Sidebox mounts and the strength of bolts.
c_dug
PostPosted: 14:09 - 13 Dec 2012    Post subject: Sidebox mounts and the strength of bolts. Reply with quote
I have the top box rack fitted to my divvy and have the d rails for mounting the side boxes, however the mounting bolts were lost by a previous owner.
The d rails need to be mounted about 10cm from the rack to clear the bodywork of the bike so i was thinking about knocking something together with some bolts from b&q but I'm unsure if they would be strong enough to support the weight of a full box?
The bolts will have a diameter of around 8cm and as before the space between the rack and the d rails will need to be about 10cm. There will be 2 bolts to each sidebox. The sideboxes are around 40l which I'd guess if packed with heavy stuff would weigh a maximum of 30kg.
Are the bolts likely to snap or bend with that kind of weight plus the force generated by the bike being ridden?
The boxes and rails are made by nonfango, who went bust a few years ago, so buying replacement parts is near impossible.
Thanks
Nope.
PostPosted: 14:19 - 13 Dec 2012    Post subject: Reply with quote
The bolts will likely be fine, just make sure to either use locking nuts or thread lock as you don't want them vibrating out in the fast lane of the motorway!
PostPosted: 14:48 - 13 Dec 2012    Post subject: Reply with quote
The bolt isn't actually supporting the weight. It's just holding the box and the rail together firmly enough so they behave like a solid piece of metal where they touch.
Your footpegs are probably held on with two M8 bolts.
Get a couple of decent ones bolts. I personally would use mild steel ones of grade 8,8 with either spring washers, double nuts or a nylok nut. Although in theory, if you do it up to 19ft/lb with a plain nut, it shouldn't come undone anyway.
You could make a spacer by drilling the middle out of a couple of plain nuts.
c_dug
PostPosted: 15:14 - 13 Dec 2012    Post subject: Reply with quote
Nope, on mine the weight will be going directly through the bolts and nothing else, there are two styles of racking used on the xj and on mine the top box rack follows under the line of the tail end body work meaning the side box brackets need to be supported away from the main rack to allow room for the boxes to fit.
Mine rack is the same as the one on this bike (but not in red!), you can just about make out the mounts on this bike. https://www.ebay.co.uk/itm/YAMAHA-XJ-900-DIVERSION-/190766845595?pt=UK_Motorcycles&hash=item2c6a970e9b
Hopefully you can see what I mean about there being a distance between the main rack and the sidebox mounts.
sickpup
Old Timer
PostPosted: 18:04 - 13 Dec 2012    Post subject: Reply with quote
Have you noticed the bracket between the 'u' pieces and the rear of the grab rails?
woll
PostPosted: 19:29 - 13 Dec 2012    Post subject: Reply with quote
Just a normal pair of 8.8 tensile bolts will do the job. You'd be suprised how much they're used.
c_dug
PostPosted: 22:19 - 13 Dec 2012    Post subject: Reply with quote
Thanks sickpup, hadn't seen that.
bladerunner
PostPosted: 04:05 - 14 Dec 2012    Post subject: Reply with quote
If your worried about tensile strength...
Buy some 10.2 bolts...a much stronger high tensile grade. B and Q will be cheap spec 8.8 at best but even these with proper mountings should be fine if no gaps between the parts they hold.... B and Q will not be the cheap option if you look up an engineering supply shop or trade centre close to you.
reckless_b
PostPosted: 20:38 - 14 Dec 2012    Post subject: Reply with quote
check the advised loading for the panniers, stick to that and you could probably get away with number plate screws, seriously though 8.8 spec bolts will be fine the shear load is way above what you will need.
40 years on the road on and sometimes off bikes with a very recent OFF
There is a gap of 1 year, 137 days between these two posts...
c_dug
PostPosted: 12:21 - 01 May 2014    Post subject: Reply with quote
I eventually got around to making the mounts for my boxes a week or two back. They're solid stainless steel, bolted on either end with M8 bolts.
Should be plenty strong enough!
https://i235.photobucket.com/albums/ee81/paddy2007dug/DSC_0156_zpsxtxu636z.jpg
https://i235.photobucket.com/albums/ee81/paddy2007dug/DSC_0158_zpsk6fs5jep.jpg
I was tempted to drill through and pop a long bolt all the way through but the design of the rails mean they needed a cap head at either end of the mount so I couldn't have kept it neat with a nut.
Anyway, I've noticed with an empty box they twist outwards slightly. I'm guessing this is what the third mount that Sickpup pointed out above is designed to prevent.
It should run from the upper left hole in this picture and end under the back of the pillion handle.
Sort of like this:
https://i235.photobucket.com/albums/ee81/paddy2007dug/railing_zps59f9ee54.jpg
It's quite difficult to knock on up though as none of the angles really line up, plus one end needs to take a bolt and the other end needs to be thin enough to fit under the grab rail.
I'm guessing it doesn't need to take any weight and is purely for stability of the boxes so this far my plan is to cut a 1mm stainless plate into an L shape, then bend it at the end and bolt through the plate, like this:
https://i235.photobucket.com/albums/ee81/paddy2007dug/Bracketidea_zpsc4556215.png
So I have two questions.
1) Any better ideas for a bracket or any issues with my idea?
2) for the time being do you think a ratchet strap or something similar around the top of the rail and the pillion handle would do the job? I'm not in work for a week and a half now and it would be handy to use the boxes before then.
The last post was made 12 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 68.89 Kb
