Cant format a hard drive
mic
PostPosted: 19:15 - 09 Jan 2013    Post subject: Cant format a hard drive Reply with quote
Ive got my old laptop hard drive in a case and have connected to the PC with USB. it detects it as a mass USB storage device but it wont detect it under 'my computer' and i cant seem to do anything with it.
i just wanna wipe it clean (format it) so its there for storage as itll still have windows etc on it. any suggestions??
thanks
zzr600
oldpink
PostPosted: 19:21 - 09 Jan 2013    Post subject: Reply with quote
go into the control panel -> Admin tools -> Computer management -> Disk management
remove the partition(s) on said drive (make sure its the right one or you will loose data or worse)
create a new partition and format
mic
PostPosted: 19:49 - 09 Jan 2013    Post subject: Reply with quote
ahhh stupid works computer wont give me the admin rights lol will have to wait till i get home. but thats great, thanks very much.
whilst i think about it, once wiped clean would i be able to install Ubuntu on the hard drive and use that when i turned the laptop on, partition a % of the drive for storage and the last % for that?
zzr600
orac
PostPosted: 20:08 - 09 Jan 2013    Post subject: Reply with quote
have you got a floppy drive, if not get one, download f-disk, unplug all other drives boot from from floppy and run it
this will will set all sectors to 0 (normally called a low level format) removing all trace of anything that was on there, make sure there is nothing on there you want to save as it will be unsave-able by normal means.
oldpink
PostPosted: 20:12 - 09 Jan 2013    Post subject: Reply with quote
most likely restrictions on your works PC is stopping you from being able to format it
as to Ubuntu you could do the other way around Ubuntu on the primary storage on the secondary
mic
PostPosted: 20:33 - 09 Jan 2013    Post subject: Reply with quote
floppy drive is a no, only have notebook
on the laptop i had windows with ubuntu running along side. now the laptop is dead i can use my playbook for browsing etc but i like ubuntu for torrent sharing. i dont wanna mess about with the wifes notebook and the kids notebook is only a standard cheapy with low memory so dont wanna mess with that.
however, with my spare harddrive i would like to wipe it and install ubuntu to it so when the kids go to bed i can plug it in to theirs and let it download torrents whilst not interferring with the wifes usage etc.
but im guessing that would mean id have to tell which harddrive ubuntu installs to and have to plug it into the notebook before powering on so can choose between windows/ubuntu as i did before on the laptop.
make sense?
zzr600
orac
PostPosted: 21:31 - 09 Jan 2013    Post subject: Reply with quote
have you tryed foramting during an install.
alos does the drive apear in the BIOS?
mic
PostPosted: 22:09 - 09 Jan 2013    Post subject: Reply with quote
havent tried anything, just put the drive into the case and took to work thinking i could format it here but obviously not Laughing
havent done anything with it at home
zzr600
woodall57
PostPosted: 22:39 - 09 Jan 2013    Post subject: Reply with quote
you could try downloading hierins boot cd and use boot and nuke to format it?
cbt:4/7/12 theory:16/7/12 module 1:12/8/12 module 2: ?
PostPosted: 22:40 - 09 Jan 2013    Post subject: Reply with quote
Easeus is the fastest formatting tool I have used.. just for reference.
orac
PostPosted: 06:07 - 10 Jan 2013    Post subject: Reply with quote
more effort is required then, the drive is most likely fine, its just you cant do much due to restriction on you work computer.
mic
PostPosted: 06:13 - 10 Jan 2013    Post subject: Reply with quote
Taking the harddrive out of the laptop was the last thing I did before going to work. I'm still at work Smile its on the ever growing list of things to do when I get home
zzr600
mic
PostPosted: 08:29 - 10 Jan 2013    Post subject: Reply with quote
Is done using oldpinks method Smile have downloaded ubuntu on it, will do the rest after a bit of sleep. Thanks guys
zzr600
The last post was made 13 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 76.66 Kb
