Yamaha Diversion 600 heated grips
sickpup
Old Timer
PostPosted: 19:42 - 05 Dec 2012    Post subject: Yamaha Diversion 600 heated grips Reply with quote
Just tried to fit heated grips to Recluso's bike and discovered that it has extemely narrow grips. The bars are the standard 22mm wide but the grips are only 118mm long not the standard 125/130 which with the addition of Yamaha bar ends which can't be spaced out means that normal heated grips won't fit.
I've seen the Oxford Hot Grips Premium touring which can be cut down to 114mm but at £75 they are a bit on the pricey side.
So does anyone have a recommendation of heated grips that will actually fit and allow you to retain the OEM bar ends?
PostPosted: 19:55 - 05 Dec 2012    Post subject: Reply with quote
Yes. Symtec under grip heaters stick to the bar itself. Put the original grips back over them.
They work well had them on Mrs. stinkwheels CB500 for a couple of years now. I can't hang on to them for long with them on high but she thinks they're fantastic and they prevent her Reynolds syndrome being triggered.
The cheapo Chinese copies don't work very well, I'm going to replace mine with Symtec ones. Although in fairness, the time consuming bit was the wiring for them, the grips are easily changed over and it was worth a £4 gamble.
sickpup
Old Timer
PostPosted: 20:06 - 05 Dec 2012    Post subject: Reply with quote
But are they short enough?
Charlie
PostPosted: 21:26 - 05 Dec 2012    Post subject: Reply with quote
I've cut down my Oxford essential grips as they won't fit with my Barkbusters on. They look a bit tatty mind and thinking about it I haven't tested it yet. Partly because the control unit is hidden under my muffs.
While cutting I didn't see any evidence that I cut any tracks/heating element wiring.
scarborough_lad
PostPosted: 21:42 - 05 Dec 2012    Post subject: Reply with quote
I had to use and find) a counter-sunk screw of a weird size when I fitted mine.Probably why I didn't bother and don't have bar ends, what's the worst that can happen!
'96 Suzuki GS500
mgh0
PostPosted: 22:08 - 05 Dec 2012    Post subject: Reply with quote
What year Diversion?
I fitted R&G grips to my '95 Diversion with no problems at all.
"Courage is not defined by those who fought and did not fall, it is defined by those who fell and rose to fight again." Adrienne Rich.
PostPosted: 22:18 - 05 Dec 2012    Post subject: Reply with quote
I'll measure mine in the morning, it feels like my hands are too big for the grips so possibly the same size.
Will answer tomorrow Thumbs Up
sickpup
Old Timer
PostPosted: 22:46 - 05 Dec 2012    Post subject: Reply with quote
Its a 12 reg diversion, the new model. The earlier model used 130mm grips.
PostPosted: 23:51 - 05 Dec 2012    Post subject: Re: Yamaha Diversion 600 heated grips Reply with quote
Whaaaa? Do I need to update my personnel records? Eh?
Really bargain basement £5-delivered-from-China heating elements worked OK on my 125. It's just two resistor sheets (which from memory will be narrow enough), wiring, on/off switch and some heat shrink covers. The whole lot goes over the grips, takes a few minutes to fit, and the heat gets straight to your hands. What's not to like?
PostPosted: 02:11 - 06 Dec 2012    Post subject: Reply with quote
I see nothing at all preventing you from fitting them up to and even under the switchgear (although I wouldn't make a hole for a rowlpin through them).
Recluso
PostPosted: 13:08 - 07 Dec 2012    Post subject: Reply with quote
So far all I've found regarding the grip size is:
a. Implication that Oxford grips were used and cut down
b. Use the R&G racing ones recommended for the model (which have had reasonable reviews).
Have found loads of the 2009 - 2012 range for sale and all with heated grips. They just don't bloody say which grips they are!!
'Just erotic. Nothing kinky. It's the difference between using a feather and using a chicken.'
Honda PS125i > Yamaha YBR125 > Yamaha XJ6 Diversion > Yamaha Tracer 900
PostPosted: 13:10 - 07 Dec 2012    Post subject: Reply with quote
Sorry, completely skipped my mind!
Mine are 130mm sorry. Daytona grips.
The last post was made 13 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 72.94 Kb
