chinese 2 stroke 49cc problem ?
 Topic moved: from Forum Feedback & Help to The Workshop by Korn (3 Jan 2013 - 10:49)
gilera183
PostPosted: 19:56 - 02 Jan 2013    Post subject: chinese 2 stroke 49cc problem ? Reply with quote
hi all, new to this forum my friend has a problem with his shitray 49cc 2t moped, problem is the usal, wont start ?
ive had the engine out,
cleaned the fuel
cleaned the carb, no hole in the float or dirty jets
set the carb up as it should, needle is set correctly
air filter is clean,
semi synthetic oil
unleaded petrol
loads of compression
reed valves are fine
spark plug is new !
cdi works as the plug sparks to the frame, gaskets in the engine are fine, nothings flooded,
anyway to the point, it will not fire up for anything ? and the engine seems fine and clean ? only 500 miles on it ?
possibly a wire problem grounding it out ? any help is apreciated! thank you all.
hamster16
PostPosted: 22:59 - 03 Jan 2013    Post subject: Reply with quote
have you had the spark plug out and turned the engine over and is there a spark? also when you take the plug out is there any petrol on the tip to indicate wether it is pulling fuel into the cylinder? and a little trick i learnt to do is get a little bit of petrol about a tablespoon an pour into the cylinder then put the plug in and start as usual then it should run for a few seconds and either cut out or keep going as sometimes it just needs to be run to get running. if it wont run even when you put your fuel in the cylinder then fuel isnt the problem. so start going through a checklist of problems
good look
DMCpro
PostPosted: 15:19 - 04 Jan 2013    Post subject: Reply with quote
Time for the scrap yard by the sounds of it, you know the disposable cameras you get (used to?) well Chinese bikes are a lot like them, your best bet is to swap the engine for a different one perhaps a piaggio or similar branded engines before something else breaks
Or you could do a compression test then top end rebuild buy a new carb new coil stator if you want to waste money and wait weeks for postage by all means go ahead
Honda CB-1, TS125X
VW Golf Estate
petechett
PostPosted: 15:24 - 04 Jan 2013    Post subject: Reply with quote
shitray? lol. any bikes from china sucks Thumbs Down
gilera183
PostPosted: 15:49 - 04 Jan 2013    Post subject: Reply with quote
iknow all chinese bikes are shit lol, ive always had gilera/piaggio etc bullet proof, hence the name gilera183, its completley fucked anyway hes buying a runner now thanks to me....
The last post was made 13 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 16 - Page Size: 48.43 Kb
