spark, compression, no go! (dt 125)
MartZ0r
PostPosted: 15:24 - 24 Dec 2012    Post subject: spark, compression, no go! (dt 125) Reply with quote
Hey guys I I picked me up a cheap non runner 1997 dt125r as I finished my last build. This is next years Very Happy
it had no spark but I sorted that out with another coil I had spare now its got a nice bright spark but still cant get it going, I suspected jetting was blocked because it will try and run for a second then shut off and won't go but if you leave it for a few seconds or kick it over without ignition on, then turn it on it will try and go again
so i stripped the carb down cleaned it out but its still doing the same. Before I rip it apart again can anyone give any suggestions? Leak test is next to check the seals
MartZ0r
PostPosted: 16:26 - 24 Dec 2012    Post subject: Reply with quote
Does anyone know off hand the compression range for the dt125 motors? 90-100psi pops in my head
Thinking it might have less compression than I thought.
nightshaddow
PostPosted: 18:23 - 24 Dec 2012    Post subject: Reply with quote
i believe these have a range of between 140 - 180 psi my next dor neighbor has a 2002 re the engine freshly rebuilt and that is at around 175psi
MartZ0r
PostPosted: 20:53 - 24 Dec 2012    Post subject: Reply with quote
bloody hell, i was miles off with that guess then!
thanks mate!
DeeTee
PostPosted: 06:50 - 28 Dec 2012    Post subject: Reply with quote
thanks mate!
110 115psi is about right for a cold DTR engine
Supermotard37...
PostPosted: 06:35 - 31 Dec 2012    Post subject: Reply with quote
Kills switch?
Kick stand switch?
It's a long shot but try poring some fresh fuel down the spark plug hole put the plug back in and the lead on and give it a kick if you've got at least 100psi of compression the bastard should fire I've had dt's and ktms currently still own one there cracking lil bikes
If you have a spark,compression,and fuel getting to it, it should fire no problem by putting some fuel down the head it will at least turn over for a few seconds also try setting the air fuel mix back to the standard settings,i think the orginal main jett is a 220 or 240 dont hold me to that tho Laughing and check the fuses hope this helps Thumbs Up
Ps.sorry for being illiterate Razz
Fuck off..!! "You absolute contraception malfunction"
MartZ0r
PostPosted: 20:18 - 03 Jan 2013    Post subject: Reply with quote
hey, thanks for the posts. finally got round to checking this. sparking fine still. compression seems pretty solid at 135psi cold.
going to have to run a full leak test to check the condition of the seals. not before checking the reedblock though might not be sealing.
cant really be much else Confused
bladerunner
PostPosted: 04:04 - 04 Jan 2013    Post subject: Reply with quote
did it run with ok for a few seconds after you put fuel down the plug hole? if yes then its fuel starvation....if not and it tries to fire once or twice when your kicking it over...could be timing ie sheared woodruff key on the flywheel. Always try a new plug when trying the above.
trevor saxe-coburg-gotha
PostPosted: 06:28 - 04 Jan 2013    Post subject: Reply with quote
You probably know this but there's a dedicated DT forum out there somewhere, and it seems pretty active iirc. Not sure if it's mostly about/for '70s and '80s DTs though. Might be worth a look. Fwiw I love pretty much all the DTs and hope to own at least one one day. Wink
Supermotard37...
PostPosted: 14:04 - 04 Jan 2013    Post subject: Reply with quote
Is it possible that when you've fitted a "coil pack" do you actually mean one or was it the stator plate which,I'm sure there the same thing or I could be retarded but let's just say they were the same thing stator/coilpack is it possible that you when you've fitted the coilpack/stator? you have advance or retarded the engines timing causing it to spark but,not at the right point to make the engine run sufficiently ?
MartZ0r
PostPosted: 20:19 - 04 Jan 2013    Post subject: Reply with quote
hey guys, thanks for the replys. the coil pack is a seperate part from the stator plate. timing is fine and woodruff key is intact. the engine is currently out.
Whats this forum your talking about trevor? i know to a DTR125 one but its dead.
passed leak test at 7psi so seals are ok, decided to pull the inlet manifold off to check reeds and noticed some gold stuff plastered inside the cases?
i have seen a faint bit of this on some engines but surely this shouldnt be peeling like this and what actually is it? Very gritty
https://i276.photobucket.com/albums/kk27/MartZ0r06/WP_000629_zps3a414c19.jpg
https://i276.photobucket.com/albums/kk27/MartZ0r06/WP_000628_zps24a1d951.jpg
PostPosted: 13:09 - 05 Jan 2013    Post subject: Reply with quote
No, not the 125 one - this is for all capacities. It's not *massively* busy - but check out the dates of the replies on the main forum listings page and you'll see that people post quite regularly, and that a lot of stuff is from the last month or even more recent (although I'm afraid you'll have to join before you can see this information - don't worry though as I'm pretty sure approval is either automatic or else if it *is* admin or mod approval it happens quickly):
https://yamahadtclub.proboards.com/index.cgi
Hope someone can help you there. If nothing else, there's some great DT porn in the resto forum. Wink
MartZ0r
PostPosted: 14:59 - 05 Jan 2013    Post subject: Reply with quote
thanks guys. never seen that forum but thanks trev, going to take a look Very Happy
Timing is spot on flywheel end, definitly electrical now though or the carb still needs looking at. going to drop my spare on.
Engine at 135psi and according to some replys on here and a little research on some german sites thats spot on for this engine. (3BN head with lower compression)
I will sort it out Very Happy
bladerunner
PostPosted: 15:16 - 05 Jan 2013    Post subject: Reply with quote
If the cage on the big end breaks down it can leave gold/ bronze bits all over the place but never seen one like that Shocked if its gritty then get it removed as it won't do the piston/bore or crank any favours when it starts flying about as it will! Also if it's metallic then your plug ain't going to last 2 mins!
MartZ0r
PostPosted: 22:01 - 05 Jan 2013    Post subject: Reply with quote
could be onto something then. The crank is in spec according to Haynes and my feelers. crank is nice and tight. Asside from the fact its been run a bit hot if you see the burn marks on the crank pin.
Funny enough there is a lot of bit's so im glad it didnt run. that was my first thought. they were more in the topend though than the bottom. i have cleaned it out now.
i checked the carb again and sure enough it's blocked again.
The last post was made 13 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 90.13 Kb
