Are Iridium sparks pointless?
Mondeo Man
PostPosted: 11:58 - 22 Dec 2012    Post subject: Are Iridium sparks pointless? Reply with quote
The sparks on my bike have done next to no miles (although it's been standing for over a year before I picked it up).
I have a set of Iridium sparks which I will either fit or sell. Is it worth fitting them? Will it make any meaningful difference in performance - to me, it's irrelevant if the Iridiums "last longer" - because the standard ones last long enough.
bandit 6 s
0l0dom0l0
PostPosted: 12:39 - 22 Dec 2012    Post subject: Reply with quote
It's up to you really.
You aren't going to notice an increase in power, you aren't going to notice an increase in economy.
But to be honest, if the bikes been sitting for a year un-used and you have them there... I'd swap them out.
Purely on the basis that you might sell them and get £10 for them, but for the hassle and everything else of selling them, posting them etc and the fact that plugs do de-grade over time, especially when not used and the fact we have lots of cold weather coming etc. I'd just change them.
keggyhander
PostPosted: 13:34 - 22 Dec 2012    Post subject: Reply with quote
I've found that the ignition "catches" quicker on cold starts with iridiums.
Fizzer Thou
PostPosted: 13:45 - 22 Dec 2012    Post subject: Reply with quote
If you have them it would be worth fitting them.
I have them on my R1 and my KTM enduro and notice a differance in throttle response,especially when used in conjunction with super-unleaded.
This is my own feeling and I do not expect everyone to agree with my findings.They just happen to work well for me.
Always have a 'Plan B'
s1h
PostPosted: 14:04 - 22 Dec 2012    Post subject: Reply with quote
Definitely better for cold starting the other year when it was -15 or whatever my bike was a pain to start when left outside overnight at work. Put these in and it fired up first time Everytime
fatpies
PostPosted: 14:05 - 22 Dec 2012    Post subject: Reply with quote
Placebo?
AlexW
PostPosted: 14:11 - 22 Dec 2012    Post subject: Reply with quote
fatpies wrote:
Placebo?
I always wonder about this. I have Iridium spark plugs (I hate them being called "Sparks" :@ ) in my bike, I noticed it helped, but I do wonder how much differance it makes vs new standard plugs.
temeluchus
PostPosted: 15:21 - 22 Dec 2012    Post subject: Reply with quote
fatpies wrote:
Placebo?
No.
They do last longer, which is the main benefit.
PostPosted: 16:07 - 22 Dec 2012    Post subject: Reply with quote
Just for larks, I tried a selection of plugs in my 125. Two heat ratings, iridium, and a side gapped plug. It's my subjective belief that the iridium gave the easiest cold starting. That's all that I present it as.
nowhere.elysium
The Pork Lord
PostPosted: 17:46 - 22 Dec 2012    Post subject: Reply with quote
They're more durable, and have a slightly higher conductivity than regular plugs, which probably explains the improved cold starts that people report. Personally, I'm not that fussed about them - if the shop has them and they're only a little bit more expensive, then I might splash out, but they're not something I'd actively seek out.
Frost
PostPosted: 18:44 - 22 Dec 2012    Post subject: Reply with quote
They last longer and perform more consistently. But you when you compare the cost of them vs the cost of buying normal plugs to last the same time period there's no real difference.
I stick with normal plugs and change them as soon as they get shitty or oiled up.
Paulington
PostPosted: 18:51 - 22 Dec 2012    Post subject: Reply with quote
I have found no difference having iridium spark plugs in the Pan-European since they were fitted, starts and runs the same.
I think you notice the difference more on higher tuned engines, on the race engines having an iridium spark plug made it run better, easier to start, ran cooler and was just a noticeable improvement.
I fit them to everything as it's what we keep and they last longer, but I don't think you're missing out on much on bog-standard engines.
oldenuff
PostPosted: 19:07 - 22 Dec 2012    Post subject: Easier starting in the cold and wet Reply with quote
I get easier starting with the iridium plugs and as the price difference is small if you shop around why not use them?
MattEMulsion
PostPosted: 20:39 - 22 Dec 2012    Post subject: Reply with quote
I've never used them in anything, performance bikes or cars. I do however use genuine original equipment plugs when I change them. If its good enough for when it leaves the factory then it'll do for me... Very Happy
Oh and on another note I don't think that unused (or little used) plugs will deteriorate with age, so if the ones in are haven't do many miles it would be false economy to change them. Thumbs Up
Yamaha YZF-R6
stevo as b4
PostPosted: 12:26 - 23 Dec 2012    Post subject: Reply with quote
here's a theory for the techie people then!
Say you have a tuned high compression engine or a turbocharged engine that is running either higher boost pressure than std or is using a nasp engine's ignition system and coils etc.
Would fitting iridium plugs maybe help to give better running or stronger sparks in an instance where higher than std cylinder pressures are trying to blow out the spark? Or is that normally a load of old bollocks and even tuned engines with forced induction are rarely able to overcome a std ignition system's ability.
My thinking was it might take less voltage at the plug with a thin iridium electrode to create the spark, and thus take some load off a coil that is close to capacity?
It sounds feasible to me, and would also explain why alot of straightline competition vehicles often have fancy expensive coils, and HT leads?
Acemastr
PostPosted: 12:44 - 23 Dec 2012    Post subject: Reply with quote
Blow out a spark? it's electrical!
2016 Toyota Tacoma Limited
stevo as b4
PostPosted: 13:05 - 23 Dec 2012    Post subject: Reply with quote
I agree it sounds almost rediculous!
But it's aften talked about on alot of forums and tuning websites and by owners of tuned vehicles suffering a high rpm misfire at dyno days etc.
if you think of the pressure inside the cylinder of a petrol engine almost at the top of the compression stroke when ignition is required, then it's much harder to make a spark than it is with the plug outside in the fresh air. I've had it happen with faulty plug leads/spark plug insulators where they will spark ok tested outside in the fresh air, but not inside the engine. A new plug has been fine though.
I don't know the math to work out specific cylinder pressures, but say if a nasp engine is making around 200psi of peak cylinder pressure before ignition, then could a turbocharged engine easily be making 250-300psi at the same point? I just thought that the higher you increase the cylinder pressures above std, the harder you are making it for the spark to occur?
temeluchus
PostPosted: 14:12 - 23 Dec 2012    Post subject: Reply with quote
A high compression motor will stuff more air and fuel between the electrodes so will offer more electrical resistance hence needing more POWA to make a spark.
The main thing with them is the longevity-iridium electrodes last longer.
Yes.
Robbed from wikipedial
The central electrode is usually the one designed to eject the electrons (the cathode) because it is the hottest (normally) part of the plug; it is easier to emit electrons from a hot surface, because of the same physical laws that increase emissions of vapor from hot surfaces (see thermionic emission). In addition, electrons are emitted where the electrical field strength is greatest; this is from wherever the radius of curvature of the surface is smallest, from a sharp point or edge rather than a flat surface (see corona discharge). It would be easiest to pull electrons from a pointed electrode but a pointed electrode would erode after only a few seconds. Instead, the electrons emit from the sharp edges of the end of the electrode; as these edges erode, the spark becomes weaker and less reliable.
temeluchus
PostPosted: 14:16 - 23 Dec 2012    Post subject: Re: Easier starting in the cold and wet Reply with quote
The do require a slightly lower voltage to spark due to the narrow tip. They would certainly help in marginal situations (starting).
The improvement I suspect would be greater on older machines where the electrics are getting a bit tired, in the cold etc. On a modern machine with more pokey ignitions I guess it would make less difference.
Again the main improvement is longevity.
The last post was made 13 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 105.98 Kb
