cylinder rebore
mr-jermy
PostPosted: 19:35 - 09 Jan 2013    Post subject: cylinder rebore Reply with quote
got an ns125r and the cylinder has several hairline cracks in it, i have a spare one but im not sure if it will need to be rebored or how much it would be likely to cost, anyone know how i can tell if it needs reboring and/or how much it would likely to be, based in norwich if that helps,
Thanks in advanced Smile
Stevey
PostPosted: 21:43 - 09 Jan 2013    Post subject: Reply with quote
Mick Abbey charge 15 quid per cylinder plus a fiver postage back to you. https://www.two-stroke-addicts.freeserve.co.uk/mick/home.htm
I got mine re-bored and honed for £35 at my local re-bore shop.
Probably best if you either took some good pictures and uploaded them or even take the barrel to a bike shop, most would advise and probably recommend a local place.
Current: 50cc Suzuki scooter.
Project: Yamaha RXS 100
mr-jermy
PostPosted: 22:26 - 09 Jan 2013    Post subject: Reply with quote
thanks for getting back to me bud much appreciated, they look quite good found a couple of places near me so i might see what they are like and try them thanks, heres a couple of pics of the inside of the barrel not the best but the lighting isnt brilliant. Smile
Teflon-Mike
tl;dr
PostPosted: 22:32 - 09 Jan 2013    Post subject: Reply with quote
What did you get rebored? Sig says you have an RSX100.
As far as I know, that's a plain iron liner in an alloy barel, and CAN be rebored.
NSR as I recall has a Nikasil Chrome bore, which I dont know, but may be plated directly onto the auminium.
Either way, they cant be re-bored.
Two stroke specialist job, to get the barel reconditioned, either a new liner shrunk in, or the old plating removed and new plating put on.
Or its a new barrel.
I doubt very much that it will cost as little as £15...
mr-jermy
PostPosted: 22:36 - 09 Jan 2013    Post subject: Reply with quote
technically its not an nsr, its and ns125rl slightly different but by how much i dont know Smile
mr-jermy
PostPosted: 22:47 - 09 Jan 2013    Post subject: Reply with quote
ok thanks i should have a spare piston ring lying around here, is there any difference in the rings? does it matter which one goes at the top? (sorry to sound like and idiot) thanks
mr-jermy
PostPosted: 00:18 - 10 Jan 2013    Post subject: Reply with quote
ah right ok cheers will have to get it looked at to find out thanks
The last post was made 13 years, 296 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 61.71 Kb
