problems with power loss as accelerating
nick1990
PostPosted: 22:02 - 01 Jan 2013    Post subject: problems with power loss as accelerating Reply with quote
hi i know this site is mainly for big bikes but im having problems with my 50cc baotian as im accelerating i get complete loss off power bike slowes down then all of asudden it picks up with a huge burst of power ive draind carb incase of water and i carnt find a foult in the fuel lines has any one got any ideas air filter is clean aswell and its a 4stroke engine
mospeed
PostPosted: 23:53 - 01 Jan 2013    Post subject: fault Reply with quote
Hi, sounds to me like your bike may have a common fault which is water/moisture in the fuel. You say you have drained the fuel in the carb but you may need to do more.
I assume the bike will run ok on tickover and low revs, what happens when you rev the bike on the centre stand. Have you checked the rollers as they do become squared off and this will cause them to stick, then release suddenly. Could even be the sparkplug.
Bit more info would help!
nick1990
PostPosted: 14:43 - 02 Jan 2013    Post subject: Reply with quote
im not sure were the rollers are the bikes been doing it since i got it from esb motercycles i did take it to them all they did was check the carb and air filter and said it was fine but it really isnt as power loss still happens i checked oil this morning looks like it needs changing so im going to drain that next week and put new inn see if that helps.
jeddy11
PostPosted: 18:27 - 02 Jan 2013    Post subject: Reply with quote
Take it back and make them ride it...
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
nick1990
PostPosted: 19:40 - 02 Jan 2013    Post subject: Reply with quote
Yh they took it out for less than 5mins and they tryed to say it was fine and there were no problems yet as soon as i went out on it after them it did it again
BorderHooner
PostPosted: 23:26 - 02 Jan 2013    Post subject: Reply with quote
take it back. tell them you have rights under the consumer sales of goods act and demand they do something, take an older family member with you maybe.
Benelli. Happy as a pig in cacky.
nick1990
PostPosted: 23:49 - 02 Jan 2013    Post subject: Reply with quote
Ill take it in tomorrow and get them to check everything i think the scooter has had mods done to it aswell as im hitting 50 top end this is making me wish i did my das and got the cbr600
BorderHooner
PostPosted: 00:59 - 03 Jan 2013    Post subject: Reply with quote
cool. tell them it's not fit for the purpose and is endangering your life. you can also threaten legal action and tell them you will take the bike to vosa for inspection.
nick1990
PostPosted: 01:15 - 03 Jan 2013    Post subject: Reply with quote
Thank you for the advice mate will se what they say first before threatening them im still in warranty woth them so if they carnt find the problem or so they make out ill just get my money back and go buy somewere else
pa_broon74
PostPosted: 17:22 - 03 Jan 2013    Post subject: Reply with quote
Had a similar fault although, on a much bigger bike.
We swapped the coils out, one was definitely faulty, poor contact from the coil to the plug cable. It was arcing over a break but, we think when accelerating, the gap increased to the point where the spark just wasn't strong enough.
If its still under warranty, get the shysters to sort it out.
Didn't catch anything.
nick1990
PostPosted: 18:41 - 03 Jan 2013    Post subject: Reply with quote
There going to look at it tomorrow as there
Mechanic isnt in today the guy thinks its to do with the fuel systems but that could be anything from fuel lines all the way to compression in the piston if im right
mr-jermy
PostPosted: 10:36 - 04 Jan 2013    Post subject: Reply with quote
i had a similar thing on my boatian i think it my problem was to do with the mixture but cant remember exactly.
nick1990
PostPosted: 13:21 - 04 Jan 2013    Post subject: Reply with quote
The scooter was in today and they found a problem the manifold has corroded so waighting for a new one now hopefully that will fix it
joshuaconroy
PostPosted: 01:24 - 05 Jan 2013    Post subject: Reply with quote
I had a similar problem on my mbk ovetto it's simple on mine the air pipe from filter to carb it was split so I replaced it and sorted
Srengam
PostPosted: 19:55 - 07 Jan 2013    Post subject: Reply with quote
I've actually got the same problem on my bike at the moment. As soon as it hits 6k theres a hesitation until it gets to 7k, it's fine after that.
I've been on KatRiders (forum for Katanas), they're convinced it's the jet needles in carbs, they need raising a little to richen to mixture a little in that rev range where the jet neddles are responsible for it.
My plan is:
New air filter, check all hoses, clean out tank vent pipe (it's definately blocked), then syncronise carbs.
If that doean't work i'm gonna adjust the needles as suggested.
I'm not sure if this helps you at all (as said above, it's under warranty), but it may help somebody else searching the forums.
Suzuki GSX600F Katana (1997)
nick1990
PostPosted: 01:54 - 08 Jan 2013    Post subject: Reply with quote
all great replys im going to waight for the new manifold to be fitted and see how it rides as im definatly getting powerloss there and i found out some info on how the ped was looked after bye the last owner lets just say if i new that before i bought it i would have left it in the shopits been ragged to death and dropped many of times Sad
mr-jermy
PostPosted: 12:28 - 08 Jan 2013    Post subject: Reply with quote
that sounds like my brothers old bike tbh he dropped/crashed his a few times and ragged it about alot, is it an 09 plate by any chance?
nick1990
PostPosted: 12:32 - 08 Jan 2013    Post subject: Reply with quote
No its a 2011 plate baotian eagle gt50
mr-jermy
PostPosted: 12:48 - 08 Jan 2013    Post subject: Reply with quote
ah right its not his then lol
sodbaotian
PostPosted: 21:22 - 05 Feb 2013    Post subject: Reply with quote
hi new member here, well all i can say is that baotian scooters are a pile of dog mess. i bought mine new in 2011 and it went backwards and forwards to the shop nearly every month this is a list of the problems
2x snapped mudguard brackets, side stand spring falling off then engine cutting out remedy was to put a blob of weld on the stand and disconnect the lead for the stand.
cold starting problems in the winter months-advised to keep it inside !! until a mod was done
fuel tank sender unit packed up new one fitted then the fun and games began. constantly breaking down after having it fitted told theie was condensation in the tank causing the problem mmm tank was stripped and carb this was fine till it rained and hey ho it broke down again , back to the shop who were going to charge me as it was now 2 weeks out of warranty, soon put them right .Again even more water in the tank cause was a nipped seal on the sender unit allowing rain water into the tank. remedy was to put some sealant on the main seal refit and then smother the top of it in silicone.
now after trying to sell it with no luck i went to start it today and guess what water in the tank/carb. i stripped the carb to find a rusty brown gunk all over the sump bowl and inners of the carb.
seriously now thinking of going to trading standards as not fit for purpose so if any one is thinking of buying one of these scooters avoid them with a wide berth.
sorry rant over
nick1990
PostPosted: 23:19 - 05 Feb 2013    Post subject: Reply with quote
Yh mate there a bag of crap i sold mine back to the shop and bought a brand new yamaha vity 125e and its a rapid little 125 no problems and as its still running in its getting faster as the miles add up
There is a gap of 2 years, 103 days between these two posts...
addiemartin11...
PostPosted: 10:56 - 20 May 2015    Post subject: baotian eagle gt Reply with quote
HI
i have a baotian eagle gt 50cc 4 stroke,
at the minute i cant go any faster than 30mph?
the pink wire has been cut, the brass screw under the carb is missing, also got new variator and new rollers, still no differents,
please any ideas at all?
thanks
Adam
nowhere.elysium
The Pork Lord
PostPosted: 11:05 - 20 May 2015    Post subject: Re: baotian eagle gt Reply with quote
addiemartin11939 wrote:
HI
It's a 50cc ped. They're designed to do 30mph. If you want more speed, get something bigger.
The last post was made 11 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 114.31 Kb
