| c_dug |
 c_dug Super Spammer
| Nope. |
 Nope. World Chat Champion
| stinkwheel |
 Posted: 14:48 - 13 Dec 2012 Post subject: |
The bolt isn't actually supporting the weight. It's just holding the box and the rail together firmly enough so they behave like a solid piece of metal where they touch.
Your footpegs are probably held on with two M8 bolts.
Get a couple of decent ones bolts. I personally would use mild steel ones of grade 8,8 with either spring washers, double nuts or a nylok nut. Although in theory, if you do it up to 19ft/lb with a plain nut, it shouldn't come undone anyway.
You could make a spacer by drilling the middle out of a couple of plain nuts. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| c_dug |
 c_dug Super Spammer
 Posted: 15:14 - 13 Dec 2012 Post subject: |
Nope, on mine the weight will be going directly through the bolts and nothing else, there are two styles of racking used on the xj and on mine the top box rack follows under the line of the tail end body work meaning the side box brackets need to be supported away from the main rack to allow room for the boxes to fit.
Mine rack is the same as the one on this bike (but not in red!), you can just about make out the mounts on this bike. https://www.ebay.co.uk/itm/YAMAHA-XJ-900-DIVERSION-/190766845595?pt=UK_Motorcycles&hash=item2c6a970e9b
Hopefully you can see what I mean about there being a distance between the main rack and the sidebox mounts. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| sickpup |
 sickpup Old Timer
| woll |
 woll World Chat Champion
 Posted: 19:29 - 13 Dec 2012 Post subject: |
Just a normal pair of 8.8 tensile bolts will do the job. You'd be suprised how much they're used. ____________________ Current Bike- Suzuki DRZ400 SM K6
Damaged spleen, damaged kindey, 2 popped lungs, 2 broken ribs, broken face, broken wrist and 5 back fractures... remember kids walls hurt |
| c_dug |
 c_dug Super Spammer
| bladerunner |
 bladerunner World Chat Champion
| reckless_b |
 reckless_b Trackday Trickster
There is a gap of 1 year, 137 days between these two posts... |
| c_dug |
 c_dug Super Spammer
The last post was made 12 years, 201 days ago. Instead of replying here, would creating a new thread be more useful? |
