Fitting Hand Guards
bridgedino
PostPosted: 14:56 - 31 Dec 2012    Post subject: Fitting Hand Guards Reply with quote
Hi,
Started to fit my hand guards today, only when I trimmed off the end of the throttle grip to insert the bar-end I found it wasn't a hollow hole.
Instead I found what I assume is the plastic throttle housing body which rotates.
So does anyone know if it is possible drill to open up the end of it and slip the bar-end in?
Or is it likely to turn not a can of worms?
Thanks
bladerunner
PostPosted: 15:01 - 31 Dec 2012    Post subject: Reply with quote
Would think its just the end of your throttle tube. Why not undo the switch gear and take a proper look!
bridgedino
PostPosted: 15:10 - 31 Dec 2012    Post subject: Reply with quote
Thanks. Yeah it's the throttle tube I'm sure but im un sure if it can be opened up at the end or not.
Therefor how do you think i can I go about fitting my guards?
PostPosted: 15:36 - 31 Dec 2012    Post subject: Re: Fitting Hand Guards Reply with quote
As above - pretty sure it's just the end of the throttle tube.
Get the throttle tube off completely anyway to be sure and to make sure what's behind it is ok.
bladerunner
PostPosted: 16:23 - 31 Dec 2012    Post subject: Reply with quote
If your fitting guards then you don't need the end of the tube, so either drill it or cut it off.
bridgedino
PostPosted: 16:48 - 31 Dec 2012    Post subject: Reply with quote
Thanks guys, job done before it got dark. Trimmed of end of tube with trusty junior hacksaw.
bladerunner
PostPosted: 17:06 - 31 Dec 2012    Post subject: Reply with quote
PICS !!! Wink
bridgedino
PostPosted: 17:18 - 31 Dec 2012    Post subject: Reply with quote
Lol I will do, once it gets light again
The last post was made 13 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.57 - MySQL Queries: 13 - Page Size: 53.77 Kb
