problem with starter i think
tfg
PostPosted: 14:45 - 03 Jan 2013    Post subject: problem with starter i think Reply with quote
hi i have been having trouble starting my bike since about november at the minuite i have to charge my battery every night i have bought 2 new batterys one cheaper one and one exspensive one yet still i only get 1 or 2 starts max does anyone have any suggestions i think it may be the starter relay but is there any way to test this
J.M.
PostPosted: 15:14 - 03 Jan 2013    Post subject: Reply with quote
When you say starts, do you mean:
1) Starting the bike and then riding it to where you want to go
or
2) Starting the bike, stopping the engine and then starting it again
2004 R1 & 2018 XSR900
PostPosted: 15:16 - 03 Jan 2013    Post subject: Reply with quote
Ever considered the battery could be screwed, you could also have something earthing which kills the battery.
Get the bike started, check the voltage over the battery with a multimeter. You ideally want over 14v.
tfg
PostPosted: 15:55 - 03 Jan 2013    Post subject: Reply with quote
hi sorry yeh i start it ride to work then work then ride home ok then in the morning it wont start i have bought 2 new batteries as i have to change everyday and this hasnt changed anythin
J.M.
PostPosted: 16:00 - 03 Jan 2013    Post subject: Reply with quote
Your batteries won't be the problem here then, you're looking at two potential issues:
- not charging
- short somewhere causing battery to discharge
Both of these issues can destroy batteries, so it's essential that you fix it to stop having to purchase batteries.
First of all, fully charge your battery, start your bike, put a multimeter over the battery and rev the engine to 4-5k. If the reading is 13v+ then it's okay. 12.5v... meeh not too bad.
Doing the above, what reading do you get?
tfg
PostPosted: 16:08 - 03 Jan 2013    Post subject: Reply with quote
i would have to wait to get my hand on a multi meter to do this
PostPosted: 16:15 - 03 Jan 2013    Post subject: Reply with quote
Where abouts are you based?
kernow24
PostPosted: 17:52 - 03 Jan 2013    Post subject: Reply with quote
I'd put money on a faulty reg/rec.. Has a similar problem a while back.
J.M.
PostPosted: 18:08 - 03 Jan 2013    Post subject: Reply with quote
You can't tell without diagnosing it.
I had the same problem but my issue was inside the wiring loom meaning that I had to wire the reg/rec directly in to the battery.
tfg
PostPosted: 23:13 - 03 Jan 2013    Post subject: Reply with quote
liverpool area mate i can get hold of one do on the 7th
Robby
Dirty Old Man
PostPosted: 17:30 - 05 Jan 2013    Post subject: Reply with quote
A dodgy starter motor or solenoid won't discharge the battery overnight.
A fault reg/rec is the most likely problem. What bike is it?
The last post was made 13 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 68.52 Kb
