Yamaha SR125 - Electric Starter Issue
Doobrey
PostPosted: 19:48 - 07 Nov 2004    Post subject: Yamaha SR125 - Electric Starter Issue Reply with quote
Can anyone help?
I insert key
I press the starter, and a demented bumble bee buzzes around under the seat, no ignitiion...
Suggestions are welcome, as are PDF versions of the haynes manual!
HELP!
instigator
PostPosted: 19:49 - 07 Nov 2004    Post subject: Reply with quote
you using the choke then?
*gulp*....just covering all bases firstly Wink
Davo
Davo To The Rescue!
PostPosted: 19:53 - 07 Nov 2004    Post subject: Reply with quote
Have you checked the battery? If it's buzzing as opposed to turning that's the first place I'd look.
THCi
PostPosted: 21:32 - 07 Nov 2004    Post subject: Reply with quote
Tried bumping it? Is it sparking?
Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
"We're not gonna die. We can't die, Bendis. You know why? Because we are so...very...pretty. We are just too pretty for God to let us die."
Doobrey
PostPosted: 22:47 - 07 Nov 2004    Post subject: Reply with quote
Tried the choke... not that....
It has been standing for about 3 weeks....
How exactly could I check for sparks? How could I "bump Start" it?
Thanks for the advice already guys.
Doobs.
Doobrey
PostPosted: 22:48 - 07 Nov 2004    Post subject: Reply with quote
Haven't checked the battery...
Any suggestions on how I could do that?
I have a car, could it be like jump starting a car with jump leads?
Doobs.
THCi
PostPosted: 23:19 - 07 Nov 2004    Post subject: Reply with quote
NO, dont jump start from a car. A car (dependant on model) is 12, 125s are generally 6volts. You could have some interesting times jumpstarting from a car.
To bump a bike, its exactly the same as a car. Stick it in first, pull the clutch in, roll it down a slope. Let the clutch out, slowly. Make sure the ignition is on, as well as the fuel tap, put the choke on.
Repeat the rolling bit until it sparks, then pull the clutch in again. If all goes well it should tick over. Dont open the throttle or the chances are you'll flood it. Its a 125 remember! Wink
To check if its sparking, remove the plug, reconnect it to the lead, and wedge it onto the engine. Try starting the engine, as normal (it aint gonna work! Wink), if its sparking you'll see an arc of electricty jump between the contacts on the spark plug. If it doesnt its either an electronics problem, a duff spark plug or a duff lead.
dodsi
Dirty Carny
PostPosted: 02:25 - 08 Nov 2004    Post subject: Reply with quote
how old is your SR, mine is 2001 on a 51 plate and no problems...yet...except a rear tyre...and brake pads...and oil change...
Doobrey
PostPosted: 10:28 - 08 Nov 2004    Post subject: Reply with quote
My SR 125 is an S Reg...not sure of the exact year..
I am thinking of investing in a battery charger....
Doobs.
Doobrey
PostPosted: 18:20 - 08 Nov 2004    Post subject: Reply with quote
Are you sure it's 6 Volt?
checking on the web, a replacement battery for an SR125 is a 12V variety...
Doobs..
THCi
PostPosted: 00:04 - 09 Nov 2004    Post subject: Reply with quote
Id imagine that its 6, check the battery. Depending on the number of cells, IIRC 12volters have 6, 6volters have 3.
TheShaggyDA
Repost Police
PostPosted: 00:07 - 09 Nov 2004    Post subject: Reply with quote
Doesn't the SR125 have a kick start too?
mchaggis
PostPosted: 00:25 - 09 Nov 2004    Post subject: Reply with quote
Bump starting is better carried out in second than first as you don't have to push it so hard, just a little faster. Even then I still managed to slide the back wheel letting the clutch out pushing it in second. It started fine though.
I'm pretty sure that the SR125 is a 12 volt bike though. 6V systems are a little outdated nowadays.
I must not be a troll...
Mmmm, Guinness
Doobrey
PostPosted: 14:54 - 09 Nov 2004    Post subject: Reply with quote
I have removed the battery and checked.
My "battery" knowledge isn't the best, to be honest, but looking at it, it has 6 yellow bits on the top, which I assume is where you fill it up? Therefore my assumption is that this is a 12V battery?!?
Also, do you think that the acid that leaked all over my garage floor when I titlted the battery on the site is a problem >!< (JOKING - I know it's a problem, and it did seriously leak Acid!)
Doobs.
THCi
PostPosted: 21:30 - 09 Nov 2004    Post subject: Reply with quote
Er, leaking acid is a problem. For one its flammable, if its sitting near your engine, you're gonna be a 125 fireball if it catches.
Nevermind about all the 'benefits' to your health it has, like, for example, death.
Look into a new battery mate.
Haggis > Youre probably right, never had to bump mine. And (knock on wood) I never will! Wink
Doobrey
PostPosted: 23:06 - 09 Nov 2004    Post subject: Reply with quote
So a new battery it is!
Doobs..
Crying or Very sad
THCi
PostPosted: 00:16 - 10 Nov 2004    Post subject: Reply with quote
Can you get it bumped though?
Doobrey
PostPosted: 13:16 - 10 Nov 2004    Post subject: Reply with quote
I tried to bump it (lack of experience on that front)...
I used the advise given in the forums, put it into first, ignition on, choke on, don't pull throttle....ran down the hill, release clutch slowly and nothing...
I think the battery is so dead that it won't even jump start - the lights don't even come on anymore, although they did when I first had the problem.
Can anyone confirm the 12V vs 6V question for me? Considering the acid leaking scenario, I need to invest in a new one!
Doobs.
THCi
PostPosted: 20:11 - 10 Nov 2004    Post subject: Reply with quote
Go with 12volt mate, if your still worried, take the headlight apart and see what it says. If 12v, go with 12v.
Doobrey
PostPosted: 11:39 - 11 Nov 2004    Post subject: Reply with quote
Okay....
Bought myself a 12V battery charger, realising that the acid leaking from the battery was from the "inbuilt" overflow device on the actual battery....
Charged the battery
Put it into the bike
Ignition on
Press starter - Bumble bee gone, starts to turn over...WOOT
Tried again....realised that choke really needs to be out for this to work....sounded more promising (Can't make chug chug noises on here very well)
Tried again....battery dying now....hum...
AH!...Helps if the petrol is turned to the on position...
Tried again....battery dead...DOH!
Recharged battery.....plugged it in, choke, petrol, ignition...starter....
After about 30 seconds of pain....VROOOM>....VROOM>......
Me is well happy. I would just like to thank everyone for the assistance.
Doobs.
loply
PostPosted: 20:57 - 14 Nov 2004    Post subject: Reply with quote
I enjoyed your very graphic descriptions of getting the bike to start.
Anyone else think bikes should come with a kickstart as a backup?
Doobrey
PostPosted: 17:44 - 15 Nov 2004    Post subject: Reply with quote
For some strange reason.....me?
The last post was made 21 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 115.21 Kb
