Causes of gearbox whine
hazza
PostPosted: 12:37 - 04 Dec 2012    Post subject: Causes of gearbox whine Reply with quote
Bandit 600 '98 36,000 miles.
It's always had a bit of a whine in second and it seems to be contagious and has spread to first. Ive been riding it with no noticable difference in sound for the last 10k. Im due an oil change (well 1500 past actually but have been mega busy) But what is the likley cause?
I NEED the bike so if its terminal i will just drop a second hand lump in if needs be for quickness.
Ta,
Harry
Aff
PostPosted: 12:44 - 04 Dec 2012    Post subject: Reply with quote
Original front sprocket?
Is the chain too tight?
Electric Bike Project
babybiker
PostPosted: 13:06 - 04 Dec 2012    Post subject: gearbox Reply with quote
Hi,
if it is only in two gears it is unlikely to be the output bearing.Possibility of your actual gears being worn is more likely as first and second get more of a hammering than higher cogs.My own GSX750f has dogged in second gear (the gear has actually broken) and while searching for a box have found a few more including GSXR's with same problem.
regards,ron
hazza
PostPosted: 13:08 - 04 Dec 2012    Post subject: Reply with quote
Chain is tensioned correctly. Unsure of sprocket but i did buy a new one to change as a matter of course. It's a crap excuse but i have been ridiculously busy over the last 6 months with work and making my house livable and really havent had the time to replace it yet! May drop teh oil and change the front sprocket over the weekend....
Can the sprocket be a cause of noise then?
Ta,
Harry.
Aff
PostPosted: 14:24 - 04 Dec 2012    Post subject: Reply with quote
I know that some OEM sprockets have a rubber vibration/noise damper built in. No sure if is rubbish though, and not sure what noise it would make if you didn't have it and should (if any).
Ja7
PostPosted: 19:36 - 04 Dec 2012    Post subject: Reply with quote
I had it on a diversion I had forth, used to not use the gear annoying noise it spread to fifth but sold on, sorry new owner I did tell him, I've got it on my bandit now on fifth gear its bearable at mo, hardly use fifth gear these days only on motorways, live in town, I'm aware that anything gearbox related ie new gears, bearings need engine split to get at them, correct me if I'm wrong, new engine might be a good idea if it annoys you that much, or if your willing to split engine..
The last post was made 13 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 48.31 Kb
