speedfight 3 ac can i have a bit of advice am new to riding
dan3315
PostPosted: 22:32 - 01 Jan 2013    Post subject: speedfight 3 ac can i have a bit of advice am new to riding Reply with quote
hi everyone just brought a bike a month to go as using a car to go work just cost more lol
basically bike is a 50cc ac about 3500 miles on a 2010 plate
it rides fine until when i get to a hill i know there ment to be slow going up hill but this goes so slow i have to stop it feels like it just dies proper it wasnt doing it when i first got it would struggle about 12 - 16 mph lol then go but lately just had to stop it feels like it need to drop a gear just need some advice on what to do im pretty good with car engines had them apart and together again just really racking my head do rollers cause this problem theres one other thing is well i get a ting noise from it when idle nothin major like what is that lol ar as i know it hasnt been de- restricted and oringnal exhaust cheers for you time peeps
cheers
jimspeed
PostPosted: 22:35 - 01 Jan 2013    Post subject: Reply with quote
Hi it could be so many things, from compression in the engine to sticking variator rollers or torque spring, or the belt/clutch slipping. I would take it to someone who knows the bikes to be sure as otherwise you could just keep trying things which gets expensive
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
CaNsA
PostPosted: 22:37 - 01 Jan 2013    Post subject: Re: speedfight 3 ac can i have a bit of advice am new to rid Reply with quote
dan3315 wrote:
hspeedfight 3 ac can i have a bit of advice am new to riding
Firstly I would advise you to not use "am new" but to use "I'm new" instead.
Secondly I would advise you use a spellchecker.
Thirdly I would advise you not to ride like a tool. Thumbs Up
dan3315
PostPosted: 22:43 - 01 Jan 2013    Post subject: Re: speedfight 3 ac can i have a bit of advice am new to rid Reply with quote
how do i ride like a tool and secondly just typing fast and messing up
sure you make mistakes
CaNsA
PostPosted: 22:49 - 01 Jan 2013    Post subject: Re: speedfight 3 ac can i have a bit of advice am new to rid Reply with quote
cheers
BCF, it's not BBM.
https://www.wikihow.com/Use-There,-Their-and-They%27re
"meant" not "ment"
"nothing" not "nothin"
andys675
PostPosted: 00:27 - 02 Jan 2013    Post subject: Reply with quote
I did a lot of work on speedfight 2's in a previous job, the best advise I can give for riding a restricted 50 uphill is make sure you're flat out when you start from the bottom
might be an idea to look at the rollers though!
Supermoto_Fan
PostPosted: 00:38 - 02 Jan 2013    Post subject: Reply with quote
I used to had a speedy 2 and I would suggest popping off the transmission case and variator and looking at the rollers, they may be old and worn and need replacing, only a 15 minute job
mospeed
PostPosted: 00:40 - 02 Jan 2013    Post subject: Reply with quote
Check the belt too, stretched or worn out belt = lack of power to final drive
Supermoto_Fan
PostPosted: 00:49 - 02 Jan 2013    Post subject: Reply with quote
+1
Replacing my belt with a new Polini one gave my bike a new lease of life, gaining an extra 5mph at least, which, when your on a moped means alot! Haha Wink
dan3315
PostPosted: 21:20 - 02 Jan 2013    Post subject: cheers Reply with quote
cheers for the help will check them on the next dry day lol any special tools required??
Supermoto_Fan
PostPosted: 21:26 - 02 Jan 2013    Post subject: Reply with quote
Sockets and ratchet to undo the transmission case and then you will be able to tell if the belt is stretched by eye really, variator is held on by one nut although you may need a variator holding tool for that one
The last post was made 13 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 69.14 Kb
