HONDA H100 - OLD BIKE HELP!
ojmit
PostPosted: 13:02 - 03 Jan 2013    Post subject: HONDA H100 - OLD BIKE HELP! Reply with quote
Hi all
got a 86 honda h100 - running fine for ages then.....started cutting out - changed air filter, battery, oil pump and throttle cable, plug.....now starts but immediately jumps to max revs and stays there.....any ideas?? had the carb off and cleaned it through......
RhynoCZ
PostPosted: 13:07 - 03 Jan 2013    Post subject: Reply with quote
Does the throttle work properly and are you sure the choke is not stuck?
And the basic question, what about the idle screw?
PostPosted: 13:30 - 03 Jan 2013    Post subject: Reply with quote
I'd suggest either a sticking throttle or an air leak round the inlet manifold
ojmit
PostPosted: 14:12 - 03 Jan 2013    Post subject: Reply with quote
CHEERS - how would i sort these out?
PostPosted: 14:43 - 03 Jan 2013    Post subject: Reply with quote
Throttle sticking would be my starter for 10.
First off, check you put the throttle valve back in the right way round. Cutaway to the rear. Also make sure the throttle needle hasn't come adrift when you put it back in, there isn't much holding it in place, if you didn't get it cleanly down the main jet when you put it back together, it can push up into the middle of the throttle body.
If you take the carb rubber off, you'll be able to see the throttle valve moving as you open and close the throttle.
Other potential causes are things like the cable having come off its runner in the twist grip and a poorly routed cable.
cb1rocket
PostPosted: 17:15 - 03 Jan 2013    Post subject: Reply with quote
it appears there has been alot of fiddling for no reasons. alot of the random cutting out is down to the ignition switch playing up.
RhynoCZ
PostPosted: 19:32 - 03 Jan 2013    Post subject: Reply with quote
It could also have been the fuel tap, on my former bike GPz550 the faulty fuel tap (blocked with dirt), did caused cutting out + I had dirty tank breather, if I rode it in high revs a while, it caused the same thing Thinking
ojmit
PostPosted: 14:32 - 05 Jan 2013    Post subject: FURTHER HELP Reply with quote
cheers all - after a lot of mucking about - took the carb off again..the pin that holds the float holder on has come off its mountings - tried to reattach....then replaced, bike started but then fuel came pouring out the carb drain plug........reckon i have to buy a new carb????
PostPosted: 15:21 - 05 Jan 2013    Post subject: Reply with quote
I think you should post photos of the parts in question because you are giving every impression of not knowing what you're talking about.
Carb upside down, float bowl removed, in good light, in focus and of a decent resolution.
So like this:
https://i19.photobucket.com/albums/b183/Dave_ett/NSR250/floatvalveremoval.jpg
Not like this:
https://www.dirtygirlmotorracing.com/articles/carb-game/8-carb-float.gif
The last post was made 13 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 64.72 Kb
