosted: 10:06 - 03 Dec 2012    Post subject: Reply with quote
Rogerborg already done wrote:
Voltmeter on the battery, charge it up, if it's still under-volting, that's a problem for the dealer.
Buy a Chinese bike and your first purchase should be a multimeter. It takes all the guesswork out of it.
You can get one delivered for under £5, or find them in Argos, Halfrauds, B&Q or Maplin. They will also provide a battery charger, as will any bike shop. Make sure that you get one suitable for motorcycle use, with a charge rate no higher than 1 amp (500 mA is safer, you'll have a small battery).
YouTube will provide HowTo videos.
Your "new" bike could have been sitting around for months with its battery slowly draining before you rode it away. It might never have been properly charged.
I keep my batteries on trickle charge constantly. You can buy a 12v power socket for a few £££ which you can attach to the battery and which will let you plug in a charger without even getting access to the battery. I have a solar charger on my GPZ that I keep permanently attacked and tucked in the transparent pocket on my tank bag.
Zen Dog
PostPosted: 15:17 - 03 Dec 2012    Post subject: Reply with quote
https://www.zontes.co.uk/index.php/panther
Zontes wrote:
As with all Zontes 125 engines, they utlising the overhead cam and counterbalanaced crackshaft which delivers smooth power great economy.
Maybe its the crackshaft? Shocked
Zen Dog
Shinigami
PostPosted: 15:40 - 03 Dec 2012    Post subject: Reply with quote
makes the engine more frantic does a bit of crack
bikertomm
PostPosted: 16:09 - 03 Dec 2012    Post subject: Reply with quote
Zen Dog
Good lord, have they never heard of spellchecker.. I can see words spelt wrong on every page.
DottyDuck
PostPosted: 16:21 - 03 Dec 2012    Post subject: Reply with quote
omg omg omg OMG!!! whooopppppaaa!! Mr Zonty worked today! <3 he is back in my good books.. what a babe! thanks for all the feedback Smile i will just put it down to teething problems!
ADSrox0r
PostPosted: 18:02 - 03 Dec 2012    Post subject: Reply with quote
<looks into crystal ball>
I see.....I see....another thread, just like this one....in the not too distant future....
cromwell
PostPosted: 18:09 - 03 Dec 2012    Post subject: Reply with quote
+1
Make sure it's in neutral, clutch in etc depending on model.
"unbelievable"
Current - Suzuki Bandit 600
Ex's - Yamaha YBR 125
The last post was made 13 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.72 - MySQL Queries: 13 - Page Size: 127.67 Kb
