Best way to measure DB of bike
grant965
PostPosted: 10:37 - 02 Jan 2013    Post subject: Best way to measure DB of bike Reply with quote
Hi all, what is the most accurate way of measuring how loud my exhaust is whilst riding. I have only been using the app on my phone and I had it in my outside pocket with the front of the phone (and presumably the mic) facing outwards.
It came back at 101, but thought it would be a lot higher as that is still within the legal limit?
Grant
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
PostPosted: 10:54 - 02 Jan 2013    Post subject: Reply with quote
has to be measured behind the bike, approximately 50cm from the exhaust outlet at an oblique angle.
That's what they do at MSV circuits anyway.
Ja7
PostPosted: 11:07 - 02 Jan 2013    Post subject: Reply with quote
Is that a free app ?
Formerly known as
P.
PostPosted: 11:23 - 02 Jan 2013    Post subject: Reply with quote
That, you'll need 2 people, I think they ask for 2/3 max revs too.
Was awesome at Brands, they said idle it at just over 4000rpm for me.
Came back, said try 3000rpm.
Said. Mmmm it will have to do but if you get flagged please come off, its quite far over the limit. Laughing
Ariel Badger
PostPosted: 11:35 - 02 Jan 2013    Post subject: Reply with quote
Phone apps are just for fun, proper sound testing is done with serious kit and as said above at 2/3 revs at about half a meter and at an oblique angle.
Most tracks work on 105 Db max, Brighton Speed Trials are 110 Db.
They also put a sort of spring on your can during the test that vibrates, this may or may not measure your revs.
However the law says that your pipe should be no louder than factory (or it used to).
supZ
PostPosted: 12:10 - 02 Jan 2013    Post subject: Reply with quote
5000 for litre bikes and 7000 for 600s is how they normally do it at trackdays..
CBR954RR - Daily toy
CBR600RR - Trackbike
Formerly known as
P.
PostPosted: 12:17 - 02 Jan 2013    Post subject: Reply with quote
Nice to know, ta! Thumbs Up
i.p.phrealy
PostPosted: 13:22 - 02 Jan 2013    Post subject: Reply with quote
Ride Faster, noise will be behind you! Innit! Laughing
oh, and on a serious note, Maplin used to do a fairly accurate hand held decibel meter, don't know if they still do.
andyscooter
PostPosted: 17:57 - 02 Jan 2013    Post subject: Reply with quote
we use the maplin decibel meter at the track
we work to 84 at a range of 30cm behind the bike on the 125s and a bit higher on the 250s
most four stroke 450s had to be banned as they were too loud and we were getting 140 odd decibels at a range of 50 metres and then the enviromentel health got called and we lost ten meets a year
Ariel Badger
PostPosted: 18:16 - 02 Jan 2013    Post subject: Reply with quote
I would sugest your meter was crap or you were doing it wrong 140 Db is a jet aircraft engine at 30M this chart
Red Devil
PostPosted: 18:28 - 02 Jan 2013    Post subject: Reply with quote
They actually do it right at the exhaust most places now and at the below revs:
Thundersport Pre-National Sport 600 2014 #92
EMRA Roadstock 600 2013 - 3rd
www.facebook.com/MattJohnstonRacing
Acemastr
PostPosted: 18:59 - 02 Jan 2013    Post subject: Reply with quote
According to that 10db is 'double' the loudness, I was always under the impressions that it was 3db(or 5, one of those)?
2016 Toyota Tacoma Limited
Ariel Badger
PostPosted: 19:08 - 02 Jan 2013    Post subject: Reply with quote
click
bazza
PostPosted: 22:12 - 02 Jan 2013    Post subject: Reply with quote
The dB measurement scale is logarithmic, not linear.
PostPosted: 23:00 - 02 Jan 2013    Post subject: Reply with quote
No, they don't. The thing they stick on the end of the exhaust is a measuring stick, the actual microphone is on the other end.
sidewinder
PostPosted: 23:20 - 02 Jan 2013    Post subject: Reply with quote
I have a decent idea for once Very Happy Might be worth popping into a decent music shop they will have quality db meters to measure any kit they hire out .pop them a few quid i'm sure they will take a reading of your bike for you Thumbs Up
Souleh
PostPosted: 23:37 - 02 Jan 2013    Post subject: Reply with quote
Guys im a race event sound tester.
For testing, hold the DB meter at 50cm and 45degrees from the exhaust with any wind direction blowing engine noise AWAY from the meter (Aka back up the exhaust)
For RPMs see here
https://www.clubmsv.com/bike-testing-noise-limits
Any questions ask away
PostPosted: 23:42 - 02 Jan 2013    Post subject: Reply with quote
There is more than one DB scale, so make sure you are using the right one (not sure but think the difference is how is biases noise levels from different frequencies).
Measuring in your pocket will be pretty meaningless. Way too much difference caused by position relative to the exhaust, and on top of that there is wind noise to screw up the readings.
For circuits they use a pretty crude reading, with the noise meter in a particular position relative the exhaust at some set rpm. The details may well vary between different circuits.
For road noise tests it is done very differently. Not really any chance of getting an accurate measure of that in a random place with a phone app.
Red Devil
PostPosted: 07:05 - 03 Jan 2013    Post subject: Reply with quote
That would make sense actually! Just presumed the mic was on the end.
WindyMiller
PostPosted: 10:03 - 03 Jan 2013    Post subject: Reply with quote
10dB more sounds twice as loud, but is 10 times the power. 3dB would be double the power, but doesn't sound twice as loud. So in audio terms, running 10W into a speaker sounds twice as loud as 1W.
I don't know how accurate a phone app would be, but it ought to give you a halfway reasonable number. Not when it's in your pocket though, the jacket will reduce the levels a bit.
YBR125 SV650S Triumph Sprint ST 1050
Walloper
PostPosted: 16:35 - 03 Jan 2013    Post subject: Reply with quote
Aye, there is a A, B and C etc. dB measurement scales.
Phone app just a toy. Maplin dB meter is a more expensive toy.
I have use of both. They give a fairly inaccurate/unstable reading of stable noise.
A 'proper' meter will be about £500 and above as they are jammed full of filters and stuff and require regular calibration.
Phone in pocket? Was that Rustle I heard?
i.p.phrealy
PostPosted: 01:24 - 04 Jan 2013    Post subject: Reply with quote
This is why a 100 watt guitar amp will not sound twice as loud as a 50 watt one, and you need twice the power for each octave down you go to sound as loud.
this is why bass players amps are usually higher wattage than the guitarists.
the spread of sound is important too, a larger bore exhaust will sound louder, in the same way a 100 watt twin speaker amp will sound louder than a 100 watt single speaker one.
Walloper
PostPosted: 07:49 - 04 Jan 2013    Post subject: Reply with quote
Watt T F?
The last post was made 13 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 125.06 Kb
