| Eddie Hitler |
 Eddie Hitler World Chat Champion
 Posted: 19:52 - 18 Dec 2012 Post subject: zzr600 d rear wheel |
Me. Again.
Thanks for the advice in the last post, I'm sure it's all ok but will have a play with it tomorrow to double check.
Ordered a new sprocket carrier. Someone had SUPERGLUED! yes superglued part of the old carrier plastics where the bearing was held. Unbelievable. The bearing that came with this new one looks brand new, so will grease again and use that it.
Problems are arising with the spacers. Most I can work out, but this one doesn't seem to show up in the diagram Kickstart provided. It seems to detatch from eachother, creating 2 separate spacers.
Now when I put just one half inside the carrier, it slides onto the wheel no problems. When I combine the 2, which is how they somehow came out to begin with, it doesn't fit on.
Any ideas? Racking my brains.
The spacer in question is in the centre.. The 2 below go on the chain side of the wheel.
https://i49.tinypic.com/313sos4.jpg |
| Eddie Hitler |
| Dracon |
 Dracon Nitrous Nuisance
| yen_powell |
| Eddie Hitler |
 Posted: 22:59 - 18 Dec 2012 Post subject: |
Just realised..
The bearings were shot. Is it possible that's the inside of a bearing? And I have just gone mad.
Dracon - I have everything for the other side.  |
| Eddie Hitler |
| Eddie Hitler |
| jimspeed |
 jimspeed World Chat Champion
 Posted: 23:51 - 18 Dec 2012 Post subject: |
The mystery bit is a broken bearing, you should have a spacer between the wheelbearing and the sprocket carrier bearing otherwise when you try to tighten it its just trying to push the carrier bearing thru to the wheel bearing..
I think there should be a small gap between the carrier and the wheel to allow for movement but not sure of 2mm is a bit much.
basically if you imagine the axle bolt should pass thru the spacers and wheel with no air space between any of the bits ie , rear arm>spacer>carrier bearing>spacer>wheelbearing>spacer tube inside wheel>wheelbearing>spacer>rear arm if you see what I mean.  ____________________ Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?" |
| Eddie Hitler |
 Posted: 23:56 - 18 Dec 2012 Post subject: |
I do see what you mean, I'm going to put it all back on tomorrow once my new spindle comes through (playing it safe, the old one was minutely warped). Cheers, it does seem too much of a gap, but there is nothing else I can change, it's all there correct.  |
| Raffles |
 Raffles World Chat Champion
| Eddie Hitler |
| Raffles |
| Eddie Hitler |
 Posted: 00:27 - 19 Dec 2012 Post subject: |
It's set up how the diagram you showed is, it's just the small gap between the carrier and the wheel that's bugging me. Is a gap normal? It's set up correctly, and all the parts are correct.
BTW, I didn't mean the gap that you're thinking. I mean the outer rim, where the carrier meets the wheel. The outer circle/rim.
| Eddie Hitler |
The last post was made 13 years, 200 days ago. Instead of replying here, would creating a new thread be more useful? |
