Aux lighting (more of it)
mr.z
PostPosted: 21:31 - 10 Nov 2004    Post subject: Aux lighting (more of it) Reply with quote
Still not satisfied with the lights i have i'm looking at adding some more...
At the moment i have two car fog/all weather lamps that come on with the main beam, while thye make allot of difference they dont let me see all that much further ahead..
So i'm going to get two spot lamps to mount onto the indicator stalks, and get some indicators to go on my newly aquired hand guards (ala bmw)
2x 4pin relay setup
https://homepages.nildram.co.uk/~noriba74/images/bike/lightsmash1.jpg
1x 5pin relay setup
https://homepages.nildram.co.uk/~noriba74/images/bike/lightsmash2.jpg
Ive drawn two (horribly in MSPaint™) ways of going about it, only things not included are fuses and switches which i can turn both main and fog lights off.
The 5pin relay works the same as a normal relay but it has two "outputs" and the output depends on weather its switch is on or off (the switch being an electrical input from the low beam circut perhaps)
So what do you think? (ignoreing i could get a higher rateing headlight bulb) the two relay way i would be able to controll the lights individualy, but the single relay will use up less space and wires (and less to go wrong)
Can anyone reccomend any good reasonably low wattage spot lamps? (rick?)
Robby
Dirty Old Man
PostPosted: 23:29 - 10 Nov 2004    Post subject: Reply with quote
Buy a car.
Or a CBX750.
PostPosted: 23:57 - 10 Nov 2004    Post subject: Reply with quote
Right, scrap that, I am going WAY too complicated!
PostPosted: 00:29 - 11 Nov 2004    Post subject: Reply with quote
Two relays. One standard 4-pin, one '5-blade changeover' both inside the headlamp shell, you can get micro relays if space is tight.
https://www.vehicle-wiring-products.co.uk/VWPweb2000/relays/relays.html
Run all the power to the lights through a fuse (inline or on a fused 4-balde relay) directly from the battery. Wire it all up as shown below and use the connection that normally attaches to the headlamp bulb hi-beam as the switching current (terminals 85) on the 5-blade.
You would be drawing just below 15A from a 60w beam and 2x55w spots.
Run a new earth to the battery or a good frame earth.
This way should work and will avoid setting your bike on fire...I can't comment on how your charging system will cope but a CX should be pretty hefty. Appologies for the numerous crossovers, it was a quick job.
EDITED DUE TO WIRING BLINDNESS
mr.z
PostPosted: 00:55 - 11 Nov 2004    Post subject: Reply with quote
Yeh it confused the hell out of me before you edited it! Laughing
The fog lights on now are 40w each i think, i've not noticed any problems with the chargeing whatsoever (not had to charge the battery yet) apparently the thing to do is fill the oil to the top, stops things getting warm in the event of it being overworked (may or may not be true)
My relay currently lives under the seat, i do have a micro relay i could try for size, allthough space is very tight indeed.
It all at fesability stage at the moment, its not getting any brighter at night and i'm getting sick of not being able to see a soding thing in the rain Thumbs Down
The diagrams and advice are very much appreciated Thumbs Up
PostPosted: 01:28 - 11 Nov 2004    Post subject: Reply with quote
You can put the relays wherever you want really. The headlamp shell is handy because all the wires you want to access pass through there. Minimal disturbance to the original loom that way.
I have my relays in a waterproof plastic enclosure bolted to the front subframe just behind the lights. IP56 (jetted waterproof) rated, all the wires go through a waterproof gland in the side of it.
Big Pete
PostPosted: 17:25 - 11 Nov 2004    Post subject: Reply with quote
I would expect a CX500 alternator to have a peak output of less than 200w (at relatively high speed), if you run it at with a heavy draw like this all the time then you risk cooking the stator wires in the alternator (especially when the engine is at low revs). Given what a bastard it is to change a cx alternator and that they are not the most reliable ones in existence I would be carefull about how much extra load you put on.
Trust me, I`m an engineer
GarageOfPower.co.uk
PostPosted: 02:02 - 12 Nov 2004    Post subject: Reply with quote
So what he is saying is get on the RBZ and speak to mouse. Guru on fitting massive outboard alternators to japanese engines (he has a car alternator running off the camshaft on one of his bikes, hence how his main beam alone totals 330w and he can still run a homemade heated vest and grips on top of it.
Big Pete
PostPosted: 09:48 - 12 Nov 2004    Post subject: Reply with quote
that would be a top plan, most car alternators run 650+ watts.
GarageOfPower.co.uk
mr.z
PostPosted: 13:47 - 12 Nov 2004    Post subject: Reply with quote
Sounds interesting Very Happy
If i was to go for something a bit mad like that...
The fan is driven off the camshaft and its crap, its fallen off twice so i'm planing on getting rid anyways... if i can get in some decent fans there may be space for an allternator too.... (allthough i have no idea of the size) hmmmm
Thanks for that though, i will hunt out mouse and ask Very Happy
Another thought was finding a single fog and mounting it inline but below the headlamp (the way the ducati multi strada has it, but biger and ugly) it would invole takeing a big bit out of the lower part of the faring and makeing a brackett of some kind.. but it dosent do anything and ive never liked that bit anyways Very Happy
That way it would not risk overloading anything....
stryker
PostPosted: 14:31 - 12 Nov 2004    Post subject: Reply with quote
REF: the LED bulb thread in general chat. LED bulbs of any use to reducing your drain while giving good lighting?
Fraid the LED bulbs on the market are limited to mostly the most popular bayonet style and sizes.
Now what?
mr.z
PostPosted: 15:36 - 12 Nov 2004    Post subject: Reply with quote
Ah yes, i'd totaly forgot about that, yes it would be a significant wattage saveing... ill remember that when i'm looking for lamp powers Thumbs Up
While looking for a cx pic to shop (to get an idea of what two headlights might lok like) if found...
https://www.funky-moped.fsnet.co.uk/bikes/CX.jpg Shocked
2x CB400 headlights, dosent mention any chargeing system modifications...
and
https://www.cxboard.netfirms.com/cxChopper/August2003/headlights.jpg
This is sort of what i had in mind, i dont think there would be room for an additional full sized lamp, but a smaller one underneeth would be no problem...
The last post was made 21 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 78.86 Kb
