Project Dirty beast - WR450
PostPosted: 22:05 - 04 Jan 2013    Post subject: Project Dirty beast - WR450 Reply with quote
Laughing No idea where to start.
Stolen/recovered WR450, 2005 model, dirtier than a London hooker, leaks more too.
It need on first glance.
A full wiring loom.
Fork seals.
Severe tidying up and painting parts of frame to deal with rust.
Jobs for tomorrow...rebuild my Ninja and move out of the shed, stick this in its place and strip it down and get the engine out of the frame.
Rub frame down, get most of the rusty bits covered in primer and start cleaning bits up.
https://super-user.co.uk/thewr.jpg
nowhere.elysium
The Pork Lord
PostPosted: 22:23 - 04 Jan 2013    Post subject: Reply with quote
This is going on the road, right? Sumo wheels, then. My preliminary googling also suggests that you'll also want oil. Lots of it.
Does it run ok?
PostPosted: 22:25 - 04 Jan 2013    Post subject: Reply with quote
Sumo wheels in time...after its been road reg'd otherwise it is likely to fall under the minimum height and clearance thing.
Engine seems as sound as a pound.
It will run nicely when the electrics aren't just 8 feet of multi coloured wire. Laughing All I want is electric start wired in, lights will come at a far later date.
nowhere.elysium
The Pork Lord
PostPosted: 22:35 - 04 Jan 2013    Post subject: Reply with quote
All it needs is a set of zip ties to bundle it together in the right places, then a bout of swearing and self-amalgamating tape to tidy it up. It's not fun, but it certainly is cheaper, as well as affording you the opportunity to spot and sort any potential problems.
I'm not sure how complex wiring a set of lights in would be - you'd have to ask someone that's electrically competent for a straight answer to that one, but my recent experience of checking over a loom tells me that it's not as terrifying as all that, just time-consuming.
Do you have all the bits to do the lighting, like brake switches, appropriate buttons on switchgear and so forth?
PostPosted: 22:38 - 04 Jan 2013    Post subject: Reply with quote
Nothing.
There is no switchgear. There is nothing electrical on the bike at all, no wiring for the lights. The lighting kit is apparently an additional option you can get from Yamaha which plugs in to the loom.
The loom has been chav'd and looks nothing like its original spec.
nowhere.elysium
The Pork Lord
PostPosted: 22:46 - 04 Jan 2013    Post subject: Reply with quote
Ah. Fair enough; my off-road experience only goes as far as parking up on gravel Laughing
As for the chavtabulous electrics, I'm genuinely surprised they got it running, if it really hath been wrought by the retarded hand of Kevin T. Scrote.
Pie-Roe
PostPosted: 00:16 - 05 Jan 2013    Post subject: Reply with quote
When you inevitably get bored of this, first dibs.
Wiring isn't that bad on most of these bigger four strokes that I've found. Would carry around sets of fuses, my drz and te both had a habit of blowing main fuse when starting when they are hot.
Let me know if you get stuck with anything, as ever I'm very good at brute force and hammering.
mysterious_rider
PostPosted: 12:49 - 05 Jan 2013    Post subject: Reply with quote
I'd just wire it yourself. A gn250 lights switchgear is easy, three wires from it go to the battery, then the others go to indicators, high beam,low beam and horn.
Bike looks savage mate, I'd love one of those. Smile
KAWASAKIIIII
steveh
PostPosted: 15:43 - 05 Jan 2013    Post subject: Reply with quote
ill get that workshop manual uploaded for you, its a genuine Yam one, so its pretty damn good.
Steve.
binge
Emo Kiddy
PostPosted: 02:45 - 06 Jan 2013    Post subject: Reply with quote
My YZF450 (Racing Thoroughbred brother of this bike), ran a total loss electrical system.
Small battery tucked up inside the seat, to some basic switch gear, for a stop/tail light, a high/low headlight, and a horn. That was it.
Wiring, I did myself, was very easy to do.
Yours will be similar, but ran from a reg/rec, instead of a battery.
Bike looks cool. Another 'dibs' if you like, on this if you get bored of it. I do miss my YZF massively!
Bit of inspiration for you:
Could get mine from this:
https://sphotos-a.ak.fbcdn.net/hphotos-ak-ash4/264127_10150222945100606_6733641_n.jpg
To this:
https://sphotos-f.ak.fbcdn.net/hphotos-ak-snc6/255063_10150221766090606_6877434_n.jpg
In around 10 minutes.
Oh, and sometimes, they like to do this: Laughing
https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash4/253734_10150220507550606_1597980_n.jpg
PostPosted: 18:52 - 06 Jan 2013    Post subject: Reply with quote
Oh Ben, I miss that bike... would have had that off you Laughing
Maybe you can give me a hand with this one, I'm ordering a new wiring loom as mines been chav'd with.
Oh, I removed the engine today, it has been standing outside for a few months with no cover and no spark plug Rolling Eyes Needless to say its got some water in there.
Engine flush may need to be used here...or constant flushing with oil?
No oil in water... head gasket seems fine and bike does "go" but not now as the loom is removed.
The carb is massive. I've never seen a carb that big in my life Laughing
PostPosted: 22:18 - 12 Jan 2013    Post subject: Reply with quote
Oooh oooh oooh!
Might have an update for tomorrow!! Mr. Green Mr. Green Mr. Green
ian505050
PostPosted: 22:49 - 12 Jan 2013    Post subject: Reply with quote
What happened? Why did the bike take a piss? was the beast not toilet trained?
PostPosted: 22:50 - 12 Jan 2013    Post subject: Reply with quote
His bike shat its oil from the sump.. He did try calling me Laughing
His bike was fucking mental though. I'd never really wheelied before, usually was loads of revs and clutching it.
Fuck that, open the throttle in any gear Laughing
PostPosted: 16:15 - 13 Jan 2013    Post subject: Reply with quote
Le Update.
Today we have stripped the carb.
I believe something may have been left out by accident so will need stripping again... carb seems to be leaking loads now we have touched it, out of the overflow pipe.
BUT
It sparks now, it has start and stop buttons, all it needs is fuel.
Also, anyone got any titanium exhaust parts at all? I am amazed at the weight of these parts, the downpipe weighs as much as an empty can of relentless Laughing
PostPosted: 18:52 - 13 Jan 2013    Post subject: Reply with quote
This is the carb that is giving me all the hassle.
https://super-user.co.uk/carb.jpeg
nowhere.elysium
The Pork Lord
PostPosted: 19:41 - 13 Jan 2013    Post subject: Reply with quote
Float needle not been re-seated properly?
TUG
PostPosted: 19:52 - 13 Jan 2013    Post subject: Reply with quote
This, Happened to me with my FZR400 believe it or not but there is a right and wrong way to hook them back up.
Haz ER-5, innit!
PostPosted: 20:05 - 13 Jan 2013    Post subject: Reply with quote
No idea...need to strip again as I found a spring floating around Whistle no idea where it goes but can check the float.
Really fucking annoying Sad Need to find the manual/see one stripped down and see locations.
Its a Keihin CR if anyone stumbles across one Laughing
nowhere.elysium
The Pork Lord
PostPosted: 20:12 - 13 Jan 2013    Post subject: Reply with quote
Parts list here, pertaining to this image: https://www.boats.net/images/diagrams/yamaha/MCY/2005/WR450FT/IMAGES/CARBURETOR.png
PostPosted: 20:21 - 13 Jan 2013    Post subject: Reply with quote
Am I assuming correct that the float should go in that way up ^^^
If so, someone has trolled me as the carb had it in the other way. As to the spring, fuck knows Laughing
Frost
PostPosted: 20:23 - 13 Jan 2013    Post subject: Reply with quote
binge wrote:
Inadequate chain tension?
nowhere.elysium
The Pork Lord
PostPosted: 20:24 - 13 Jan 2013    Post subject: Reply with quote
Have it apart again, take photographs this time. Having the floats the wrong way up could well cause an overflow. However, if this thing has been torn apart by chavs prior to now, it's best to go over everything yourself, just to make sure.
As far as I'm aware, that diagram is accurate; it was listed as being for an '05 WR450F.
Tight as a jew when you sit on it though Thumbs Up Nice soft rear shock Laughing
binge
Emo Kiddy
PostPosted: 20:54 - 13 Jan 2013    Post subject: Reply with quote
Re my YZF450:
It chucked all it's oil out after having a full gearbox rebuild. They have 3 oil drain screws. Must have forgot to tighten one back up. Was on the country lanes, arse end kept stepping out, and I assumed I had a flat on the rear.
Looked down, and was caked in fucking oil! Laughing
Pulled over promptly, had a pal come up with a few basic tools, a litre of oil, and a handfull of M8 bolts. Whacked a bolt in, filled it up, and rode home.
Chain tension was spot on that day, as I'd literally put the bike back together an hour previous to that.
Looks slack, that's just how they're meant to be. Have it any tighter, and they stretch really quickly...
The last post was made 13 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.44 - MySQL Queries: 13 - Page Size: 130.77 Kb
