Bike starts well but stalls as soon as goes in gear
drmmanish
PostPosted: 07:17 - 07 Jan 2013    Post subject: Bike starts well but stalls as soon as goes in gear Reply with quote
Hi all,
I have a cbf 125 Honda which has about 8500 miles on it. Started the bike today..no issues.. But as soon as bike goes in first gear the engine stalls! Tried it a few times..same problem. The clutch at my end seems to be working fine. The engine on start sounds absolutely fine.
Was wondering what the problem could be.
Many thanks for advice.
Manish
ginny
PostPosted: 07:45 - 07 Jan 2013    Post subject: Reply with quote
Side stand or side stand switch problem?
Formerly known as
P.
PostPosted: 08:16 - 07 Jan 2013    Post subject: Reply with quote
That ^
Should be a switch on the side stand, check its working. I normally remove mine, join the wires and tape them out of the way.
PostPosted: 10:03 - 07 Jan 2013    Post subject: Reply with quote
Heh, I tucked the switch on my HN up under the seat straight out of the crate - they're a known failure point on those bikes.
The CBF125 side stand switch apparently looks like this:
https://ccjm.dnsd.me/cbf125-side-stand-switch.jpg
Find it, make it not broken. Give it a clean with WD-40, iso-propyl alcohol, or whatever you have to hand, bit of a wiggle, clean any crud off, see if that gets you going. Worst case you can just remove it and either leave the circuit open or short it, depending on whether the switch opens or closes it with the stand up.
jcewright
PostPosted: 10:49 - 07 Jan 2013    Post subject: Reply with quote
Put the bike in first with the engine off, pull in the clutch and see if it rolls. If it does move onto switches.
tom_m
PostPosted: 18:24 - 07 Jan 2013    Post subject: Reply with quote
Agree with paddy, had same problem on my ybr with side stand switch, now disconnected Thumbs Up
Current: 2005 Kawasaki Er-5 C5P
Past: 2012 Yamaha Ybr 125, 2004 Yamaha Neos 50, 1994 Suzuki Gn 125, 2005 Aprilia Sportcity 125, 1988 Yamaha Tzr 125
Theory: Passed... Mod 1: Passed 22/08/12 Mod 2: Passed 22/10/12
unitynotsocri... This post is not being displayed because the poster is banned. Unhide this post / all posts.
drmmanish
PostPosted: 23:59 - 07 Jan 2013    Post subject: Reply with quote
Hi guys,
Just to say a big THANK YOU. It did work. I mean when the bike is not on the side stand it works well. Is it supposed to be like that; I mean when on the side stand is it meant to not run?
Many thanks.
Ps: spent my weekly petrol money in one day on tube!!
Nope.
PostPosted: 00:11 - 08 Jan 2013    Post subject: Reply with quote
Yes, it stops you riding off with the side stand down and then experiencing that anus clenching moment when you go round a bend the same side as your side stand and can't lean the bike over.
Much like this guy with his very expensive Spondon RG500:
https://www.youtube.com/watch?v=atP5l0ptaFg
The last post was made 13 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 60.46 Kb
