where to buy localy BA20D bulbs?
U_W v2.0
PostPosted: 20:07 - 17 Dec 2012    Post subject: where to buy localy BA20D bulbs? Reply with quote
looked on halfords website, no results. tried B&Q no results.
so where would be a good place to buy a 45/55w BA20D from locally?
UnknownStuntm...
PostPosted: 20:51 - 17 Dec 2012    Post subject: Reply with quote
Look for an auto electrical place, or look up 'motor factors' in the big yellow doorstop.
To be honest, halfords should be able to get it, depending on the chimp you speak with on the parts counter.
neil.
PostPosted: 22:07 - 17 Dec 2012    Post subject: Re: where to buy localy BA20D bulbs? Reply with quote
ORLY?
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_263703_langId_-1_categoryId_246903
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_263257_langId_-1_categoryId_246903
Those are 35W 12V jobbies, I don't think you can get anything higher, at least I've never seen anything anywhere. They tend to be used on older/small bikes that don't kick out much electrickery.
map
Mr Calendar
PostPosted: 22:17 - 17 Dec 2012    Post subject: Re: where to buy localy BA20D bulbs? Reply with quote
ORLY?
FWIW the Varadero XL125V uses the BA20d 35/35w bulbs (aka 395 bulb). Daughter's Vespa LX scooter also uses the same.
I'm trying to get hold of Xenon BA20d bulbs to give a little better illumination - see here.
Ollie1995 This post is not being displayed because the poster is banned. Unhide this post / all posts.
U_W v2.0
PostPosted: 22:33 - 17 Dec 2012    Post subject: Reply with quote
those two links are for HMB417.
dont think they're the same as BA20D.
if they are though, explains why BA20D returned no results.
i have a halogen or xeon in there already. cant remember which, either way its still absolutely crap.
you can get 55w BA20D but only seem them online for £75!
neil.
PostPosted: 22:35 - 17 Dec 2012    Post subject: Reply with quote
My old YBR used a krypton 395 and I found the 417 halogen replacement to be a massive improvement. Not seen Xenon ones (I assume you mean HID?) but have seen blue tinted halogen ones on the likes of eBay claiming to be that.
neil.
PostPosted: 22:37 - 17 Dec 2012    Post subject: Reply with quote
BA20D is the type of fitment, AKA Bosch. The numbers are specific bulbs which use that fitment.
Raffles
PostPosted: 23:06 - 17 Dec 2012    Post subject: Reply with quote
You could try one of these:-
https://www.ebay.co.uk/itm/SCOOTER-HALOGEN-UPGRAD-HEADLAMP-BULB-12v-50-50w-BA20D-/300377023419?pt=UK_Motorcycle_Parts&hash=item45efdda3bb
You should, however, be aware that the lamp may require more current than your bike can provide and that the heat it will produce may cause the lense and reflector to melt.
Shinigami
PostPosted: 14:20 - 18 Dec 2012    Post subject: Reply with quote
my cityfly uses the same bulbs, they're only rated upto 35w.
I got a xenon one from ebay, it is a bit brighter/cleaner light but doesn't really make much difference at all really
Robby
Dirty Old Man
PostPosted: 00:53 - 19 Dec 2012    Post subject: Reply with quote
If the headlight is crap, then using a brighter bulb will just mean you have warmer wires. A decent headlight works perfectly well with a 35W bulb.
If your headlight is an ebay cheapy, it'll always be shit. Brighter bulbs won't help, getting a decent headlight will.
_mjs_
PostPosted: 10:03 - 19 Dec 2012    Post subject: Reply with quote
I've got a ba20d bulb from my old XR if you're still after one.
PM me your address and I'll stick it in the post after work Thumbs Up
Resurrection This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
CarlosCBR
PostPosted: 13:09 - 19 Dec 2012    Post subject: Reply with quote
https://www.ebay.co.uk/itm/H6M-BA20D-395-XTREME-WHITE-XENON-MOTORBIKE-35-35W-BULB-/220656857279
Used these on the CBR125, Much better than the OEM bulbs and lasted 2 years and 20,000 miles before one blew.
The last post was made 13 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 84.28 Kb
