Another compatibility issue
The Artist
PostPosted: 14:46 - 25 Dec 2012    Post subject: Another compatibility issue Reply with quote
I have an i5 3570k now Very Happy Which I am happy about.
Now onto the mobo.
I was going to go for a different one but saw this on offer.
https://www.scan.co.uk/products/asus-p8z68-deluxe-intel-z68-s-1155-ddr3-sata-iii-6gb-s-raid-sata-pcie-20-(x16)-atx
Now it says on the CPU spec page
Ivybridge CPU's will work on H61/H67/P67 & Z68 Boards but a BIOS Update may be required for these Motherboards to support them
As the mobo linked to above is a Z68 board, what does that mean I need to do? BIOS update? I remember doing one a while ago but that was when the PC was up and running. If I plug everything together and boot up onto a win 7 dvd, will it still work enough for me to get to do a BIOS update or will it come with a CD or something?
Ta muchly.
oldpink
PostPosted: 15:46 - 25 Dec 2012    Post subject: Reply with quote
I'd suspect you won't need a BIOS update but if you do
you could create a boot CD and load it from that or possibly from a memory stick
now the thing is I'm not sure if you can get to the Bios if it can't use the processor without the update
but it does seem to have a different Bios configuration than normal
here's the the homepage https://uk.asus.com/Motherboards/Intel_Socket_1155/P8Z68_DELUXE/#specifications
it does say it can take your i5
The Artist
PostPosted: 15:47 - 25 Dec 2012    Post subject: Reply with quote
Yeh, after some more research, a BIOS update needs to be done. Will research options without having to borrow a SB cpu first.
Seb
PostPosted: 20:33 - 25 Dec 2012    Post subject: Reply with quote
I've only ever had flat out compatibility issues with AMD board/cpu combinations, and in those cases it generally means the machine will flat out refuse to post until you pop in an old CPU and update the board. Handily a decent portion of motherboards can be flashed from within the bios these days simplifying things massively.
I can't say I've ever needed to flash an intel board for compatibility mind, before you start sweating it, perhaps fire off an email to scan and see if they know. A search around the big hardware forums might be wise too Thumbs Up
2010 Triumph 1050 Sprint ST
Frost
PostPosted: 20:53 - 25 Dec 2012    Post subject: Reply with quote
The last AMD compatibility issue i had just resulted in each of the cores running at 800mhz until i updated the BIOS.
The Artist
PostPosted: 21:52 - 25 Dec 2012    Post subject: Reply with quote
According to various forums, the mobo I have is the GEN 3 which mean it already comes shipped with the latest BIOS update which supports ivy bridge so it SHOULD work.
Their have been issues but I have learnt how to flash a bios just using a usb stick. Thumbs Up
All is well.
Now....what GFX card.
The last post was made 13 years, 74 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.15 - MySQL Queries: 13 - Page Size: 48.42 Kb
