Sufficient Warm Up Time For CBF500
Scootaloo
PostPosted: 11:32 - 22 Dec 2012    Post subject: Sufficient Warm Up Time For CBF500 Reply with quote
Hello All
I commute a short 15 minute drive to work.
At the very first segment in my commute (about 2-3 minutes in) I hit a fast dual carriageway which will often see it at about 50-70 mph.
In recent days when it's been really cold, I was wondering is it bad for a machine to be running at %60+ capacity within the first few minutes of driving?
The Engine feels ever-so-slightly restricted in the few minutes running up to the carriageway, but this soon is gone.
What are your thought's on this?
(CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87)
Quote Me Happy
PostPosted: 11:34 - 22 Dec 2012    Post subject: Reply with quote
As long as you're not redlining it in every gear it will be fine.
Scootaloo
PostPosted: 11:51 - 22 Dec 2012    Post subject: Reply with quote
Cool, All I needed to hear.
I don't red line it, but I do boot it a bit sometimes upto 8000 RPM (redline: 9500 RPM) so it should be operating well within it's printed design.
Cheeseybeaner
PostPosted: 11:57 - 22 Dec 2012    Post subject: Reply with quote
Just don't over rev it for a few miles. Personally I always try and get the engine to the dial position it normally reaches when warm on the temp gauge before I'd think about opening it up fully.
My bikes: 2003 KAWASAKI ZRX1200R, 1996 YAMAHA DIVERSION XJ900S
esullivan
PostPosted: 12:09 - 22 Dec 2012    Post subject: Reply with quote
I have a routine in the morning (which tend to be dark and cold at 6am):
* I unlock the bike from the ground anchor.
* walk it to the centre of the drive
* start the bike
* check the lights (each indicator and the brake)
* do a quick walkaround (looking for any very obvious broken things)
* put my lid and gloves on and then hop on and go.
The time between the third and sixth steps is plenty of time for a warm up. Probably too much, actually, for a fuel-injected bike, but I can do all this in a couple of minutes.
On the way home, I do a shorter version of this, starting the bike when I'm sitting on it and giving it about 30 seconds before setting off.
Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
0l0dom0l0
PostPosted: 12:48 - 22 Dec 2012    Post subject: Reply with quote
Pulling onto a 70mph dual carriageway in the first few mins of riding, isn't exactly ideal.
I try to keep my bike below 4k rpm until I see two bars on the temperature gauge which means the coolant is at 60 degrees, but as a general rule of thumb it won't see anywhere near the redline (8k and above) until 4-5 miles of riding.
It's partly the revs that kill cold engines, and it's partly the load. So whacking the throttle wide open at 4k revs will do just as much damage as taking it to the redline.
You can't help going on the dual carriageway, so the only thing I would suggest if you aren't already is start the bike up as early as you can, so if you're getting it out a garage, start it when you get it out then put on gear etc just to give it a chance to get a little bit of temperature before you join the dual carriageway.
T0MMY
PostPosted: 13:29 - 22 Dec 2012    Post subject: Reply with quote
I don't see a problem with just starting it, jumping on it and going as long as you don't accelerate hard or rev it much. Just ride gently until it's up to temperature, getting up to 70 can definitely still be gentle.
ZX6R + CBR600RR
J.M.
PostPosted: 13:38 - 22 Dec 2012    Post subject: Reply with quote
There's no real point giving it a lot of time to warm up idling, all it will do it warm the engine up unevenly.
The best thing that you can do it hop on the bike and ride it gently as soon as you're able until the engine has warmed up a little. The air whilst riding helps to spread the heat through the engine rather than keeping it centralised mainly in one area.
2004 R1 & 2018 XSR900
AlexW
PostPosted: 14:03 - 22 Dec 2012    Post subject: Reply with quote
Depends how much you care, I start my bike on the road, drop it into gear and fire off up the road at full throttle.
But then I don't care Very Happy
Scootaloo
PostPosted: 14:17 - 22 Dec 2012    Post subject: Reply with quote
Not too fussed, Just trying to get as much mileage out of the machine as possible as this is going to be my commuter for the next 2 years.
AyrshireBiker
PostPosted: 14:27 - 22 Dec 2012    Post subject: Reply with quote
My bike is a Bandit 650 with carbs... I normally start it, let it tick over for a minute while I get my lid and gloves on then do the first 1/2 mile quite gently - which takes me onto the dual carriageway. By then it is pretty much warmed up.
You are as well getting on your way, doing a gentle 1/2 mile or so as you are letting it idle. Just don't start it, hop on and wack the throttle open!
Vracktal
PostPosted: 15:01 - 22 Dec 2012    Post subject: Reply with quote
I have an old 500 with carbs, generally I start it on half choke and let it run for about a minute or two, then turn off the choke and ride it gently for a half-mile or so, then ride normally.
stevo as b4
PostPosted: 15:06 - 22 Dec 2012    Post subject: Reply with quote
Id be more careful with the warming up when the bike is 12years old and has been over half way round the clock, than over the first 2years of it's life.
And Dom is right about really loading up a cold engine with big throttle openings at low revs is as bad if not worse than just letting it rev freely through the gears with less throttle.
PostPosted: 15:27 - 22 Dec 2012    Post subject: Reply with quote
Anyone got comparative pictures of the internals of engines that have been run in a controlled, consistent fashion from several hundred cold starts, both from new, and when they've already had miles put on them?
Absent that, we're discussing unquantified myth and anecdotes. Everyone knows a guy who knows a guy.
Unless you're planning on keeping it long term, then I'd go ahead and ride it any way you like. Maybe change the oil a bit more regularly to assuage the folk wisdom.
Rogue_Shadow
PostPosted: 15:41 - 22 Dec 2012    Post subject: Reply with quote
I gently rev my SV till the engine temperature reading comes on. Normally 1-2 minutes which is fine when parked at home, but annoying when I'm leaving a mates ect after the bikes been rested for a good couple hours.
PostPosted: 15:51 - 22 Dec 2012    Post subject: Reply with quote
^^^You don't need to.
Get on and ride it without thrashing or labouring the engine.
Choke/Fast Idler is on the handlebars and easily adjusted, unlike the cruddy CG where I rammed my hand into the area of the carburettor and punched it a few times.
PostPosted: 16:12 - 22 Dec 2012    Post subject: Reply with quote
My 125 does a motorway journey every day.
I start the bike, it idles while I pop my lid on then I ride away.
It does about 2.5 miles then it gets on the motorway and sit at 70/75 which is full throttle Laughing
PostPosted: 22:43 - 22 Dec 2012    Post subject: Reply with quote
I would avoid more than half max revs until it is up to temp (rule of thumb, same revs as I would use for running in), but avoiding large loads is also a good idea.
That said just starting it and leaving it idling won't do it any good either (probably increase wear).
hornetmike
PostPosted: 08:33 - 23 Dec 2012    Post subject: Reply with quote
I worry more about getting the tyres warm rather then then the engine.
Chassis generally gives up before the engine on high mile bikes, how many people have killed a modern engine within 60k, whilst ridding normally ?
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
evoboy
PostPosted: 10:27 - 23 Dec 2012    Post subject: Reply with quote
Agreed. There are many more factors that kill an engine on a modern bike. Lack of proper maintenance being the first...
I have to get onto a 60mph limit road less than a mile from my house. But then the zx7 is only turning some 4-5k at that speed.
APT Motorcycles
RhynoCZ
PostPosted: 10:51 - 23 Dec 2012    Post subject: Reply with quote
On the clock there is small C next to small square. That C stands for COLD, get it above the square and you're good to do what ever you want Thumbs Up
https://bikebreakers.ie/images/honda-cbf500-clock-set.jpg
DrSnoosnoo
PostPosted: 22:45 - 23 Dec 2012    Post subject: Reply with quote
With mine, a ZZR 600, I start it with the choke for the amount of time to get my gloves and helmet on.then I ride it down the road to the 40 zone for about a kilometre then in my head she's warm enough
moppy
PostPosted: 22:51 - 23 Dec 2012    Post subject: Reply with quote
Turn the bike on, put helmet + gloves on, wait until bike can idle without choke. Get on bike and ride as normal. Probably not what you should do, but it is what I do do.
Noxious89123
PostPosted: 00:55 - 24 Dec 2012    Post subject: Reply with quote
CBR runs hot as hell, by the time I've put my lid and gloves on and got out onto the main road it's already at 70c+
Walloper
PostPosted: 03:10 - 24 Dec 2012    Post subject: Reply with quote
Hand Are there any Kittens in the neighbourhood?
If it's free of kittens I'm sure it will be OK to do wot u r doo in.
The last post was made 13 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 127.17 Kb
