Security chain length?
Barold
PostPosted: 11:59 - 27 Dec 2012    Post subject: Security chain length? Reply with quote
Morning folks
Soon to be new rider, going to get myself a YBR125. Can anyone give some advice on the minimum length of chain I'll need to loop through the frame of the bike and connect to a ground anchor (I can park near enough directly on top of the anchor).
I'll be going with the Torc anchor, chain+lock here: https://securityforbikes.com/proddetail.php?prod=Torc1-P16-x.x-Untouchable
unless someone can give me a good reason not to.
Thanks
esullivan
PostPosted: 12:04 - 27 Dec 2012    Post subject: Reply with quote
I would recommend getting the 2-meter length (if you can afford it). I've bought 1.5-meter chains twice now and regretted it each time. While I can get that length to work, 2m would give me some more options. On my current bike, 1.5m is simply too short to get through anything frame-like. I'm currently looping it through the forks on the front, which would trouble a thief for only a couple of minutes...
Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
P.
PostPosted: 12:12 - 27 Dec 2012    Post subject: Reply with quote
That is a beastly combination.
Do you live in a rough area Laughing
Barold
PostPosted: 13:19 - 27 Dec 2012    Post subject: Reply with quote
Cheers. I was going to go with 1.5, but the extra cost to get to 2m isn't a major issue.
Area isn't too bad, but the bike will be on my drive 10 steps from the road and I don't want it being literally carried off.
Englishman
PostPosted: 13:53 - 27 Dec 2012    Post subject: Reply with quote
I ordered a 1.5m chain from Ghostbikes, but they rang me to say that they only had the 2m one in stock, and would that do for the same price? I'm so glad they sent the longer one as 1.5m is just not long enough unless you're prepared to get your bike into the only perfect place every time.
INSTALLING SUMMER... ████████░░░░░░░░44% DONE. Installation failed.
404 error: Season not found.
Ribenapigeon
PostPosted: 14:21 - 27 Dec 2012    Post subject: Reply with quote
I have a 2m chain biut it goes through the floor of my shed then through an anchor in a concrete block. It still manages to loop through the frame of my bike which is a tall one. They say you should try not to have any chain laying on the ground as it gives a theif something to back up a chisel or bolt cutters so shoirt might be better.
Teflon-Mike
tl;dr
PostPosted: 14:41 - 27 Dec 2012    Post subject: Reply with quote
At home... if you dont plan carrying it about, as long as you can practically get; remember its looped, so chain makes a circle, the diameter of which is 1/pi about 1/3rd the circumference or length the chain. So a 1.5m chain, by the time you have looped it through the anchor, lost a link for the pad-lock and a few cm for the chain width, only stretches roughly 50-60cm. (You MIGHT make it stretch a bit more, but? at best, you are only going to get 70cm from it)
If you have extra chain, you can always loop excess around an extra bit of bike to use it.
IF you are going to carry the chain.... well weight & portability are an important consideration.
Having ace security on the bike at home, where you are probably near it is all well and good, but what about when you park it up in works or college car-park for eight hours a day, every day, or worse, public car-park?
THAT is where its more likely to be nicked from; and bigger hassle having hat and coat under your arm trying to find a bus stop or call a taxi when everything is locked up, than walking out your door to find a 'space' and being able to go back in make a coffee and call the boss to tell them you are going to be late this morning!
For 'away' security, anything is better than nothing; I have a 5m x 10mm cable... its FAR from heavy duty security... as previous comments on the topic..... Paddy could probably chew through it like liquerish! BUT, gives a good one and a half meters or looped reach from an anchor point to bike; can also be lassooed either end so you have single strand of cable between two loops, for further reach, or so that I can park by a lamp-post, lassoo round lamp-post then thread through back wheel, frame then front wheel and lock a last loop back on itself around the forks.... This will deter the average scroat far more than a disc lock, and prevent a casual wheel away, or even lift away; any-one (apart from those with Paddy's Jaws like dentistry!) that is going to have a go, will be coming 'tooled up' for it, which basically means that they would be tooled up for almost any hard security you would use, and its not a matter of stopping them, just slowing them down, and even then....
So.... balancing budget; do you get two locks; one heavy duty 'home' set and a light duty 'away' set, or do you try and make a compromise between the two?
For away? Length is damned useful; a short chain around a wheel to no hard point is worth no more really than an extra disc lock; to be useful it has to be long enough to go round some bit of street furniture, and THERE you cant rely on the convenience of being able to park right over or next to it.
Using a single chain? I found a 3m Hard-Core 'useful', but a bit limiting, a 4m would have meant I could have locked to lamp-post or similar a lot more often.
Currently got Snowie's bike on a 1.5m Almax, straight over ground anchor; that is not long enough to get to or through anything on the frame, apart from a security cleat I actually welded to the front engine bracket..... a 2 or 3m chain would be a lot easier to get around front down tube and back to the anchor.
So for home use only, I suppose 2m-3m; for away, 3-4m better, 5m great, but heavy and awkward!
if that gives you any ideas, I don't know.
Teflon-Mike
tl;dr
PostPosted: 14:47 - 27 Dec 2012    Post subject: Reply with quote
Yeah.... thses kind of things are bandied about a lot; but if a scroat has come tooled up with bolt-croppers, cold chissels, diamond bit saws or whatever..... they are pretty deturmined, and are going to have your bike one way or another, aren't they?
Anything 'extra' you do to make it more difficult is probably not going to do much but slow them down, and what difference does it make, if it takes them two minutes or twenty to get through it all?
What are you going to do in that time?
They are carrying big heavy sharp implements and aren't afraid to use them or break the law?
Even if something alerts you to thier en devours, an alarm, dog, neighbour or whatever?
Would YOU go confront them?
Do you think that would STOP them?
It might..... but bash on the head from a pair of bolt croppers could stop you riding for as long as an insurance claim takes, or more!
Ribenapigeon
PostPosted: 15:15 - 27 Dec 2012    Post subject: Reply with quote
I would also suggest some sneaky security like a personal alarm hooked onto a bit of fishing wire tethered nearby. And take a a look at https://www.pingmee.co.uk its cheap as chips and works and is small enough to hide on the bike. You could get a bike cver as well and again atach a personal alarm to it.
TomGT
PostPosted: 15:27 - 27 Dec 2012    Post subject: Reply with quote
Boozehawk wrote:
I would also suggest some sneaky security like a personal alarm hooked onto a bit of fishing wire tethered nearby. And take a a look at https://www.pingmee.com its cheap as chips and works and is small enough to hide on the bike. You could get a bike cver as well and again atach a personal alarm to it.
£180?!
1992 ZXR 400
Ribenapigeon
PostPosted: 15:43 - 27 Dec 2012    Post subject: Reply with quote
TomGT wrote:
£180?!
Mine cost £60 through amazon plus a free sim card and a top-up
Tef.
In my capacity as an underpaid over worked homeless charity worker I work with exactly the kind of scrotes who steal bikes and just about anything else they can lay their grubby mitts on. I would definatly challange them and with the bent end of a golf club! The last thing they want is to add assualt GBH and affray to charges of breaking and entering and theft charges. The three times that i've had attempts to break into my shed they made so much noise (them trying to break in + alarms) the whole street was woken up and they were chased off. Noise and being identified or getting physically caught are what they are scared of. If there are any Pro bike thieves involved they are most likely up the street in a van waiting for their junkie flunkies to bring them the gear and are going to split as soon as they know the alarm has sounded.
Ribenapigeon
PostPosted: 15:49 - 27 Dec 2012    Post subject: Reply with quote
Woops bad link it should be https://www.pingmee.co.uk
Barold
PostPosted: 16:18 - 27 Dec 2012    Post subject: Reply with quote
It'll be used for commute only (unless I really get the bug and start doing weekend cruises). Work have a fairly secure multi story car park so I'd expect that to be safe enough, and there would be more expensive bikes around it that'd be better targets for thieves). Padlock can do double duty as a disc lock for work use.
The chain is *supposedly* bolt cropper proof, so they'd need to use power tools to get through it. I'm hoping the required noise would put them off.
Saw a post somewhere suggesting you (/a female friend) get the police to give you a rape alarm and then rig that to the bike.
Ribenapigeon
PostPosted: 16:23 - 27 Dec 2012    Post subject: Reply with quote
Theives like "cheap" IE 125's as they are light (easy to lift) and there's a big market for them.
Nothing is bolt cutter proof they will just keep nibbling at the chain. Time is the thing you buy if you get a good quality chain.
You want to try and park where there is plenty of passing people who would notice an alarm going off.
Teflon-Mike
tl;dr
PostPosted: 16:44 - 27 Dec 2012    Post subject: Reply with quote
Yeah, you would hope....
Thing is Learner-Legals are often more valuable than many big-bikes.
They also often have 'less' in built security; and are parked up by novice owners who are rather more nieve about additional security and, aspiring to a bigger bike, think the same, a bigger more valuabe machine is more desirable and more likely to be nicked.
On that score, very wrong; most bike thefts are learner legals.
Market is very strong; buyers often incredibly gullible, and a bike can be 'ringed' incredibly easily, as newbie owners often wont even look at engine and frame numbers or know to, or to look for any other 'tells'.
Learner-Legals also get frequently crashed by learners who dont know how to ride them very well, or thrashed or neglected to death, as they dont know how to look after them very well either.
A ten year old 125 is probably worth more as parts than it is as a running bike, and some models of more fancy 125 like an YZF-R125 for instance are probably worth more as parts than they cost in the show-room 'new'; to feed the market for lads on third party only insurance who blow them up or smash them up and cant afford to fix them.
No trade secret; buy a £10K r6 chances are you will have the dealer fit a tracker, or data-tag or alpha-dot system before you even take delivery; its a small fraction of the purchase price. Less likely you will go to such measures on a £4.5K 125, even less a £2.5K one, less still a secondf hand one.
Consequently, the parts are likely to be far more easily fenced without redress.
They will also be smaller and lighter and, in a market with more of any particular model in existance, less easy to identify.
Smaller & lighter, also means easier to lift & pocket.
Try lifting a Gold-wing into the back of a van! You need a few efty blokes and a BIG van!
Little CG or YBR? Go in the back of people mover with the seats out! And a fourteen year old can probably lift it there on thier own!
Parking at work? Seen regularly in the same spot, left unattended, its just as likely to be lifted from there as it is your home.
Still worth a little bit of 'added' if you can use it.
Booze..... rather you than me with the golf-club!
My luck, I'd be the one being 'done' for GBH, in that peculiar perversion of our justace system.... or the one suffering from it!
I dont think I could ever suggest any-one try be a have-a-go-hero... as you said, likely to be junkies stealing to get thier fix, and off thier heads on wiz or smack, I'd not want to risk it! (Though bent handlebar by the back door implies otherwise! Wink )
mcfcbiker
PostPosted: 17:20 - 27 Dec 2012    Post subject: Reply with quote
Almax do their Immobiliser IV which is rated as being bolt cropper proof, there some vids online showing some of the other chains on the market being cut with industrial croppers. They do a 2.5m length aswell.
My friend has one on his bike and its big and heavy so its perfect for the stay at home style chain.
Current Bike = 2011 Triumph Street Triple R
Previous Bikes = Yamaha YBR 125, Honda CBF 125, SYM XS 125K
PostPosted: 19:43 - 27 Dec 2012    Post subject: Reply with quote
Who was it that was doing chains with a big ring on the end so that you can loop the chain through itself and effectively double the length of it? Thinking
bridgedino
PostPosted: 19:52 - 27 Dec 2012    Post subject: Reply with quote
1.5m for me.
sits nicely diagonally over my shoulder ~ waist for carrying whilst riding and has so far proved the perfect length for locking to posts and racks
J.M.
PostPosted: 20:22 - 27 Dec 2012    Post subject: Reply with quote
bridgedino wrote:
1.5m for me.
Wouldn't like to regularly carry a chain around my torso Sick
I use a fairly beefy 1.5m chain. Wouldn't want anything shorter. Loops nicely around the tail of the bike to carry and loops on to objects when parked up. Longer than that would be nice... but you get in to the troubles of carrying it and going "I have too much chain! How do I keep it all off the floor?!"
Best security tip aside from buying a great chain... always park next to a nicer bike.
2004 R1 & 2018 XSR900
i.p.phrealy
PostPosted: 20:52 - 27 Dec 2012    Post subject: Reply with quote
I use a chain through the back end of the frame and round a metal fence post, also a cycle D Lock through the front wheel either side of the forks. at £20 for the D lock it's a nice, light, extra deterrent.
but it won't stop the local scrotes from trying to nick it, and the fellas who know how to nick bikes will still have it away in minutes.
luckily for me it's a 6 year old, cheap Chinese 125, so even it's resale value for parts will be piss poor.
Ribenapigeon
PostPosted: 22:44 - 27 Dec 2012    Post subject: Reply with quote
A few of the places I park up other bikers leave a chain there rather than take it home. So you could have two chains one for home one for work.
J.M.
PostPosted: 23:18 - 27 Dec 2012    Post subject: Reply with quote
I remember someone on here posting about somebody who had a heavy duty chain left somewhere. A thief cropped one of the links and replaced it with a fat zip-tie.
Ribenapigeon
PostPosted: 23:25 - 27 Dec 2012    Post subject: Reply with quote
Sneaky
Joncrete Cungle
PostPosted: 23:39 - 27 Dec 2012    Post subject: Reply with quote
Pragmasis do on their 13mm chain.
https://securityforbikes.com/products.php?cat=Chains+%28without+padlocks%29
Barold
PostPosted: 07:41 - 28 Dec 2012    Post subject: Reply with quote
So if I may summarize:
1.5m chain will do the job but more is better.
Added security of an alarm + disc lock.
Something fairly substantial at work (I'll check out the security there properly - think the level with bikes on requires id card to access)
@mcfcbiker Almax are the other brand I'd consider, but I haven't yet spoken to them about pricing a package deal. I'd hope 16mm would be almost as good a deterant as 19mm, and as both thicknesses are cropper proof anyone who can go through one can do the other in a little more time.
@ J.M. agreed, coming off with a length of chain around you is going to be extra painful
Thanks to all for the advice
The last post was made 12 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 138.95 Kb
