| Doobrey |
 Doobrey Nova Slayer
| instigator |
 instigator Super Spammer
 Posted: 19:49 - 07 Nov 2004 Post subject: |
you using the choke then?
*gulp*....just covering all bases firstly  |
| Davo |
 Davo Davo To The Rescue!
| THCi |
 THCi Nearly there...
| Doobrey |
 Doobrey Nova Slayer
| Doobrey |
 Doobrey Nova Slayer
| THCi |
 Posted: 23:19 - 07 Nov 2004 Post subject: |
NO, dont jump start from a car. A car (dependant on model) is 12, 125s are generally 6volts. You could have some interesting times jumpstarting from a car.
To bump a bike, its exactly the same as a car. Stick it in first, pull the clutch in, roll it down a slope. Let the clutch out, slowly. Make sure the ignition is on, as well as the fuel tap, put the choke on.
Repeat the rolling bit until it sparks, then pull the clutch in again. If all goes well it should tick over. Dont open the throttle or the chances are you'll flood it. Its a 125 remember!
To check if its sparking, remove the plug, reconnect it to the lead, and wedge it onto the engine. Try starting the engine, as normal (it aint gonna work! ), if its sparking you'll see an arc of electricty jump between the contacts on the spark plug. If it doesnt its either an electronics problem, a duff spark plug or a duff lead. ____________________ Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
"We're not gonna die. We can't die, Bendis. You know why? Because we are so...very...pretty. We are just too pretty for God to let us die." |
| dodsi |
 dodsi Dirty Carny
| Doobrey |
 Doobrey Nova Slayer
| Doobrey |
 Doobrey Nova Slayer
| THCi |
| TheShaggyDA |
 TheShaggyDA Repost Police
| mchaggis |
 mchaggis World Chat Champion
 Posted: 00:25 - 09 Nov 2004 Post subject: |
Bump starting is better carried out in second than first as you don't have to push it so hard, just a little faster. Even then I still managed to slide the back wheel letting the clutch out pushing it in second. It started fine though.
I'm pretty sure that the SR125 is a 12 volt bike though. 6V systems are a little outdated nowadays. ____________________ I must not be a troll...
Mmmm, Guinness
| Doobrey |
 Doobrey Nova Slayer
| THCi |
 Posted: 21:30 - 09 Nov 2004 Post subject: |
Er, leaking acid is a problem. For one its flammable, if its sitting near your engine, you're gonna be a 125 fireball if it catches.
Nevermind about all the 'benefits' to your health it has, like, for example, death.
Look into a new battery mate.
Haggis > Youre probably right, never had to bump mine. And (knock on wood) I never will!  ____________________ Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
| Doobrey |
 Doobrey Nova Slayer
 Posted: 23:06 - 09 Nov 2004 Post subject: |
So a new battery it is!
Doobs..
| THCi |
| Doobrey |
 Doobrey Nova Slayer
| THCi |
| Doobrey |
 Doobrey Nova Slayer
| loply |
 loply World Chat Champion
| Doobrey |
 Doobrey Nova Slayer
The last post was made 21 years, 222 days ago. Instead of replying here, would creating a new thread be more useful? |
