'Never' using front brake
Bike Chat Forums Index -> General Bike Chat Goto page 1, 2, 3, 4, 5  Next
covent.gardens
World Clap Champion
PostPosted: 20:53 - 19 Dec 2012    Post subject: 'Never' using front brake Reply with quote
I'm just wondering what you all think about this. On average, I'll only use the front brake once every 60 to 80 miles or so in my normal riding (relaxed 'commuting sensibly' style riding). Almost all of my slowing down gets achieved by engine braking and/or the rear brake.
I'll generally only use the front brake if I need to, i.e. something unexpected has happened, and I need to slow fairly quickly.
I do instinctively go for the front brake in emergencies and cover it often if I think I might need to use it (at junctions etc). But, I never actually use it unless I need to, and it's pretty rare that I need to. If someone disconnected my front brake I probably wouldn't notice for days.
I've heard a lot of people say they only ever use the front brake, not the back, but I'm doing the opposite.
I often wonder if it's a fault that needs fixing, or just a preference I have that's ok to keep. When I'm on the bike I don't feel that it's a problem but then I wonder why more people don't seem to ride like this.
Whaddaya think?
Slacker24seve...
PostPosted: 20:57 - 19 Dec 2012    Post subject: Reply with quote
Unless back is front and front is back in your mind (perhaps making for an interesting anal vs regular sex encounter) then you are very much doing it wrong.
It is a fault that needs fixing, and quickly.
Banger rallies are ace
covent.gardens
World Clap Champion
PostPosted: 20:59 - 19 Dec 2012    Post subject: Reply with quote
I know which pedal/lever does what Wink
I guessed it might be seen as a fault, but not quite clear on why?
BigDan1190 This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
U_W v2.0
PostPosted: 21:02 - 19 Dec 2012    Post subject: Reply with quote
I used to do the same. But that was because I was concerned over the "push bike high speed front brake" then realised I had the entire weight of the motorcycle and chances of doing that with a 125 where minimal at best and impossible if used properly.
Now I will use the front brake more than the rear.
I find I spend less time braking using the front brake more than the rear as it beds the wheel into the road increasing grip and stopping power.
covent.gardens
World Clap Champion
PostPosted: 21:03 - 19 Dec 2012    Post subject: Reply with quote
BigDan wrote:
Its really not worth explaining it to you.
Just learn to use the front more.
You've been given the redundant rating you deserve, if you can't be bothered to explain yourself don't bother saying anything. I am willing to listen to anyone who takes the time to explain.
U_W v2.0
PostPosted: 21:06 - 19 Dec 2012    Post subject: Reply with quote
As I edited into my previous, I think has to do with the fact the front brake has the following effects.
1) shifts weight forward onto front wheel
2) beds from tire into the road gaining extra grip
3) increases stopping power due to shifted weight
4) can brake later and harder
5) can spend less time braking and control your "flow" better through "stop start" traffic.
hope this helps anyway.
biker7
The slightest bit of petrol, grit or new rain and a skid is possible. Both brakes with slightly more on the front and only the front in slow traffic for me. Engine braking whenever possible. If you ever have an off when your back wheel locks - you won't ask the question again. Take care.
Swansea area
Fat Bob (2019)
Ollie1995 This post is not being displayed because the poster is banned. Unhide this post / all posts.
Chalky.
PostPosted: 21:10 - 19 Dec 2012    Post subject: Reply with quote
My CG125 doesn't have a front brake Laughing
Lots of fun in the wet... Shocked
Slacker24seve...
PostPosted: 21:13 - 19 Dec 2012    Post subject: Reply with quote
You can brake more efficiently with the front brake - the fact it is considerably bigger (and there is often two of them) should give you some pointers about this. Why do superbikes have massive, twin, four or six pot calipers up front and a tiny, single pot rear brake?
Start using the front brake. Do it on your next ride - squeeze progressively - and not only will you thank us for it when you need to stop in a hurry but you'll also start to see just how much later you can brake.
Ollie1995 wrote:
I learnt not to use the front brake excessivley the hard way today, lost the front end Sad
You've been riding for all of five minutes and crashed into a massive 4x4 that you didn't see. Pipe down.
covent.gardens
World Clap Champion
PostPosted: 21:14 - 19 Dec 2012    Post subject: Reply with quote
These are 4 sound reasons, but to me it's like they would be more relevant to fast road riding or a track. Not my gentle old commute!
Thing with my riding is I try and be smooth, and I'll slow well before a bend rather than speeding up to it and trying to shed speed at the last moment.
I try never to get in to the situation where I need to brake quickly. If I do, I will use the front brake.
Mr Rear Brake is my friend in this kind of situation too, I'll tend to ride the rear brake and keep going at a slow pace whilst everyone else stop/starts!
U_W v2.0
I rode my bike 10 minutes down the road without a front brake to get some brake fluid and found it terrifying knowing it wasn't there.
Subtle case of "what if I needed it?" SPLAT! Most likely.
I would offer you that chinese after market master cyclinder but honestly, having tried it, its not worth the pixels the text would make up on the screen.
stonesie
PostPosted: 21:17 - 19 Dec 2012    Post subject: Reply with quote
I find that the front brake gives much greater control and massively more stopping power than the rear, as you brake the weight of yourself and the bike is thrown forward onto the front wheel giving it more grip. Because of this it means the rear tyre has less weight pushing it into the ground, so less grip.
To be perfectly honest all of that has no real effect on the riding you describe but it is a very bad habit, in a genuine emergency you will stamp the back brake before you consciously think about it because that's what you always do to slow down.
https://youtu.be/AY02LkCHvvQ?t=2m32s
My rear gets used below 15~20mph only.
Valentino Mossy
PostPosted: 21:18 - 19 Dec 2012    Post subject: Reply with quote
Bought a trials bike and within a few seconds of going down my first muddy wet bank i realised....you dont use the front brake....unless you like eating mud.
U_W v2.0
PostPosted: 21:19 - 19 Dec 2012    Post subject: Reply with quote
The other thing is, if your not using your front regularly it could be prone to problems.
You may also "forget" where its bite point is and where the "fuck you im throwing you off" point is.
Im not sure how long you've been riding, if your licensed or on CBT. Not that its comepletely relevant but most 125's I've noticed have front disk and rear drum. And we all know the difference between the two is night and day. Forgetting where the points are on your front disk could result in a nasty injury, same with if it develops a problem between you last using it and you needing it. You can be a royal jerk sometimes but wouldnt really wish you any harm. So might be good to start using it more often. Thumbs Up
covent.gardens
World Clap Champion
Going to be honest and say I do recall locking up the rear once quite unnecessarily. I lifted off immediately and it sorted itself and was no biggie. I reckon part of why I prefer the rear brake is that if the rear locks, at least you've a good chance of recovering. If the front goes down you've had it!
I think I'd have hit the deck by now if my problem was one of overusing the front brake!
U_W v2.0
PostPosted: 21:21 - 19 Dec 2012    Post subject: Reply with quote
Someone please comment on the relevance of this post to this thread! I cant bring myself to do it.
Teflon-Mike
tl;dr
PostPosted: 21:23 - 19 Dec 2012    Post subject: Reply with quote
In Days of yore, they used to say stuff like, "If you lock the Back you can always get it back, if you lock the front, your in for a shunt" And it was a very common suggestion to NOT use the front brake.
and there were valid reasons for it. In days of yore, tyres were no where near as predictable as they are now, and motorcycle design, favoured longer, lower motorcycles with more rearward weight bias.
However, you look at road-race bikes of the 1930's, even then they were fitting brakes to teh front wheel, and often bigger brakes than they did at the back.
By the 1960's they were fitting huge, multi-leading shoe front drums to the front of racing bikes, and much more 'token' single leading shoe brakes to the rear; while filtering to road bikes the larger Twin-Leading Shoe drum was commonly fitted to front wheels, a smaller single leading shoe drum to the rear.
1970's, we started seeing powerful hydraulic disc brakes fitted to the fronts, while drums were rertained at the back; and through the 80's and on, the vouge has seen ever larger, ever more sophisticated twin discs used at the front with multi-piston calipers, while far less powerful and much smaller single disc arrangements have been used on the rear.
That tells you where the braking power is put, and ought to suggest where most of your effective braking is going to come from......
The Front.
Under braking, you get 'weight shift', the force pitching you forwards as the bike tries to slow down beneath you.
That weight shift sees most weight moved to the front wheel; which consequently has the most grip on teh road and can therefore transmit even more braking force than before it started.
Grip is the force between wheel and road, and is basically the co-efficient of friction between rubber and road, times the weight on the wheel.
Braking at the back wheel, weight shift is working against you; you brake weight goes forwards OFF the wheel that's braking meaning less grip, meaning less braking and the wheel is more likely to lock and the bike skid.
Text-Book braking is 75% braking effort FRONT, 25% Braking effort rear, in GOOD conditions; 50% front 50% rear in poor conditions, ALWAYS front applied before back.
So, yeah... you are doing it wrong!
At least for 'Normal' Road-Riding. There is some situations where rear only braking is legitimate, such as trail braking for slow speed manouvers, or trailing the rear brake for stability into a corner. More instances exist off road on loose surfaces, but even in the most extreme, in trials riding, we will still use the front, and often hard, particularly in situations like a slippery down-slope, where you'd expect the back to be favored, as precaution against flipping over the nose... but, risk there is that you end up with the tail sliding and no control, so we will move weight as far back as we can, and still use as much front as possible.
Adamantis
PostPosted: 21:24 - 19 Dec 2012    Post subject: Reply with quote
I've put 12k on my bike, and the front pads are still full of life. Ahhh, the engine braking abilities of a v-twin, or something... (I do use the front brake, but usually only to come to a complete stop or if something "unexpected" happens - anticipation reduces the wear on the pads...)
Rides: '91 CG125 (Sold), '00 CB500S (Sold), '97 Thundercat (Sold), '99 KTM EXC 300 (SOLD), '99 RSV Mille (stolen. Thieving SCUM!!!), '94 DR350 (sold), '10 Vstrom 650 (hated it so much I gave up riding), now on the OH's CBF1000 until I can afford another Mille...
noobRider
I am new at this but my instructor told me to be at least 70-30 on the front brake (in the dry). At any sort of speed the back brake isn't very effective compared to the front and I am very good at getting the back to skid if I use it too much, to the extent that I only use it at low speeds. I was worried at first because of the push-bike thing but it's different and you're pushing the wheel into the road, not catapulting yourself over the top Smile
On my mod 1 my instructor said to use the back brake only at the low speed stuff to keep control just as you would in traffic queues etc, and to only use the front brake for the fast parts of the test: on the emergency stop I just used the front brake and moved my foot on the peg so the examiner would think I was using the back: it's so easy to skid as a noob otherwise.
Engine braking on a big bike is great though Very Happy
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
Valentino Mossy
PostPosted: 21:27 - 19 Dec 2012    Post subject: Reply with quote
Road bike i will use more front then rear, use the rear brake on the corners.....
When the weather is shit and slippery, i'll use more rear then front...
off road or fucking wet/ice as fuck... rear all the way.
Thumbs Up Wink
You want to use more front as that is where weight is transferred during braking.
I rarely use the rear, ever.... Laughing
dungbug
PostPosted: 21:29 - 19 Dec 2012    Post subject: Reply with quote
/\ This, front brake has vastly more stopping power. It's a bad habit really, get into using the front. Wink
CBT: Pass 25/06/2011 Theory Test: Pass12/06/2012 Mod 1: Fail 08/07/2012
Mod 1 Retest: Pass 15/0702012 Mod 2: Pass 03/08/2012
Suzuki GN125 (Sold) ~ Current bike: Yamaha YZF 600R Thundercat
Acemastr
PostPosted: 21:38 - 19 Dec 2012    Post subject: Reply with quote
I've had the same rear pads on my bike for 2 years... and I've had 2 advisories for them being low Smile that's how much I use it!
Rear brakes are shockingly bad and aren't designed to slow the average bike down, if it was a cruiser I could understand but I'd almost certainly be dead if I only used the rear
2016 Toyota Tacoma Limited
The last post was made 13 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 5
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 136.88 Kb
