"Password authentication" on a Dell Laptop
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
Dazbo666
PostPosted: 04:35 - 17 Dec 2012    Post subject: "Password authentication" on a Dell Laptop Reply with quote
I was recently given a spare laptop that I intended to use as a DVD/media player on quiet night shifts...
However the previous owner had not used the laptop for some time, and couldn't remember the password(s)... so now I get this screen comin up the moment my computer loads..
"This computer system, #2GBGD3J-595B, is protected by a password authentication system.
You cannot access the data on this computer without the correct password.
Please type in the primary or administrator password and pres <Enter>."
Is there a way to get rid / reset this "master password authentication" screen?
Its a Dell Inspiron 1520
Windows Vista Home Basic
Word of the day : DILLIGAF
CaNsA
PostPosted: 05:39 - 17 Dec 2012    Post subject: Reply with quote
Download Hirens boot cd
burn it, or plonk it on a pen drive (use google)
boot from it
offline password changer
clear admin password
save
remove hirens
reboot
feel awesome
Dazbo666
PostPosted: 06:11 - 17 Dec 2012    Post subject: Reply with quote
Will give it a try after I've finished my night shift....
Hopefully have some time to myself when the O/H goes to work this afternoon Confused
(Gotta say, being paid to be at work, and getting enough spare time to do some surfing on BCF is pretty cool?!)
prawny1
PostPosted: 10:51 - 17 Dec 2012    Post subject: Reply with quote
Is this a hdd/bios password or windows user password?
I know some of the dells have a bios password system that can be decoded with the service tag.
Ifyour very lucky removing the cmos battery (easier said than done on a laptop) can also sometimes remove bios passwords.
hellkat wrote:
oldpink
PostPosted: 11:09 - 17 Dec 2012    Post subject: Reply with quote
I've binned 2 good laptops because they had the Bios password protected
as there was no way to bypass or remove it
J.M.
PostPosted: 11:21 - 17 Dec 2012    Post subject: Reply with quote
Usually there's a short-circuit trick that you can do on the motherboard to reset the BIOS. I've never tried it before, but I've heard stories about my friends doing it to reset their passwords.
How true it is, I don't know.
2004 R1 & 2018 XSR900
duhawkz
PostPosted: 12:22 - 17 Dec 2012    Post subject: Reply with quote
you can contact dell for a master password to unlock it
you will probably need proof of purchase before they will give you it
or you can pay somewhere like www.laptoprebirth.com for the unlock code.
or you can try searching XXXXXXX-595B bios unlock code or inspiron 1520 bios unlock code and to if you can find some you can get it for free
duhawkz
PostPosted: 12:27 - 17 Dec 2012    Post subject: Reply with quote
Found a free keygen, try it
https://dogber1.blogspot.co.uk/2010/05/dell-2a7b-keygen.html
oldpink
PostPosted: 12:36 - 17 Dec 2012    Post subject: Reply with quote
these were coded directly to the Bios and can't be removed or shorted
as said you can get a master code from Dell but that requires proof of purchase
I tried several hack's and codes without success and eventually gave up
Neorion
PostPosted: 12:46 - 17 Dec 2012    Post subject: Reply with quote
The last dell bios password I cam up against involved me taking out the battery and the bios battery and voila it was wiped.
This wasnt a rom based one so needed the battery not sure what yours is.
VFR FI 2000- Shiney Red Thing
"some things man was never meant to know, for everything else there's Google"
prawny1
PostPosted: 13:59 - 17 Dec 2012    Post subject: Reply with quote
If it is a bios password a forced/recovery bios update might work
Or you can try the default password "dell" or try shorting pin 3 + 6 on the epprom (not done this myself)
Latitude_MasterPW.exe might help if our machine is a d35b model
OR
inspiron_masterpw.exe for 959b models
failing that if you can't find any other work arounds you will need to transfer ownership of the laptop to yourself before calling dell to remove the password as they won't help if you are not the registered owner on the system.
CaNsA
PostPosted: 14:29 - 17 Dec 2012    Post subject: Reply with quote
Hmmmz,
I think it might be the HDD password :/
There are a few bios progs on the hirens cd but i have never needed to use them so i dont know if they work or not.
SQL
PostPosted: 23:13 - 17 Dec 2012    Post subject: Reply with quote
Nuke it reinstall windows sorted you don't need the info on it right~?
duhawkz
PostPosted: 23:36 - 17 Dec 2012    Post subject: Reply with quote
It's a bios password so it won't boot, that won't work
CaNsA
PostPosted: 23:38 - 17 Dec 2012    Post subject: Reply with quote
Do you know that for sure?
Could be a atapwd which applies to the hard drive only.
PostPosted: 00:44 - 18 Dec 2012    Post subject: Reply with quote
From the text it seems like a BIOS password. On an old Dimension desktop I'd just move dip switch 5 but on a lappy who knows.
U_W v2.0
PostPosted: 02:54 - 18 Dec 2012    Post subject: Reply with quote
perhaps a bios "update" would reset the password for it if its old enough?
Casper
PostPosted: 03:39 - 18 Dec 2012    Post subject: Reply with quote
https://www.ehow.com/how_6804267_reset-bios-dell-inspiron-1520.html
andym
PostPosted: 05:30 - 18 Dec 2012    Post subject: Reply with quote
what happened to the good old days of just removing the CMOS jumper for a few seconds to reset passwords?
Islander
PostPosted: 15:43 - 18 Dec 2012    Post subject: Reply with quote
Non-volatile memory happened. Wink
Dazbo666
PostPosted: 21:52 - 18 Dec 2012    Post subject: Reply with quote
Thanks for all the suggestions so far. Yes it seems to be a bios / Dell password.
I tried the Hirens boot disk but the password authentication screen pops up before the system boots on to Hirens disk.
I've also removed 2 small panels from the base of the unit but can't see the cmos battery.
And i've heard of shorting across the 3 & 6 pin of the eprom, but never tried that method yet.
Will prob try the keygen method next, cos that website was one that I was searching earlier this afternoon
Dazbo666
PostPosted: 23:14 - 18 Dec 2012    Post subject: Reply with quote
...Sooo I've managed to download (on to my desktop PC) and run the keygen suggested by duhawkz, then ran the Hirens boot CD.
The BIOS now shows that I've unlocked the admin and system passwords, but even though I've tried setting them to a blank, and later tried setting them to my own password, neither change seems to have been saved by the time I reboot gggrrrr Twisted Evil
Think I'll have to leave it for now, and try again tomorrow... (my body is struggling to cope with recovering from a spate of recent night shifts, and last nights insomnia didn't help)
Dazbo666
PostPosted: 23:18 - 18 Dec 2012    Post subject: Reply with quote
This may be my next plan of attack. The previous owner gave me a pile of re-installation disks (including Windows etc) Thumbs Up
J.M.
PostPosted: 00:05 - 19 Dec 2012    Post subject: Reply with quote
If it's a BIOS password you'll be unable to reinstall anything without getting past that password. You've got to get that sorted first Thumbs Up
Burnside
PostPosted: 00:18 - 19 Dec 2012    Post subject: Reply with quote
are you unplugging the ac adapter/taking out battery/holding the on-off switch/any of the above to reboot?
I started out with nothing and I still got most of it left.
The last post was made 13 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 129.71 Kb
