| ojmit |
 ojmit L Plate Warrior
| RhynoCZ |
 RhynoCZ Super Spammer
| ojmit |
 Posted: 14:43 - 03 Jan 2013 Post subject: |
Throttle sticking would be my starter for 10.
First off, check you put the throttle valve back in the right way round. Cutaway to the rear. Also make sure the throttle needle hasn't come adrift when you put it back in, there isn't much holding it in place, if you didn't get it cleanly down the main jet when you put it back together, it can push up into the middle of the throttle body.
If you take the carb rubber off, you'll be able to see the throttle valve moving as you open and close the throttle.
Other potential causes are things like the cable having come off its runner in the twist grip and a poorly routed cable. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| cb1rocket |
 cb1rocket World Chat Champion
| RhynoCZ |
 Posted: 19:32 - 03 Jan 2013 Post subject: |
It could also have been the fuel tap, on my former bike GPz550 the faulty fuel tap (blocked with dirt), did caused cutting out + I had dirty tank breather, if I rode it in high revs a while, it caused the same thing  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| ojmit |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 17:41 - 06 Jan 2013 Post subject: |
as other posters but check the oil pump cable n flow as well.
if its got points then it may be just a timing issue ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
The last post was made 13 years, 45 days ago. Instead of replying here, would creating a new thread be more useful? |
