bleed screw stuck
mr-jermy
PostPosted: 13:56 - 03 Jan 2013    Post subject: bleed screw stuck Reply with quote
the problem is as in the title, i've got a honda ns125rl and upon getting it the brake lever was broken, i'd bought a load of spares with a full front brake set-up from the hand to the caliper, I've tried to switch the parts around but they dont seem to be able to work/fit each other, so i've gone to use the new (second hand) set and noticed that the bleed screw is rusted i've tried spraying the 3in1 oil onto it to get it to soak in and release it but hasnt worked, im aware of heating it up or freezing it to help release it but dont have the equipment to do so, and am asking for help to try and sort it out please Smile any info would be grately recieved. Smile
PostPosted: 13:58 - 03 Jan 2013    Post subject: Reply with quote
Remove the offending item.
Make sure the seals are removed. Heat over an oven.
Failing that, plusgas.
Have you attached it to the bike and tried to open the nipple that way?
mr-jermy
PostPosted: 14:03 - 03 Jan 2013    Post subject: Reply with quote
my knowledge on braking systems is very little and i have no idea what you just said lol, i had it on the bike originally and it worked perfectly and wouldnt have needed to touch it if it wasnt for the brake lever, not sure how my house mates would feel with me doing it over the oven lol thanks Smile
Dave-the-rave
PostPosted: 14:09 - 03 Jan 2013    Post subject: Reply with quote
Use a rust penetrative like Plusgas and get some mole grips on it.
mr-jermy
PostPosted: 14:10 - 03 Jan 2013    Post subject: Reply with quote
hmmm where might i aquire some of this plusgas? Smile
PostPosted: 14:14 - 03 Jan 2013    Post subject: Reply with quote
Local tool factors?
Ebay/Amazon
mr-jermy
PostPosted: 14:15 - 03 Jan 2013    Post subject: Reply with quote
just found some on amazon for £4 this is the stuff right? https://www.amazon.co.uk/dp/B0001P02RA/ref=asc_df_B0001P02RA11311440?smid=A3P5ROKL5A1OLE&tag=googlecouk06-21&linkCode=asn&creative=22206&creativeASIN=B0001P02RA
Thanks Smile
PostPosted: 14:22 - 03 Jan 2013    Post subject: Reply with quote
Yup Thumbs Up
mr-jermy
PostPosted: 14:25 - 03 Jan 2013    Post subject: Reply with quote
lovely jubbly thanks buddy will get some payday and give it a go cheers buddy Smile
PostPosted: 14:39 - 03 Jan 2013    Post subject: Reply with quote
Failing everything. You can leave the seized bleed nipple where it is and fit a banjo with a built in bleed nipple. They are available on ebay.
bikenut
PostPosted: 16:35 - 03 Jan 2013    Post subject: Reply with quote
remove and strip cal;iper heat and a preying
flumpy7
PostPosted: 12:29 - 04 Jan 2013    Post subject: Reply with quote
Yup works a treat!
mr-jermy
PostPosted: 12:35 - 04 Jan 2013    Post subject: Reply with quote
how does a banjo bleed nipple thing work exactly?
PostPosted: 12:39 - 04 Jan 2013    Post subject: Reply with quote
The samer way as the normal bleed nipple, except it's on the banjo going into the calliper, not the calliper itself.
mr-jermy
PostPosted: 14:10 - 04 Jan 2013    Post subject: Reply with quote
thats awesome just realised where it goes, gonna get some plus gas and give that a go then if that doesnt work i'll get one of them Smile cheers guys Thumbs Up Very Happy
The last post was made 13 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 81.67 Kb
