Electrical problems again. any electricians?
Kradmelder
PostPosted: 18:31 - 19 Dec 2012    Post subject: Electrical problems again. any electricians? Reply with quote
Arrg, start of christmas holidays and the lights in my bar not working. They were wired to a dimmer switch. I took off the dimmer and put on an old switch I had. they lights worked perfectly for a few hours, now are off again.
It doesnt trip the circuit or anything. It is the standard 2 wire, red and black wire. the hot live, and the power to lights.
I know I know put a multimeter across the 2. Dont have one here. I called 2 electricians and both have there phones off and are gone for the holidays. I dont want to fetch my beer in the dark until Jan Evil or Very Mad
any ideas what the problem could be?
2011 KTM 990 Dakar
2009 BMW 1200 GS
PostPosted: 18:55 - 19 Dec 2012    Post subject: Reply with quote
No white wires... there is your problem..
Kradmelder
PostPosted: 19:12 - 19 Dec 2012    Post subject: Reply with quote
but you must be careful with the black one because it will zap you if you stay on top of it and clamp it down
Razz
2011 KTM 990 Dakar
2009 BMW 1200 GS
J4mes
PostPosted: 19:14 - 19 Dec 2012    Post subject: Reply with quote
tried putting the dimmer switch back in to test if the circuit is ok or if it's just the standard switch that is faulty?
Kradmelder
PostPosted: 19:21 - 19 Dec 2012    Post subject: Reply with quote
i took it off because i dont need a dimmer and i have found the dimmer part tends to go after a while. the standard swithc worked all day until evening. typical. It is an old switch though. when i can see again i will buy a new switch and install. but first i will put the dimmer switch back in tmorrow, by passing the dimmer
2011 KTM 990 Dakar
2009 BMW 1200 GS
J4mes
PostPosted: 19:25 - 19 Dec 2012    Post subject: Reply with quote
Either that or quickly borrow a switch off another light circuit and try it.
Normally in this situation I just grab a thick bit of wire with insulated pliers and jab it across the terminals to see if the lights come on, but the main risks are fire and electrocution so I wouldn't suggest you try it!
Walloper
PostPosted: 20:27 - 19 Dec 2012    Post subject: Reply with quote
Nip out to the shops and buy a freakin lamp for 30R.
You tight fisted Dutchman you.
nowhere.elysium
The Pork Lord
PostPosted: 20:38 - 19 Dec 2012    Post subject: Reply with quote
https://static.fjcdn.com/pictures/Dutch.+Nigel+Powers_0c07c6_4270628.jpg
In all seriousness, this would be the time to purchase a cheap multimeter. I can foresee more stuff shorting out over the holidays, and if you have no means of diagnosis, you have no means of solving the problem until (presumably) mid January.
Is there no-one amongst your local mates who know electrickery?
uberkron
PostPosted: 21:37 - 19 Dec 2012    Post subject: Reply with quote
Are you running filament lamps only? No halogen lamps on switchmode supplies? No compact fluros? Those dimmers are fairly rugged. Most are only 300watt. And yeah buy a cheap multimeter, with your amount of electrical woe it would help.
I can shout suggestions on how to use it too!
i ride a zip 50 2smoke. It overtakes a hundred times a day.
uberkron
PostPosted: 21:38 - 19 Dec 2012    Post subject: Reply with quote
Kradmelder
PostPosted: 21:44 - 19 Dec 2012    Post subject: Reply with quote
i thought of just connecting the 2 wires and turning on at the circuit breaker, but was worried about a short.
2011 KTM 990 Dakar
2009 BMW 1200 GS
Walloper
PostPosted: 21:46 - 19 Dec 2012    Post subject: Reply with quote
Ride the bike into the room and leave the head lamp on pointed at the bar So whenever you need more beer you just start the engine for a few minutes.
ps leave a window open.
Kradmelder
PostPosted: 21:49 - 19 Dec 2012    Post subject: Reply with quote
well one coming tmorrow. if he doesnt have one will go buy. But if there is no power across the two wires, then i have a problem.
I just checked the power at the light in the braai, further down the line. On. so the problem isnt likely the wiring in the roof. There are 2 sets of lights in the bar so it isnt the light fitting. It has to be at the switch.
i hate electrical stuff. mechanical so much more obvious.
2011 KTM 990 Dakar
2009 BMW 1200 GS
Kradmelder
PostPosted: 21:51 - 19 Dec 2012    Post subject: Reply with quote
thanks. all the lights in there are those energy savers. that is why a dimmer is usless. cant dim them.
two fittings, each has 3 14w energy savers instead of 3 60w bulbs.
2011 KTM 990 Dakar
2009 BMW 1200 GS
Kradmelder
PostPosted: 21:54 - 19 Dec 2012    Post subject: Reply with quote
fark you are full of brilliant ideas. may as well think that you can paint your face blue and charge the english long bows Laughing
now im heading into the dark bar for a brandy and coke.
2011 KTM 990 Dakar
2009 BMW 1200 GS
uberkron
Yeah dimmers work with very few fluros. There are dimmable ones but you pay for the privilege.
Kradmelder
PostPosted: 21:58 - 19 Dec 2012    Post subject: Reply with quote
ja im paying with energy savings in my bar. No lights. a bar full of booze and rely on experience and feel, not sight Mr. Green
2011 KTM 990 Dakar
2009 BMW 1200 GS
nowhere.elysium
The Pork Lord
PostPosted: 22:16 - 19 Dec 2012    Post subject: Reply with quote
Indeed. Dimmers tend to cause arseache in my experience; I'm not a huge fan of the things, truth be told. Well, until your mate turns up tomorrow, there's not so much that can be done, unless you reckon you can cultivate echo-location skills in the space of one evening Laughing
Kradmelder
PostPosted: 22:25 - 19 Dec 2012    Post subject: Reply with quote
i can see fark all in there. Laughing i will wait till my mate comes tomorrow. before that put on the old old switch bypassing the dimmer. If I have no joy it is multimeter time and buy a new swtich while Im at builder's house. if the is no power at the switch, then the break can only be in the roof between the circuit breaker and the switch, since the braai lights are working. But to crawl in the roof in this heat. far hotter up there.
roof rats and ants are common her. I poison them whenever I hear them. But they could have chewed through the wiring
2011 KTM 990 Dakar
2009 BMW 1200 GS
nowhere.elysium
The Pork Lord
PostPosted: 22:29 - 19 Dec 2012    Post subject: Reply with quote
Sounds like the ants you get are a little more imposing than the ones we're used to over here. Laughing
https://1.bp.blogspot.com/_Hc27foH9KAw/TOE7YZeUmZI/AAAAAAAADq4/LdvCqgefzak/s400/them.jpg
lihp
PostPosted: 22:33 - 19 Dec 2012    Post subject: Reply with quote
If you have a terminal strip, just connect the 2 wires together and flick the breaker on see if it works.
Kradmelder
PostPosted: 22:39 - 19 Dec 2012    Post subject: Reply with quote
i think it is the roof rats that eat wiring. The ants just go for the rat remains. I use a 2ndary poison that clogs the rat's guts, driving them out to drink. then shoot them. I dont want them dying in the roof, nor having dogs eat the poison in the rat carcass.
Tropical trees around my house, which rats climb to get at fruit. Then they try nest in roofs. it is a constant battle. dont get me started on birds nesting over my pool. Native birds I tolerate. But invasive india mynahs..... the law is we must shoot them as an invasive alien. but if they dont harm me, like a roof rat, i just cant shoot them for doing what is their nature.
2011 KTM 990 Dakar
2009 BMW 1200 GS
Kradmelder
PostPosted: 08:04 - 20 Dec 2012    Post subject: Reply with quote
No power across the 2 wires at the switch. I took off both light fittings and no loose wire there either.
2011 KTM 990 Dakar
2009 BMW 1200 GS
russeleoin
PostPosted: 13:16 - 31 Dec 2012    Post subject: Reply with quote
Big Jessie, like all Vaalies, shoot the damned birds and rats. The Myna is a pest. Next thing you will tell me you are a bass fisherman!
I love classic merc's but bikes take up less space.
Current ride is a Yamaha YB 100 and I love it! Oooow and now a running GPZ400R!
Next stop, Direct Access hopefully by the end of summer.
The last post was made 13 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 136.56 Kb
