Lexmoto XTRS 125 - Rev Counter Not Working
Ronbot
PostPosted: 09:36 - 03 Jan 2013    Post subject: Lexmoto XTRS 125 - Rev Counter Not Working Reply with quote
Hey I recently bought a Lexmoto XTRS 125 on a 61 plate, I was beinging it back from Bury, my first ride since passing my CBT last year! I was wondering if you could help me out with something:
The rev counter, it likes to flicker at the higher end RPM but anything else doesn't seem to work. I'm not sure how to fix this, I think it runs off the crank? I can't seem to see anything around.
Many Thanks,
Ron Smile
Treat it right, and it will last you for ever.
----------- Lexmoto XTRS 125 -------------
bikenut
PostPosted: 16:33 - 03 Jan 2013    Post subject: Reply with quote
hi dude, dont know this bike inn detail so does iot have a rev counter cable comin from eng to rev counter clock?? if not its either been nicked or done electroically?? some pics
Ronbot
PostPosted: 17:19 - 03 Jan 2013    Post subject: Reply with quote
It's ran off the crank, we checked, is there any fix for the clock or is it a new one in order?
(We took it out from the back of the dial, it spins freely, also I can't get anymore pics as it's not at my house Thumbs Down )
tomh
PostPosted: 17:24 - 03 Jan 2013    Post subject: Reply with quote
On a mates 61 plate XTRS his rev counter has been useless since he got it new so even if you get it working don't expect much from it.
Apparently his bike idles at nearly 2500 rpm and it is very slow to react to the engine revs.
Ronbot
PostPosted: 17:33 - 03 Jan 2013    Post subject: Reply with quote
That's grim, but it's what you get for £500 ehh...
We tuned the carb and to be honest it's running sweet as a nut! :')
bikenut
PostPosted: 12:29 - 04 Jan 2013    Post subject: Reply with quote
so is cable all ok ( greased rather than oiled ) and when eng running the cable inner rotates??
make up a drive bit to insert into drill and speedo, turn on drill ( so bit rotates the correct way and drives the speedo head ), what happened??
maybe speedo internal need lub?? sorry revcounter not speedo.
PostPosted: 14:14 - 04 Jan 2013    Post subject: Reply with quote
Yup, definitely check the cable first. Free it at both ends, and make sure it's contiguous - it could be snapped internally and dragging the top end round some of the time - my GPz305 did that.
Ronbot
PostPosted: 16:51 - 04 Jan 2013    Post subject: Reply with quote
Thanks guys, I'll go and have a look now!
The last post was made 13 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 55.09 Kb
