Cornering help/advice
Speedysidders
PostPosted: 23:03 - 28 Dec 2012    Post subject: Cornering help/advice Reply with quote
This might sound weird but I'm sure it can't only be me, so I have come for some advice Shocked
Basically, when taking a corner on the left I'm absolutely fine and can hold decent corner speed with a decent line (or so I have been told), however when it comes to a right hand bend I'm like an old age pensioner and struggle in comparison and it's stressing me out.
I thought it could be to do with having an accident on a right corner however I have remember that I also do this when racing motocross and enduro. Embarassed Crying or Very sad
Any help/replies is greatly appreciated! Surprised Thumbs Up
A Pint of sweat saves a gallon of blood.
Spangle2k4
PostPosted: 23:08 - 28 Dec 2012    Post subject: Reply with quote
*grabs popcorn* Silence
Sable
PostPosted: 23:11 - 28 Dec 2012    Post subject: Reply with quote
Odd question, have you checked your wheels balanced?
My kwak had a slightly off balance front wheel, and I happily dropped into left hand bends, but just couldnt seem to go right. Same feeling again on the Sinnis when i dropped it recently and twisted forks in the yoke slightly. Just with the kwak I didnt know what was wrong until someone pointed it out too me Embarassed I thought I was being an old woman for first week of riding it.
J.M.
PostPosted: 23:13 - 28 Dec 2012    Post subject: Reply with quote
Having an accident on a right handed corner would explain it. What you're experiencing will be a mental block rather than lack of ability. You essentially see the situation and your brain is sort of scared of it, as a result you take it with extra caution.
I always tell people to get back on their bike ASAP after falling off/having an accident because it helps to stop these mental roadblocks forming. The longer you've had a roadblock in your mind the harder it'll be to remove!
Personally I would suggest the following:
- Find a route that you know well, in good(ish) conditions
- Come around the corner as a left hander and note down what speed you're doing
- Come around the corner again as a right hander and note down the speed that you're doing
The above step is simply so that you don't try and overcook the corner. If you're left speed is good then the corner can be safely taken at that speed!
- Say that your left speed was 50mph and your right speed was 30mph
- Approach the right hander corner again, this time set the throttle to 35mph. Don't break and don't let off the throttle. Just hold it steady. Go around the corner at 35mph.
- Keep doing this until you feel comfortable with that speed, then increase your speed by another 5mph.
- Do so until you reach 50mph
Now you kind of realise "I can do right handers, there's nothing wrong with them!" and it removes the possibility of approaching the corner at 50mph, panicking and crashing.
2004 R1 & 2018 XSR900
Speedysidders
PostPosted: 23:18 - 28 Dec 2012    Post subject: Reply with quote
It's definitely not the bike, as it's the same on any bike but thanks for the suggestion anyway Thumbs Up
It must be due to my mind, and I will try the corner thing to try and get my mind over it, as soon as I had my accident I rode back to the corner and rerode the bend, might sound strange but I think it helped, however I'm going to try what you said with taking the corner both ways!
Teflon-Mike
tl;dr
PostPosted: 23:26 - 28 Dec 2012    Post subject: Reply with quote
People often have a cornering bias, though more often an aversion to left handers. (at least in the UK where we drive on the left)
That's quite easy to explain; entering a left hander, look left, you have pavement, houses, hedges whatever limiting field of view into and through the bend. They are more confident on right handers, becouse when you look right, you usually have half a road of clear space to that side of you, and you can see further in and through the corner.
Right Corner aversion; the sight line theory doesn't work, but, reason is often the road camber.
Roads aren't flat, they are humped in the middle and slope to the gutters so water runs off either side. So going straight we are usually actually riding on a suirface tilting slightly to the left, which, like the banking on a race track, would favour left handers but disfavour right handers.
Curiousely, there is a bit of an anomolouse camber effect in left hand eversion, in the over centering of the tyre contact patch, as you go from bike upright the tyre tilted under it the wrong way, to bike tilted perpendicular to the road, before tyre tilting same way in relation to the corner, that can give some slight 'flop' effects as you turn in.
However.... it is almost always some sort of confidence issue. And... having an off wont have helped that.
Speedysidders
PostPosted: 23:32 - 28 Dec 2012    Post subject: Reply with quote
Thanks for the reply, it seems it must be a confidence issue, however the camber of the road seems an interesting point! Never really thought about that Doh!
J.M.
PostPosted: 23:34 - 28 Dec 2012    Post subject: Reply with quote
It made a notable improvement on my cornering skills, although they're still not brilliant.
There was a corner that I used to take regularly (although now never see) that I would only take at 50 mph. I tried the above a few times. Set the throttle to 55, got round easy. Set it to 60.. okay.. a little scary, but I got round easy.
The worst part for me is that I used to take that corner at 70 on my 125! I just couldn't get past the mental block in my mind to do it on my faster bike. The issue for me was on my 125 I knew I could only be doing 60-70 tops. On the big bike there was something else to consider... I had to slow down before the corner... I had to make sure that I wasn't still going too fast. This resulted in me always slowing down too much.
The fastest I ever took that corner was once when some guy on a Speed Triple overtook me and I followed him, matching his speed. He took that corner at 90. I took that corner at 90 and the bike could still have handled more! Was just about getting past the road blocks in my mind Smile I couldn't continue taking it at 90 after that, mind you.
Another important thing to note is to make sure that you're looking in the right place! If you look in the wrong place it'll seriously hamper your cornering abilities Smile
Speedysidders
PostPosted: 23:41 - 28 Dec 2012    Post subject: Reply with quote
With looking in the correct place, is there any advice on this you could give, as I often find myself looking 10-15 feet infront of me and I'm almost certain I shouldn't be riding like I'm in a little box Embarassed
On left handers I pretty much disregard the road within 150 meters of me and ride 'through' the bend but I struggle with this the other way
When I ride with my dad I'm alot better, it's just the majority of the time I'm alone Crying or Very sad
bikertomm
PostPosted: 23:45 - 28 Dec 2012    Post subject: Reply with quote
Went out on the bike last week for the first time in about a month.. I generally do struggle with corners, or at least in my head I do.
Would love to learn more on a trackday or even (bikesafe?) perhaps take a rideout with someone you know or even an instructor so ask for advice.
But definitely try and improve things for yourself first, it most definitely can be done!
Good luck
J.M.
PostPosted: 23:48 - 28 Dec 2012    Post subject: Reply with quote
Definitely not 10-15 feet ahead of you! If anything, that'll be your issue rather than a mental road block like I described.
It makes sense that you ride better with your dad, too. When you ride with your dad you look at Him rather than 10-15 feet ahead of you. As a result when he goes around the corner, you're looking at him so your head looks through the corner - which is correct - so you're able to take the corner at speed more comfortably.
What you need to do is "Look where you want to go", see if this video explains it at all:
https://www.youtube.com/watch?v=YAngpbsWFC0
(Note: I only watched a few seconds of the video so I can't say it'll be a great one)
Speedysidders
PostPosted: 23:50 - 28 Dec 2012    Post subject: Reply with quote
Ok mate, thanks a million for your help, it's much appreciated. Thumbs Up Thumbs Up
Slacker24seve...
PostPosted: 23:52 - 28 Dec 2012    Post subject: Reply with quote
Try some roundabout surfing on a bypass. They go right, it's difficult to get lost and you can progressively build your speed up.
Banger rallies are ace
Nick_Giles
PostPosted: 23:53 - 28 Dec 2012    Post subject: Reply with quote
as I often find myself looking 10-15 feet infront of me :
I am not a very experienced biker but I would say that is your problem.! It's a habit to get out of ASAP or more than your cornering speed will be a problem to you.
Nick.
PostPosted: 23:57 - 28 Dec 2012    Post subject: Reply with quote
I have an issue with right hand corners also Thumbs Up
No idea why, I've tried roundabout surfing. Left turn knees on the floor are probably far easier than rights for me. So much easier I've only got holes in the left side of my textiles and chicken strips are usually totally gone.
Fuck knows why.. Neutral
J.M.
PostPosted: 23:58 - 28 Dec 2012    Post subject: Reply with quote
I loved the tyre on your TTR Mr. Green
Even though you were still miles faster through corners than I was.
PostPosted: 00:00 - 29 Dec 2012    Post subject: Reply with quote
Oh yeah.. the tyre had actually worn down so much on the left and not the right, the right edge + 1-2cm in was raised and pretty much untouched tyre.
PostPosted: 00:01 - 29 Dec 2012    Post subject: Reply with quote
Look at the vanishing point of the corner where the two kerbs seem to meet because that is where you want to be going. The sharper the corner, the closer that will be. On a totally straight road, it will be on the horizon.
Approach right handers in the gutter and approach left handers in the crown of the road
weasley
PostPosted: 00:33 - 29 Dec 2012    Post subject: Reply with quote
Another reason you may not be as good on right handers is if you hang off or shift over to that side. When you do so you close up that arm a bit and reduce the finesse you have on the throttle; I have exactly the same situation.
yaigi
PostPosted: 01:20 - 29 Dec 2012    Post subject: Reply with quote
It's definitely not just you. I had an off round a roundabout on my 125 and for ages after that, especially in the wet, I went round roundabouts like an old lady. I eventually built myself up and up, but never did get to the confidence level I was at before my off before I sold my 125. Then I got my first big bike, and I thought, well, this is just going to take me backwards.... but it actually has had the opposite effect - I actually feel MUCH more confident going around corners (both left and right, but still less so on right) on my Fazer.
I'm just trying to gradually build on that confidence. It's good that you have your Dad to go out with, that will help - going out with Mr Yaigi who also has a Fazer helps me, cos I can see that the bike is perfectly capable of doing those speeds around those corners. The only road we're both (yep, even Mr Yaigi with 9 years riding experience) a bit iffy on is the one we live on - it's full of grit and rocks from the quarry, wet all year round in one place, muddy, uneven, and twisty. It's the most awful road to ride on and I've had SO many cars up my arse but I'm damned if I'm getting that close to home and coming off, so they can just bloody wait Very Happy
What bike are you riding? Are you on a 125? I find them to feel far less stable.
TheSmiler
PostPosted: 04:24 - 29 Dec 2012    Post subject: Reply with quote
Agree with what has already been said in the thread by Jm an Mike, personally I don't like doing left handed bends on country roads. Perfectly fine in the city or on duals as they are easier and I can judge them better.
Think mine was mainly something to do with an accident I had on the corporal and breaking the head stock lock, so the handlebars turned all the way to touch the tank. That as well as not being able to judge them easily, right handers you can see around the corner or going into the corner at least.
illuminateTHE...
PostPosted: 04:28 - 29 Dec 2012    Post subject: Reply with quote
However.... it is almost always some sort of confidence issue. And... having an off wont have helped Shocked that.
Shocked
Never ceases to amaze me
Theory: PASSED Module 1: PASSED Module 2: PASSED 12/2012!!!
yzf r125 [SOLD] sv650 [CURRENT]
Killer Rat
PostPosted: 10:55 - 29 Dec 2012    Post subject: Reply with quote
Makes me wonder if it is something in your brain telling your body that it is not the strongest side?
I'm lefthanded and leftfooted, my brain does not like me doing anything on my right...It could be as simple a solution as this.
No! No more talk! We go in! We kill! Kill! We kill 'em! They kill us, we kill them! Kill 'em! Kill 'em! Kill! Kill!
_______________________________________________________
cbf125 09', cbt passed 4/6/2010 - 28k miles - 1 major breakdown (stator)
nightshaddow
PostPosted: 11:04 - 29 Dec 2012    Post subject: Reply with quote
I used to suffer a similar problem to yourself and again thought it was something in my subconscious never had it with my first bike (customized cb 125) but when i bought my cagiva i suffered this problem too,
i found (in my case) it was the simplest mechanical problem, as i adjusted my rear wheel for the chain i was getting the rear wheel slightly out of alignment, i could corner like a boss one direction even almost getting a knee on the w8 but the other direction was terrible,
in short took it to the garage they pointed out my obvious mistake and now i dont find this problem
evoboy
PostPosted: 14:03 - 29 Dec 2012    Post subject: Reply with quote
Wait till it warms up and the roads dry out.
APT Motorcycles
The last post was made 13 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 137.58 Kb
