| gilera183 |
 gilera183 L Plate Warrior
 Posted: 19:56 - 02 Jan 2013 Post subject: chinese 2 stroke 49cc problem ? |
hi all, new to this forum my friend has a problem with his shitray 49cc 2t moped, problem is the usal, wont start ?
ive had the engine out,
cleaned the fuel
cleaned the carb, no hole in the float or dirty jets
set the carb up as it should, needle is set correctly
air filter is clean,
semi synthetic oil
unleaded petrol
loads of compression
reed valves are fine
spark plug is new !
cdi works as the plug sparks to the frame, gaskets in the engine are fine, nothings flooded,
anyway to the point, it will not fire up for anything ? and the engine seems fine and clean ? only 500 miles on it ?
possibly a wire problem grounding it out ? any help is apreciated! thank you all. |
| hamster16 |
 hamster16 L Plate Warrior
| DMCpro |
 DMCpro Traffic Copper
| petechett |
 petechett Nova Slayer
 Posted: 15:24 - 04 Jan 2013 Post subject: |
shitray? lol. any bikes from china sucks  |
| gilera183 |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 13:47 - 05 Jan 2013 Post subject: |
if everything else checks out then get it compression tested.t strokers usually have a lower compression and the barrels are designed to wear and be rebored.The smaller an engine is the more it will need reboring due to wear on pistons and rings/barrel. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
The last post was made 13 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
