TDR 125 not running properly in the rain
kirk
PostPosted: 09:08 - 09 Nov 2004    Post subject: TDR 125 not running properly in the rain Reply with quote
ive got a derestricted tdr 125 italian import, very quick accearation, 51 tooth rear sprocket, anyway when riding in the rain the bike will not rev over 5000 and just seems to splutter, you have to keep throttle on full revs until it seems to catch and away it goes again, any ideas.
cagiva gezzer
PostPosted: 12:08 - 09 Nov 2004    Post subject: Reply with quote
Check the HT lead. Make sure it isn't too close to anything that could cause the spark to short circuit. Check the spark plug cap to see if it is a water resistant one (rubber boot sealing the base of the cap against the plug.)
If it happens when you go through a puddle its highly likely to be the above, if it happens when the bike has been sat in the rain, then its more likely to be water getting into connectors associated with the cdi & coil.
"because one stroke isnt enough and four strokes waste two"
Smoto Bob
PostPosted: 15:54 - 09 Nov 2004    Post subject: bike Reply with quote
cagiva gezzer great advice as always Thumbs Up Also grease on the HT lead joints keeps water out. Might want to check that you air box rubbers and stuff are connected properly as well.
Also as winters comming up you might want to make sure its getting up to temperature. On My old dt125 (which has smaller rad) i used to have to cover up some of it.
F'it DO WHAT EVER MAKES YOU HAPPY!!!!! Even if it screws over everyone else :p
Titz wrote: "..and my 3rd accident was when this police car....."
The last post was made 21 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.72 - MySQL Queries: 15 - Page Size: 35.61 Kb
