GSXR 1000 bearing sizes
lilredmachine
PostPosted: 20:47 - 09 Jan 2013    Post subject: GSXR 1000 bearing sizes Reply with quote
Hey there, hope someone can help.
I need the bearing sizes of a standard 01-02 (think they are the same all the way through though) GSXR 1000 rear wheel bearing and a standard GSXR 1000 hub carrier bearing for my Bandit 12 swap.
I need a bearing with the standard outer diameter of a Gixxer but a 20mm internal diameter for the bandit axle. I know the wheel bearings i used are 6304 but oddly, I don't know the sizes as they are simply referred to as 6304s and I don't have a vernier caliper at this moment.
Any help would be marvelous.
Bikeless
PostPosted: 20:51 - 09 Jan 2013    Post subject: Reply with quote
https://www.skf.com/skf/productcatalogue/jsp/viewers/productTableViewer.jsp?&tableName=1_1_1&presentationType=3&startnum=12
Any help?
lilredmachine
PostPosted: 22:24 - 09 Jan 2013    Post subject: Reply with quote
Cheers for the effort, but I mainly need the bearing diameter for the standard Gixxer sprocket carrier.
Thanks to you I now know the 6304 is a 52mmx20mm but the sprocket carrier is a different size.
I had been under the assumption that the Bandit sprocket carrier bearing would fit but it is too small in terms of outer diameter.
I can measure it up tomorrow anyway, but was just wondering if anyone knew off hand. Thumbs Up
Bezzer
PostPosted: 23:21 - 09 Jan 2013    Post subject: Reply with quote
Gixxer rear wheel bearings are 28x52x12 Have a look at the 'fiches on Alphasports they do give most bearing sizes on particular models.
https://www.alpha-sports.com/suzuki_parts.htm
lilredmachine
PostPosted: 00:15 - 10 Jan 2013    Post subject: Reply with quote
Life saver mate Thumbs Up
Standard Bandit is a 25x62x17 (20mm axle, 5mm thick bushing) bearing and standard Gix is a 32x65x17 (28mm axle, 4mm thick bushing) bearing. I will be using the Gixxer hub but with the cut down Bandit bushing so will need a 25x65x17 bearing to fit.
Got it clear in my head now.
The last post was made 13 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 2 - MySQL Queries: 13 - Page Size: 43.83 Kb
